| Easy-X |
 Easy-X Super Spammer
 Posted: 22:44 - 24 Nov 2022 Post subject: Front brakes: drop the hardline? |
I have some plans for my bike in the next year and given the existing rubber lines will be ~7yrs old they'll be on the replacement list.
I'm eyeing up the front brakes:
https://frentubo.it/wp-content/uploads/2020/11/yamaha_xsr_700_abs_frentubo_carbonio-5.jpg
Brake line comes down from the ABS unit and then there's flexi-hardline-flexi looping over the mudguard. Given I can make up my own braided lines I'm thinking of just one simple line running over  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 22:49 - 24 Nov 2022 Post subject: |
You wonder why they didn't do that in the first place, there seems no particular reason why it needs to be a hardline in that section. Maybe they found it was rubbing/bouncing against the mudguard? ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| Nobby the Bastard |
| stinkwheel |
 Posted: 23:59 - 24 Nov 2022 Post subject: |
Pretty standard to do that even before ABS, one flexi line from the master cylinder down and a hard line across to the other calliper. I think it's a bit lighter and possibly cheaper than running two lines down from the MC.
It was also pretty common to shitcan the rigid line and run two seperate lines down from the MC when replacing the brake lines. Any time I've done it, it''s noticeably a bit of a fidget to get both lines fitted in and routed neatly down from the bars.
A hard brake line is better than a flexi one if it doesn't need to flex. If you're talking about looping a flexi line over the top of the mudguard to replace the rigid one, I'd just stick with the rigid one. If you're talking about running two lines down from the MC, one major advantage is they are easier to bleed. Two seperate lines was always known as "race" setup. I don't know why.
I know nothing about ABS so I don't understand half of the plumbing there. Or are they sensor wires? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Zen Dog |
 Posted: 00:57 - 25 Nov 2022 Post subject: |
| stinkwheel wrote: | Pretty standard to do that even before ABS, one flexi line from the master cylinder down and a hard line across to the other calliper. |
Yeah, but with this one, the line which loops over looks like part-flexi, part hard-line. With all the extra connectors and clips, you'd think it would be more complex, heavier and more expensive than sticking with just one or the other.
I always wondered why 2 lines is called a "race" setup. I can see it potentially having minor benefits for racing though. Besides the easy bleeding (which is worth it on it's own for me), it does make things easier for quickly working on the front end, you can leave the calipers dangling, and swap forks, mudguards, wheels etc. without dealing with a load of clips and things, and then zip tie them back on if needed. If the brake fluid in the lines absorbs some of the heat during braking, then in a race scenario could it mean that having 2 more or less equal and separate lines (and therefore volume of fluid) mean they heat up more evenly? Seriously marginal gains I imagine though. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Shaft |
 Shaft World Chat Champion
| stinkwheel |
| Easy-X |
| Nobby the Bastard |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 13:22 - 25 Nov 2022 Post subject: |
| stinkwheel wrote: |
I know nothing about ABS so I don't understand half of the plumbing there. Or are they sensor wires? |
Indeed. Looks like a right bugger's muddle. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| sickpup |
 sickpup Old Timer
| Zen Dog |
 Posted: 14:57 - 25 Nov 2022 Post subject: |
| ThatDippyTwat wrote: | This. Run a couple of braided lines on a dual banjo bolt. I'll be doing this to my Viffer and unlinking the brake after Xmas. |
Running a couple of lines for the front brake shouldn't be a problem, but genuinely unlinking the brakes is much more involved than you might think. Think I mentioned it before but it's not just a case of making a few loops of brake line and removing things. You'll almost certainly need new master cylinders for a start. It can be done, but just have a good read on the VFR forums before you get started if you haven't done so already, just so you know what you're getting into.  ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| stinkwheel |
| Robby |
 Robby Dirty Old Man
| WD Forte |
 WD Forte World Chat Champion
| Zen Dog |
| stinkwheel |
 Posted: 22:46 - 25 Nov 2022 Post subject: |
He could also consider replacting the top banjo bolt for one with a hydraulic brake light switch in it too. It's what I do, had too many of those flimsy brakelight microswitches fail over the years. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Posted: 22:50 - 25 Nov 2022 Post subject: |
| Zen Dog wrote: | | Robby wrote: | I'm not sure why you want to get rid of the hard line. |
I think it's because if he's committed to replacing all the rubber/flexi pipe in the front brake, he'll need to make up 2 small sections to connect to the hard line. So he's considering making one line from flexi to replace the whole "over the mudguard" section as a simpler and probably neater looking alternative. |
Pretty much. I don't rate the OEM flexi-pipes on a bike in the same regard as say a car, the latter at least are never going to see any UV. That's still a thing? Or is it magical rubber these days.
In my experience making steel braided lines up it's less important to get the length dead-on to the millimetre the longer the line is. Eyeing the existing lines on the front they'd probably need to be spot on to just drop in and then I may as well stick to OEM stuff. I'm very much into incremental improvements where practicable so I shall give the "race setup" serious consideration.
On the rear there's two hard lines running in parallel to the ABS unit with block junctions to four flexi-pipes... for the single brake caliper Whereas it could be simplified to two lines between Master, ABS and Brake, less points of failure  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Easy-X |
| stinkwheel |
| Fizzer Thou |
| stinkwheel |
 Posted: 15:19 - 08 Dec 2022 Post subject: |
I don't like ABS in cars, never tried it on a bike but I'd imagine it's similar. It's to let you steer with less risk of skidding while braking hard.
What I find is there are situations where I WANT to lock the wheel and the ABS kicks in causing the vehicle to just run-on when I feel it should have stopped. Also all my years of riding motorbikes have taught me to brake only in a straight line for maximum effect but come off the brake for steering. Tyres give maximum grip in any one axis, ask them to grip in two axes at once and you're in trouble.
One situation where it's a pain is on narrow roads where you put the nearside wheels onto the mud/grass/gravel at the side of the road. I usually lock those and they drag through the loose shit while I'm looking for max braking on the offside wheels. With ABS, there's no feel at all because the ABS kicks in super early on the tyres on the loose stuff.
The other is snow. Sometimes the only way to stop is to plough snow up ahead of the wheels and hope you wear through it onto the road surface. Or you need to lock the wheel to instagate a slide when negotiating junctions with piled snow on them. First time I used an ABS equipped vehicle on snow, it scared the shit out of me because the brakes did nothing at all. Still does.
I also like to squeal the tyres when idiot pedestrians walk out into the road without looking.
Don't get me started on traction control. You could stick my last van (RWD Vito) on a steep slope of wet tarmac 'till you turned the TC off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 3 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
