| Easy-X |
 Easy-X Super Spammer
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 09:23 - 23 Oct 2022 Post subject: |
It's easy enough to do your own tyres, breaking the bead is the hardest bit, but some tyre soap and a point force should get it to break quite easily.
Rim protectors are a must, otherwise you'll be scraping and denting your rims all over the place.
Like everything else, until you get the right technique it'll seem really difficult, but once you get it then it's simple.
As for getting the tyre to bead, you can use anything from a small plug in compressor to a proper high pressure one ... it all depends on whether or not the bead is pressing against the rim properly and making a seal (where the high pressure makes a difference) ... that and lube of some sort is a must.
The main reason for not doing it yourself ..... the stack of tyres you'll then have to get rid of ... I personally have around 15 tyres I need to get rid of  |
| Pete. |
 Pete. Super Spammer
 Posted: 09:46 - 23 Oct 2022 Post subject: |
Big bike tyres are a piece of piss.
You want a hard tyre to change at home try one of those little scooter bastards. ____________________ a.k.a 'Geri'
| Fizzer Thou |
| Robby |
 Robby Dirty Old Man
| sickpup |
 sickpup Old Timer
| hellkat |
 hellkat Super Spammer
 Posted: 19:51 - 27 Dec 2022 Post subject: |
Ain't gonna happen
I did learn once, how to get a back wheel off, but that was in nineteen eleventy whatevs and I can only just about remember how to oil a chain by sticking a broom in the back end and spinning the wheel, I'd be hard pushed to even do that nowadays.
So yeah ... nah  ____________________ Not nearly as interesting in real life. |
| Easy-X |
The last post was made 3 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
