Honda 250 Hornet fuel tank removal
scamper
PostPosted: 15:41 - 20 Nov 2022    Post subject: Honda 250 Hornet fuel tank removal Reply with quote
My hornet suddenly stopped running right and I wanted to check the spark plugs but having problems removing the fuel tank. I've removed the bolt at the back and I've pinched the clip on the fuel pipe and pull it down but I can't pull the pipe off. Is there any trick to pulling off the fuel pipe?
Supposing I can get the fuel pipe off is there anything else to disconnect? I watched a video that seemed to suggest there was something else to disconnect.
Easy-X
PostPosted: 19:50 - 20 Nov 2022    Post subject: Reply with quote
Generally you can lift up the tank a little bit and have a peek at what else is connected. If a pipe's been on a while then it might take some effort to wrestle it off, just go careful.
scamper
PostPosted: 11:09 - 21 Nov 2022    Post subject: Reply with quote
Thanks I'll take a closer look when I can get out to it.
WD Forte
PostPosted: 21:34 - 21 Nov 2022    Post subject: Reply with quote
Rubber pipes can sometimes feel like they've been glued
on to the metal pipe if they been there for years.
I usually grip them with the inner curved and serrated part of
the jaws of pliers ( the 'nut cracker' looking part in the image below)
and twist the end of the pipe around the tube before pulling them off and it mostly works for me
If the bike has a fuel gauge you'll also need to disconnect the sender cables
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Ftse1.mm.bing.net%2Fth%3Fid%3DOIP.z9DyMlKrRI1xEr3uFB3XbwHaFj%26pid%3DApi&f=1&ipt=e787e753da9f8119041c79545aedf48d1a502fb0c478c406c74fa2152c9bf83b&ipo=images
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 21:36 - 21 Nov 2022    Post subject: Reply with quote
Sounds like the OP hasn't worked out how the quick release on the fuel line works.
Triumph Sprint ST 1050
WD Forte
PostPosted: 21:41 - 21 Nov 2022    Post subject: Reply with quote
I'm assuming he's struggling with springy/clampy type tube clips
I spose he may have those modern locking plastic ones I've
mainly seen used on FI systems.
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 21:51 - 21 Nov 2022    Post subject: Reply with quote
It'll be a modern FI one. THe first time I tried to do my triumph's quick release it was an hour of convincing myself that I was doing the right thing and its supposed to come apart like that.
scamper
PostPosted: 22:43 - 21 Nov 2022    Post subject: Reply with quote
That's it. I got the pliers on the clamp and pulled that down the fuel pipe. Now can't pull the fuel pipe off and wondering why it's so hard. Not entirely sure what to expect and don't want to break anything. Is there any knack to it?
No it's not F1, just a pipe and a springy clamp. It's a 1998 so getting on a bit.
scamper
PostPosted: 22:47 - 21 Nov 2022    Post subject: Reply with quote
I'm sorry I should have read the thread above. I see what you mean about the pliers. I'll give that a try
Easy-X
PostPosted: 22:52 - 21 Nov 2022    Post subject: Reply with quote
One can only assume with their nimble little fingers the Japs think they're perfectly fine Neutral But if that's what the OP has rather than a little metal spring clip then it's a case of sliding over the plastic cover to expose square buttons either side (the grey squares in this picture)
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRFcWosa4jXx3oAQsV_FzuTL-pOmZpj5_5PzQ&usqp=CAU
...and really squeezing them both at the same time while pulling the connector off the tank pipe. Goes back on dead easy ofc!
Zen Dog
PostPosted: 23:43 - 21 Nov 2022    Post subject: Reply with quote
I had exactly the same thing on the Striple. It's an absolute sod to come off and it feels like it's going to snap at any moment even when you're doing it right. There's a bit you have to click in at the same time and mine didn't want to, I ended up having to use circlip pliers and my hands to get the bugger off. Horrible design.
But yeah on older style pipes I've had them stick on and got them moving using the pliers method without splitting them. Just twist the pipe around on the nozzle a little bit before trying to pull it off. Fnarr.
Zen Dog
PostPosted: 23:44 - 21 Nov 2022    Post subject: Reply with quote
Easy-X wrote:
That's the evil little bugger!
PostPosted: 11:56 - 22 Nov 2022    Post subject: Reply with quote
The 250 Hornet is just a standard pipe and clip, its just bastard old rubber. Be prepared to get a new bit of suitable pipe Laughing
scamper
PostPosted: 22:03 - 22 Nov 2022    Post subject: Reply with quote
This is what the fuel pipe looks like. I've pulled down the metal clip. As you say the pulling the pipe down seems to be the tricky bit.
https://i.postimg.cc/gk47FL68/IMG-20221122-173102.jpg
Kawasaki Jimbo
PostPosted: 22:34 - 22 Nov 2022    Post subject: Reply with quote
Slide a big, flat-blade screwdriver onto the rim of the hose and try to push it down. Works on my ‘99 Kawasaki. You might have to twist the blade so that one side leans on the fuel tab body and the other side levers the hose downwards.
Edit: I think when you pull the hose you stretch it and so tighten the rubber, whereas prising it off doesn’t.
Zen Dog
PostPosted: 02:12 - 23 Nov 2022    Post subject: Reply with quote
Do this. With the pliers, just rotate the pipe around on the nozzle, backwards and forwards, not trying to actually pull it off the nozzle, just rotating it, until it frees off and you can twist it pack and forth with your fingers. Then rotate it back and forth with your fingers while pulling down at the same time. It should come off, they always have for me at least.
Easy-X
PostPosted: 12:25 - 23 Nov 2022    Post subject: Reply with quote
Think Chinese finger trap Smile
If you're doing this in cold weather the rubber will be hard. A quick blast with a hair-dryer or heat gun might help. Not a blow lamp!
WD Forte
PostPosted: 13:18 - 23 Nov 2022    Post subject: Reply with quote
Looking at the pic
Like kwaklesaki jimble, I'd have just got a flat blade screwdriver in there and levered it down the spout to free it up
bikers smell of wee
Kawasaki Jimbo
PostPosted: 20:18 - 24 Nov 2022    Post subject: Reply with quote
WD Forte wrote:
Looking at the pic
Inadmissible. You’d already gone for the pliers, Jsun Kung. Wink
The last post was made 3 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 105.16 Kb
