What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 32, 33, 34 ... 57, 58, 59  Next
Easy-X
PostPosted: 14:41 - 29 Jan 2023    Post subject: Reply with quote
jeremyr62 wrote:
Took the driveshaft out of my VFR1200 DCT and lubricated the splines at both ends.
Yeah, you wouldn't want your shaft to go in dry Wink
UncleFester
PostPosted: 18:49 - 31 Jan 2023    Post subject: Reply with quote
Rode to work.
More comfortable than either car.
Cheaper to run than either car.
Faster than either car.
Going to keep using it whilst it's dry - cold does not bother me.
2017 Z1000SX
hellkat
PostPosted: 19:38 - 31 Jan 2023    Post subject: Reply with quote
Had to move both bikes off the road because of the funeral next door today.
The Harley starts up but is still misfiring, may have to nurse that back to the shop (only two miles away). Might call out the RAC to take me there, actually. About time I used this policy before it runs out in March/ish.
hellkat
PostPosted: 19:43 - 31 Jan 2023    Post subject: Reply with quote
The Suzuki howevr wouldn't start, it turned over but wouldnt catch, might be out of gas ... although at least the battery hadn't gone flat, so its holding a charge now. So I pushed that up the curb, nearly dropped the fucking thing, but parked it up out of the way for the funeral. Might spend some time trying to get that restarted this weekend if its nice (if my general health allows it, as currently I'm reluctant to go out on the bike/s until this cold has properly cleared up).
UncleFester
PostPosted: 20:10 - 31 Jan 2023    Post subject: Reply with quote
Aye. If you're not 100% working out in the cold and damp is a sure fire way to take a turn for the worse.
I forgot to corner at one point... had a total talent vacation but it wasn't a sharp corner and that refocused the brain and body haha
2017 Z1000SX
NutsyUk
PostPosted: 16:39 - 01 Feb 2023    Post subject: Reply with quote
Finished wireing in the USB adapter and oxford heated grips on the new FZ8...
Discovered last owner bodged the h7 light in a h4 socket, even though its a h7 key for the fitting... So umm gonna have to make an adapter for that...
Also discovered the headlight reflector is sort of loose inside the housing. Might be broken, might have come off the adjustment nut. Gonna have to take the whole front assembly off to look inside D:
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
Bhud
PostPosted: 22:14 - 03 Feb 2023    Post subject: Reply with quote
Project bike electrics completed (including trunking), seat mounted, tank mounted - all working but I'm going to flush the tank with fresh fuel before running it. Found I'd lost my gear shift lever (one of the last things to go on) - so just ordered a replacement. Until it arrives, there are odd jobs still to do. This thing is a frame-up that's been many months in the making - not a restoration but a weirdo bitsa. I just kept chipping away at it, and it came together.
dave001 This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 21:36 - 05 Feb 2023    Post subject: Reply with quote
Strip off wheels and brakes. Cleaned the wheels up with iron-out and scrubbing then jetwash. Gave the calipers a good dose of iron-out and a blast with the jetwash then stripped those off, popped the pistons, cleaned seal grooves and re-built & bled. Now working lovely for another few months.
blurredman
PostPosted: 08:58 - 09 Feb 2023    Post subject: Reply with quote
Wired up a USB charger/Cigarette lighter socket on the Trophy.
Though is a 6v system (all DC however) it works okay so long as there is some throttle input. USB take 5v but it seems the unit itself needs what it says (It has it's own voltage gauge) is 6.5 before it will provide any power onwards to the satnav or the mobile phone.
But that's fine - so long as I don't need to use the headlamps, the battery in the devices will sustain themselves whilst the bike is stopped idling (say at traffic) but otherwise be charging up when i'm on the move. Cool
Hong Kong Phooey
PostPosted: 09:50 - 09 Feb 2023    Post subject: Reply with quote
If the idle speed is too low, the charging system on the bike might not be pumping out enough volts, if the battery is low or bad that would make it worse. Have you checked the voltage at the battery on idle?
If it's not the idle speed, there might be something else, like tarnished contacts at the regrec, or regrec/ stator wiring on the way out.
blurredman
PostPosted: 10:50 - 09 Feb 2023    Post subject: Reply with quote
The charging system is 50 years old as it is, but even though everything is cleaned up and relatively unused (only 16k miles use) it's not particularly strong at only 60w.
