Paugeot tweet 125cc - won't start all the time
bloodwolf
PostPosted: 17:50 - 15 Dec 2022    Post subject: Paugeot tweet 125cc - won't start all the time Reply with quote
Hello,
I have the paugeot tweet 125cc moped and it was stolen few months back, since then I have been having continuing issues with it.
The bike won't start, unless use a jump pack or charge battery. However once I've driven it somewhere, it's dead again.
I installed a new battery and now once again having the same issues.
So, today I got a voltage meter and here are the results...
Battery 14.05
16.75 engine on
18.85 low reves
19.05+ on higher reves
I have also looked on the workshop manual where the regulator is, but I can't find it where it's meant too be.
Anyone know what is going on? I would appreciate any advice.
Thank you.
Update: I've had the bike running for about 15mins and battery has dropped too 15v already.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:21 - 15 Dec 2022    Post subject: Reply with quote
Where are you testing the voltage with the engine running?
Triumph Sprint ST 1050
bloodwolf
PostPosted: 18:28 - 15 Dec 2022    Post subject: Reply with quote
On the battery
jaffa90
PostPosted: 18:32 - 15 Dec 2022    Post subject: Reply with quote
""""So, today I got a voltage meter"""
Is the meter set on D/C or A/C voltage when testing?
bloodwolf
PostPosted: 18:39 - 15 Dec 2022    Post subject: Reply with quote
I have it set like it is in photo. This is what I've heard it should be on when I've looked on YouTube...
https://freeimage.host/i/HovVzwN
Nobby the Bastard
Harley Gaydar
PostPosted: 18:44 - 15 Dec 2022    Post subject: Re: Paugeot tweet 125cc - won't start all the time Reply with quote
bloodwolf wrote:
Battery 14.05
16.75 engine on
18.85 low reves
Battery with the engine off is a bit high, presumably engine on means engine running and all these readings look too high and your reg is probably knackered. This will have fried the battery.
Park it up and check the voltage on the battery in the morning.
WD Forte
PostPosted: 18:54 - 15 Dec 2022    Post subject: Reply with quote
meter setting looks fine so I'd say it deffo overcharging
if you get a rotten egg smell that's yer battery cooking that is
and not to be too technical but it will soon shit the bed.
over charging can affect other electrical systems, not just the battery as the higher voltage may burn out other components like coils for instance as the primary coils have a pretty low resistance.
12V into a 3 ohm coil will draw 4A and 36Watts
19V into a 3 ohm coil will draw 6.3A and 57 watts
Bad grounding can cause reg rec outputs to 'float' even if they're not faulty
bikers smell of wee
jaffa90
PostPosted: 19:02 - 15 Dec 2022    Post subject: Reply with quote
As said the meter setting is correct and readings way to high, so try testing a 1.5v or 9v dry batteries to rule out the meter.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:22 - 15 Dec 2022    Post subject: Reply with quote
Don't bother with this.
jaffa90
PostPosted: 20:02 - 15 Dec 2022    Post subject: Reply with quote
https://www.google.com/search?q=voltage+meter+reading+faulty+&ei=B26bY7eOLoeV8gKSvqngCg&ved=0ahUKEwj3rbfdpvz7AhWHilwKHRJfCqwQ4dUDCA8&oq=voltage+meter+reading+faulty+&gs_lcp=Cgxnd3Mtd2l6LXNlcnAQDDIFCCEQoAEyBQghEKABMgUIIRCgATIKCCEQFhAeEA8QHToKCAAQRxDWBBCwAzoKCCEQwwQQChCgAToECCEQFUoECEEYAEoECEYYAFDiEVi_FmDYWWgBcAF4AIABZIgBowOSAQM0LjGYAQCgAQHIAQjAAQE&sclient=gws-wiz-serp
Nobby the Bastard
Harley Gaydar
PostPosted: 20:35 - 15 Dec 2022    Post subject: Reply with quote
Still better off seeing what the voltage is after leaving it for 12 hours. If it@s still saying 14 v and won't start then maybe the meter is overstating the actual voltage.
If, however, it's saying less than 12 v then the battery is knackered and is a much more useful result than seeing how inaccruate to 2 decimal places your meter is.
