| type25dude |
 type25dude Derestricted Danger
 Posted: 21:39 - 23 Jan 2023 Post subject: 1982 Suzuki gs 125 cdi issue |
Hi, I’m tackling a 1982 Suzuki gs 125, drum brake, kick start model. The previous owner has chopped at the wiring to install a non stock cdi, but seems not to have got it working so the bike has sat for a long time. The bike has 6 wires coming from the stator, in two groups of 3. One group has a red connector, the other group has a clear connector. The plugs where they would have connected to the cdi have been cut off, so I’ve no idea which order the wires would have entered the cdi. Also I believe the cdi 032900 00530 is the correct one for the bike, but has only 5 pins, where does the 6th wire go.
Would anyone have a photo of how the connectors enter the cdi showing the colours of the wires. Or could you describe them?
Also, what colour wires connect to the coil?
Also, where Is the vin number on the frame, can’t find it.
Thanks. |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 00:19 - 24 Jan 2023 Post subject: |
From a quick and dirty look at some sketchy wiring diagrams. Five wires from the stator on a GS/GN 125. Three are yellow and go to the reg/rec and two for the CDi pickup coil (green and blue).
The CDI has 5 wires and two connectors. With the 2-pin connector on the left, going left to right it's green from pickup coil. Blue from pickup coil. Then in the three pin connector it's orange and white to the ignition coil and kill switch, white to the ignition coil and black and white which is earth.
That seems to be a pretty universal setup for all the small 4t suzukis of that era.
https://i.imgur.com/6NrRC0j.jpeg
Some models have a gear indicator which would have six wires coming out of the engine in a bundle.
If no gear indicator, there may be a single wire for the neutral switch also coming from the engine. It's unhelpfully blue like one of the pulse coil wires. Fuck you Suzuki. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
| type25dude |
| WD Forte |
 Posted: 13:04 - 26 Jan 2023 Post subject: |
The bare twisted wires poked optimistically into the solder pads on that PCB tells you everything you need to know about the previous owners electrical engineering abilities. As above, regard anything he's touched as a total bodge job.
What you really need is a proper workshop manual which will have the correct wiring schematics for what you're supposed to have. I'd just spend the money on one. If you have the model and year, you'll be able toget a haynes or clymer manual.
If it was me, I'd strip back anything the previous owner has touched and start from there. Might even be worth getting a loom for it if he's been at it elsewhere.
The workshop manuals usually have infor on engine number ranges too. Your wire colours don't seem to match what I was expecting which makes me query if either the wires in your picture are original or if it has the engine it's supposed to have. Do the colours on the "bike" end of the connectors match the ones on the butchered side? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| type25dude |
 Posted: 20:08 - 26 Jan 2023 Post subject: |
A bit of detective work.
Picture of a confirmed OEM reg/rec for a 1982 GS125 shows the blue on white, red on white and yellow are your charging phases.
CMSNL lists the correct ignitor unit as part: 3290005300 or 3290005220 depending on varient. (I think the first is electric start, second is kick-start). Both are like rocking horse poo and very expensive in the unlikely event you find one.
You MIGHT be able to fit a later model or pattern/universal CDI but if you can't find a wiring diagram, you're going to need to trace those wires back and see what each one does so you know where to connect them. You'll also need a wiring diagram for the bike it's off to see where they go.
For what it's worth, they are to all intents and purposes the same engine as the much more common GN125 so if I was to be fitting a CDI off another model, that's what I'd go for.
Another option would be to fit a full used charging and ignition system (stator, rotor, CDI and pickup coils) off a different model suzuki. The main determinant of what will fit is the crank for the taper and keyway positioning. Depending on which varient you have, either an '85-88 DR125s or an 89-94 GN125 share the exact same crank.
To see what varient you have, you'll need the frame number which should be stamped on the headstock. Then you can check this chart:
https://images.cmsnl.com/img/partslists/suzuki-gs125-1982-z-general-export-united-kingdom-e01-e02catalog-preface_bigsue0308prefac_7b4b.gif ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| type25dude |
| WD Forte |
| WD Forte |
| type25dude |
 Posted: 17:50 - 27 Jan 2023 Post subject: |
Hi,I've added a picture of the cdi I have for the bike, though I don't know how it could e made to work. The frame code is given in the logbook as 103254, but with no preceding code, I can't find I on the headstock. I will b e gone for a couple of days so won't be able to reply till Tuesday. The bike is kept at work, as a project for a group of teenagers at my school. Painting and fresh loom would be nice but beyond what I wanted to do, though the tank and mudguard will be painted. I think the photos make it look a little worse than it is. I just wanted a bike to show them how to change oil, brakes etc, didn't count on any major difficulties. Bought it at short notice, cheap. I know, I know...... |
 Posted: 18:51 - 27 Jan 2023 Post subject: |
| type25dude wrote: | Hi,I've added a picture of the cdi I have for the bike, though I don't know how it could e made to work. The frame code is given in the logbook as 103254, but with no preceding code, I can't find I on the headstock. I will b e gone for a couple of days so won't be able to reply till Tuesday. The bike is kept at work, as a project for a group of teenagers at my school. Painting and fresh loom would be nice but beyond what I wanted to do, though the tank and mudguard will be painted. I think the photos make it look a little worse than it is. I just wanted a bike to show them how to change oil, brakes etc, didn't count on any major difficulties. Bought it at short notice, cheap. I know, I know...... |
That is a regulator rectifier, not a CDI. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
| type25dude |
 Posted: 00:42 - 02 Feb 2023 Post subject: |
As above, a picture of a confirmed OEM reg/rec for a 1982 GS125 shows the blue on white, red on white and yellow are your charging phases.
So score those off your list. Chase the others through with a continuity tester of some sort. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| type25dude |
| type25dude |
| type25dude |
 Posted: 19:01 - 23 Mar 2023 Post subject: |
Still going on this. I've tried connecting the wires to a cdi, the two pulse wires, earth, one wire direct from cdi to coil, and 2 of the 3 power wires. Unsurprisingly, no spark. One suggestion I've come across is to connect two of the power wires to a step up transformer, and blank off the 3rd wire. My question here then is what voltage is expected leaving the stator, and what should go into the cdi. In other words, if I put in a step up transformer between the stator and AC cdi what do I expect to see going in and coming out of it. I've seen conflicting posts saying 12 volts, 15 volts or 400 volts. I don't know anything about 3 phase so what could I expect my 2 wires to produce, and what does the voltage need to be for the cdi to work? Thanks. |
| WD Forte |
The last post was made 2 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
