NSR125 what do these do?
2tenjoyer
PostPosted: 14:10 - 26 Jan 2023    Post subject: NSR125 what do these do? Reply with quote
Hello,
Help me understand these 4 things im showing in the video. I guess the 2nd one is for a sprocket? 1st and 2nd have some play in them (lmk if this is good). Also which have to spin and can I spin them if the engine isnt running like rn when cleaning or whatever? The 3rd is some sort of a coupling, what might it do? Fourth no idea. Have a great day.
WD Forte
PostPosted: 14:17 - 26 Jan 2023    Post subject: Reply with quote
1 gear change shaft
2 drive sprocket
3 breather/vent
4 cable tidy, to stop cables flapping about near the drive sprocket
bikers smell of wee
Gearshift shaft. Gearbox output shaft for the final drive sprocket. Horribly gummed up breather stub. Clip for wiring and/or breather hose.
First rotates about 45 degrees either way to select the gears. Second will rotate freely when in neutral and will turn the engine when in gear. Third should be clean and clear to allow any excess gas pressure to escape from the engine. Don't poke anything in it because you'll poke that dirt into the engine. Fourth is a clip, it clips things to stop them waving about in the breeze.
2tenjoyer
PostPosted: 14:41 - 26 Jan 2023    Post subject: Reply with quote
Thank you. The gearshift shaft doesn’t move at the moment. I don’t know if that’s how it should be right now. The drive sprocket is all okay then. What about both of them moving in and out in the clip?
PostPosted: 15:13 - 26 Jan 2023    Post subject: Reply with quote
You probably won't be able to move the gearshift without a lever on it and the engine rotating slightly.
Some lateral play is normal.
2tenjoyer
PostPosted: 15:41 - 26 Jan 2023    Post subject: Reply with quote
Opened the 2nd engine. What does everything in the pictures do? What might be missing? Also how to split the crankcase, there isn’t a crankshaft in it but the moon thingy or whatever goes through both of them. There is a spring and a nut that fell out in the 2nd picture.
How should I start dissasembling the engine going in the frame? Attaching some pics of it. I don’t have any special tools at the moment, so nothing complicated. Just unscrewing.
PostPosted: 15:56 - 26 Jan 2023    Post subject: Reply with quote
You really need to get a workshop manual. It's great that you're getting into doing your own maintainance but you obviously don't have even a basic idea of what the parts of this engine are and what they do and you're starting with incomplete engines. You are going to be in over your head very quickly indeed.
I'd have a go at dismantling and reassembling an engine without a manual but I have 20 years of experience doing it and understand how they work. Even then, I would almost certainly need to look some things up for clearances and measurements and I'd have paid attention to how it went together. Start with missing parts and you're onto a hiding to nothing.
Keep taking lots of pictures at every stage so you can look back at them and see what went where, in what order and in what position.
Haynes/clymer manuals are good because they explain things in plain english. Official Honda ones are great because they are very detailed with full diagrams of all the parts and give you the order of operations on how to dissasemble and reassemble things but they assume certain amount of knowledge of how to actually do these things.
2tenjoyer
PostPosted: 16:06 - 26 Jan 2023    Post subject: Reply with quote
I’m also using manuals.
stevo123
PostPosted: 16:53 - 26 Jan 2023    Post subject: Reply with quote
Sounds like you have bitten off more than you can chew. Study manual more closely and watch videos of 2T strip downs. If you are still struggling some back or go to a local mechanic for help. Good luck
Honda XL125-Yammy DTR125-Honda NSR125-Yammy TZR 250-Aprilia RS125-KTM RC 125-
KTM RC390-Kawasaki Ninja 636-KTM Duke 390
WD Forte
PostPosted: 18:38 - 28 Jan 2023    Post subject: Reply with quote
Don't know the NSR engine but the moon thingy looks like a balance shaft
I agree you may be taking on a lot at your stage of learning
and its difficult know what's missing precisely and the condition of what you do have without a good service manual.
I'd regard all that as 'spares, possibly useful' at best
bikers smell of wee
slowasyoulike
PostPosted: 18:55 - 28 Jan 2023    Post subject: Reply with quote
I don't know what year your NSR is, but there are exploded parts diagrams here for various model years:
https://www.cmsnl.com/honda-nsr125_model1222/
I'd have to agree that this is a big project for someone with little experience or knowledge. If it was me, I'd spend some time learning the basics of what makes your 2-stroke motor work before I dismantled anything else. There's plenty of good resources on YouTube that'll help you with that.
Fair play to you for getting stuck in though. Good luck with it Thumbs Up
The last post was made 3 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 72.57 Kb