I've done this voltage testing in the past and get 6.15v idle (about 1,200rpm), up to 6.9v when above 2k rpm which is quite normal. With lights on the voltage is at 5.75v at idle and up to about 6.5v with some RPM into it. It's a year and a half old battery and has 6.20-6.25 whenever I check it so despite the poor charging system with lights on it's never actually been a problem for me on extended runs in the night.
That's the purpose of a battery - I suppose it is comparable to an overflow bottle in a coolant system, a sort of buffer arrangement.
On older vehicles, charging simply does not occur at idle for a lot of applications. One of my cars when I have the rear defroster going, the heater motor, the headlamps, brakes, and an indicator on the go all at the same time waiting at a junction idling i'd be at 10.5v on the gauge.. It's normal.
Anyway- all said and done this quick and dirty wiring set up is only temporary for the weekend, i'll be removing it sunday. I normally have my road map and i'll still be taking that as always. But this time I just fancied being able to ride by following an arrow and not stop everytime I think I'm lost. I don't ride with lamps on in the day time anyway so it'll all be a non-issue.
Additional thing I forgot to mention was that yesterday I did a lot of tidying up of the shed in order to get the Suzi TS185ER out. Took me a while,
But after getting the bike out I find it a lot easier to diagnose why it didn't want to start the other week when I went to give it a quick start, and I find the petrol tank is completely empty. No problem, found some petrol. Actually, I used non-fresh petrol- I poured in a jar of 1 year old fuel, and about 2 pints of petrol that was brown because I had previously used it to wash parts (with a brush you know). It was filtered, ish.
Anyway bike started okay and didn't take too long to come to idle okay after choke was off. I then rode to the petrol station on it (first time in over 2 years (!!!)- which is why the tank was obviously dry) and it ran well there and back. I had to adjust the idle a bit, and other than that the only thing noticable was the clutch lever wasn't returning fully and completely in time before I was on the throttle again after a change, so it did slip a bit- but i'll lubricate the cable to get rid of that stiffness in the cable. I installed some new hand grips months ago too so it was nice to finally use them- they felt good!
Hope to ride it more when I get time. Noted the front tyre is from early 1995 and the rear from 2006. Still, the bike gives great confidence even with such tyres.
pepperami
PostPosted: 14:55 - 09 Feb 2023    Post subject: Reply with quote
Today I did work on “Project Scrappy Hyosung” .
After a clean up of all the bits like spacers and the caliper mounting plate, the cleanish back wheel went back in Very Happy .
The bike can now stand on its own wheels.
All bits that needed it were copper greased..before re-assembling.
Both Hyosungs are on trickle charge.
Also found a possible solution for a couple of the broken fairing tabs.
Not a bad mornings work Thumbs Up
Bhud
PostPosted: 19:55 - 09 Feb 2023    Post subject: Reply with quote
After a couple of rides about 30 metres down the road (just happy that it works!), I discovered a brake piston seal leak on my project bike, so I stripped it down. The piston and seal are both brand new. No sign of damage or dirt, but I probably put it in wonky (edit: on second thoughts, I'm pretty sure I'd put it in wonky, as it was very stiff going in). Reassembled it and put new fluid in, with a zip-tie on the brake lever. I think it's sorted and the seal was just twisted, but if it isn't fixed, I'll know tomorrow.
Also, checked the tracking number, and the V55/5 with all relevant forms and fees has been delivered to DVLA! Yay! That was the final milestone, so I'm itching to get a registration number now. A 5-week wait, typically, they say. First ride out on the roads will be to the local bike mechanic, to check my work, in case I missed anything. I know that every single frame-to-engine, swingarm, etc. bolts are all torqued up and have Loctite on them, but there's always something.
blurredman
PostPosted: 13:28 - 13 Feb 2023    Post subject: Reply with quote
Blurredman wrote:
Talk about charging.
In the end- everything was fine for the journey to Dragon Rally and back. The makeshift temporary wiring can be removed now. Coincidentally I measured the battery voltage a few hours after getting back home and it was reading 6.33v which as I understand it is perfect capacity for a 6v conventional lead acid battery.