Oh, and the first result from your google search? Home comsumer electric meters and not multimeter....
https://www.citizensadvice.org.uk/consumer/energy/energy-supply/your-energy-meter/find-out-if-your-energy-meter-is-faulty/
bloodwolf
PostPosted: 20:52 - 15 Dec 2022    Post subject: Reply with quote
Thank you for all the replies.
The tester is brand new and has loads of good reviews.
The battery is also brand new and was only put in about 4 weeks ago. I had same issue with last battery.
After bike was on for about 40mins with engine running on its stand, it went down too 14.40v.
I'll check in morning and see what it reads, I'm just so confused what it could be and also where the reg even is, I can't find it.
The wires were reconnected after it was hot wired, so could it be a wire on the wrong place?
Nobby the Bastard
Harley Gaydar
PostPosted: 21:01 - 15 Dec 2022    Post subject: Reply with quote
You need to check the voltage on the battery after the bike hasn't run for a reasonable period. I.e. about 12 hours. Do not start the bike before checking or whilst checking.
There is a difference between checking the voltage the battery kicks out and what the charging system kicks out.
If you've just replaced the battery and the new one has been fucked its being fried by your charging system.
As I said, those voltages are far too high and there's something wrong with the regulator. I'm betting you'll get a reading of less.than 12 volts in the morning.
WD Forte
PostPosted: 22:58 - 15 Dec 2022    Post subject: Reply with quote
!4.4V across the battery terminals is quite feasible if it had recently been running at 19v ish as the voltage won't drop immediately
when the engine stops unless there's enough load on it to pull it down.
It could take a while for the battery to normalise.
When it was nicked the wiring was quite possibly frigged with
and if they pulled a ground connection loose, that could drive up the voltage from the RR
All the OP bothers to tell us is its a tweet 125
Oh fucking great, we're all tweet experts here right?
year? carb/EFI? (they have different fucking wiring and RRs)
don't fucking tell us, we love the old guessing games we do
bikers smell of wee
bloodwolf
PostPosted: 23:29 - 15 Dec 2022    Post subject: Reply with quote
Sorry? Can you not read where it says (paugeot tweet 125cc) and where it also says (Moped)
Bhud
PostPosted: 01:29 - 16 Dec 2022    Post subject: Reply with quote
You're being your own worst enemy, with that attitude. Fix it, and your life will be better. He knows what he's talking about, especially with electrics.
Easy-X
PostPosted: 01:39 - 16 Dec 2022    Post subject: Reply with quote
The year would help at least.
bloodwolf
PostPosted: 03:45 - 16 Dec 2022    Post subject: Reply with quote
I'll do that, thank you.
The bike is 2017.
bloodwolf
PostPosted: 10:41 - 16 Dec 2022    Post subject: Reply with quote
Just tested battery and it shows 13.38. didn't turn bike on, left it off.
Thanks.
Update: Just checked the grounding by putting it on negative on battery and touching different metal parts on the bike, I pretty much get 0 or 0020.
This is using same settings has yesterday.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:46 - 16 Dec 2022    Post subject: Reply with quote
Turn it on and then check. Don't start the engine.
bloodwolf
PostPosted: 11:03 - 16 Dec 2022    Post subject: Reply with quote
I updated the last post about the grounding too, could that be the reason why?
Thanks.
bloodwolf
PostPosted: 11:05 - 16 Dec 2022    Post subject: Reply with quote
12.16v
Nobby the Bastard
Harley Gaydar
PostPosted: 11:21 - 16 Dec 2022    Post subject: Reply with quote
That seems a big drop and down at around the level where it may not start.
Does it?
bloodwolf
PostPosted: 11:26 - 16 Dec 2022    Post subject: Reply with quote
Does it?
It won't start. Lights are on etc and it tries too turn over, but it won't.
https://freeimage.host/i/Hot3QDX
https://freeimage.host/i/Hot3txn
https://freeimage.host/i/Hot3LNt
https://freeimage.host/i/Hot3rKv
These photos are from my bike and also screenshot from workshop manual.
The regulator isn't there and I don't understand why. Would a bike still work for awhile without it?
Thank you.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:37 - 16 Dec 2022    Post subject: Reply with quote
Right.
So, the power going to the battery has knackered it.
if there was no regulator how is the power getting to the battery?
Has someone just taped the wires out of the stator to the wires to the battery where the regulator is supposed to be?
The last post was made 3 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 126.21 Kb