Easy-X
PostPosted: 20:23 - 14 Feb 2023    Post subject: Reply with quote
Wired in a new LED headlamp for the old fella's Harley. (The previous effort being a bit weedy.) Had to get a bit creative with the wiring to squeeze it all into the headlamp bucket.
trevor saxe-coburg-gotha
PostPosted: 20:26 - 14 Feb 2023    Post subject: Reply with quote
standard winter palaver - rode it for one hour, cleaned it for two
Rolling Eyes
hellkat
PostPosted: 17:18 - 20 Feb 2023    Post subject: Reply with quote
Started up the GSX.
Been stressing over why it *still* wouldn't start despite me throwing an arm and a leg at it lately.
Suddenly dawned on me: maybe it was out of gas ...
Turns out it was: on reserve, no juice, doh!
Silly hellkat.
It sounds lovely Wub
And I stink of petrol Wub Wub
The Snarley's still misfiring.
Doubt if I'm competent to do the plugs-check-thing without supervision, so will just get the RAC out next time I have a day off Rolling Eyes
to v or not to v
PostPosted: 18:51 - 20 Feb 2023    Post subject: Reply with quote
insured the old banger for another year.
Moto Guzzi V7.
DaddyStu
PostPosted: 23:13 - 21 Feb 2023    Post subject: Reply with quote
Rode it through Usk - gave it a 12L drink of the good stuff. Rode onwards upto Abergavenny. Then locked it up and walked the Skirrid before returning to 127.0.0.1 (in sector 0,0,1) via the A4042.
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
Bhud
PostPosted: 21:26 - 24 Feb 2023    Post subject: Reply with quote
Funny thing happened today.
I got my V5C (new registration) from the DVLA. Sooner than expected, and they thoughtfully returned my evidence documents, too. Not much to complain about.
Just one thing: the manufacturer name came back as "Leyland" (I guess it was the next name down after Kawasaki in the dropdown list, when they were making up this document). All the other details are correct. 2 wheels, motorcycle, cc, etc. Just "Leyland".
It would be so much fun to get a big decal saying "Leyland", and slap it on the side of my tank. Laughing
But I'll probably just get it corrected like a normie, to make the insurance comparison websites work.
PostPosted: 15:10 - 26 Feb 2023    Post subject: Reply with quote
Working on my new bike ready to swap over from the old one.
Fitted wheels with new Road 6 tyres
Service front brakes, new pads fitted
Service rear brake, new pads fitted.
Bleed clutch with fresh fluid, clean and re-paint reservoir cap
Clean and polish all the bodywork
PostPosted: 15:33 - 26 Feb 2023    Post subject: Reply with quote
I replaced the brake discs on my 600RR because I bent one of the OEM ones when the bike fell on the trailer. I had to buy a pair of EBC discs as I couldn't find any cheap OEM ones. I also removed the R&G engine cover because my local garage told me it was the cause of the oil seep that has been plaguing the bike. I ended up breaking a bolt but managed to remove the remains easily. In the process I damaged the gasket which I found was pinched near the oil leak anyway.
This gives me a job for next weekend, to replace the gasket that I've now ordered. Still, not the worst day in the garage!
https://www.bikechatforums.com/files/mclp4634_small.jpg
Easy-X
PostPosted: 18:08 - 26 Feb 2023    Post subject: Reply with quote
The main thing I dislike about the CBR600RR is the aftermarket exhaust options are a bit awkward.
ThatDippyTwat
PostPosted: 20:22 - 26 Feb 2023    Post subject: Reply with quote
Ordered new boots for the Viffer. Dunlop GPR300's. Ordered a rear brake pedal and front lever as well, PO has obviously laid her down, but it's a goven at her age. She's getting ratted at some point, panels are all sorts of colours underneath, and badly painted, stone chips are making it really obvious. JJust have to decide how shes getting the matt black. Truck bed Liner? Poundland rattle can? Brush?
Fireblade had new crash bungs fitted after laying her down in the snow. Waiting on nicer weather before I take her out and see if we can even begin to get those chicken strips off on these roads. Bike far outstrips my ability at least. Still giggle like a schoolkid whwen I let off after a pull over 7K. Utterly silly, and I love it.
The last post was made 2 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Page 33 of 59
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 139.27 Kb
