How would you use your beautiful engineering minds here?
2tenjoyer
PostPosted: 19:02 - 13 Feb 2023    Post subject: How would you use your beautiful engineering minds here? Reply with quote
Trying to fit the airbox here, but seems to be hitting the shock absorber. Modified the mounting points for the airbox, didn’t help, so went back to stock ones.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:24 - 13 Feb 2023    Post subject: Reply with quote
Three questions.
1) Is this the correct airbox for the bike (though I expect it is)
2) Thats not a standard shock. Do you have a standard shock to try?
3) Usually the visible damper bar would be at the top and not the bottom, and the preload the opposite. Have you put it in upside down?
Triumph Sprint ST 1050
2tenjoyer
PostPosted: 19:28 - 13 Feb 2023    Post subject: Reply with quote
Nobby the Bastard wrote:
Two questions.
Correct box, correct intake. The subframe is from another bike, so this is what I am left with. I thought on bringing the rear upper frame mounting points a bit back (on the top, where the long bolt should go), and then I will have enough space for it to not touch the back of the shock and reach around it.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:32 - 13 Feb 2023    Post subject: Reply with quote
Bikes are not lego and you can't just swap things about between models, as Marjay repeated says.
PostPosted: 19:46 - 13 Feb 2023    Post subject: Reply with quote
There are airboxes and there are airboxes.
Some of them are designed to reflect pressure waves back into the engine with minutely calclulated baffle placement, volumes and trumpet lengths. Without it, they wont run properly. Early 90's kawasaki sportsbikes being a good example.
Others hold a certain volume of still, clean air ready for the engine to suck in.
Looking at the pictures, yours is probably one of the latter. So the obvious thing would be to make up a new airbox that fits in the space you have. Try to keep the overall volume and inlet/outlet dimensions the same as the original.
I'm presuming this is going on a rorty, fuel injected single? Should be less fussy about pressure wave dynamics over having enough air available to suck in.
If I was going to make a custom airbox, I'd probably sculpt the shape in foam then do a composite layup over the top. If I had better fabricating skills, I'd make it from aluminium plate. If I had better computer skills, I'd 3D print it.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:51 - 13 Feb 2023    Post subject: Reply with quote
It's an NSR125 and he couldn't work out where to plug in the CDI last week....
2tenjoyer
PostPosted: 19:55 - 13 Feb 2023    Post subject: Reply with quote
Well car retrofitting has been great to me ☺️
2tenjoyer
PostPosted: 20:04 - 13 Feb 2023    Post subject: Reply with quote
[quote="stinkwheel"]There are airboxes and there are airboxes.
If I was going to make a custom airbox, I'd probably sculpt the shape in foam then do a composite layup over the top. If I had better fabricating skills, I'd make it from aluminium plate. If I had better computer skills, I'd 3D print it.[/quote
Yes, this is a 2000’s frame. I was originally going to do a layup, but modifying the mounts will be more time efficient. The 3D is definitely the best choice, but I don’t have any 3D scanner laying around and reacreating the same shape is a pain in the ass. About the airflow, well I’m not a specialist in that sphere, but you do make a great point. Although I think that it won’t lack any air whatsover, I think this will come down more to when the bike is running.
PostPosted: 20:08 - 13 Feb 2023    Post subject: Reply with quote
So it's NOT the correct airbox then? Because that one is clearly off a Husqvana.
An NSR125 airbox is the first type I described, a minutely calculated exercise in pressure wave dynamics.
I'd make my customary maximum 9 bob bet it wont work properly.
2tenjoyer
PostPosted: 20:13 - 13 Feb 2023    Post subject: Reply with quote
NSR125 is only the subframe and engine. It’s the right airbox for the frame, not the engine. But I’m sure that more air will never be a problem, even if it is, I’ll figure it out Wink
2tenjoyer
PostPosted: 20:14 - 13 Feb 2023    Post subject: Reply with quote
Thanks, little Santa helper:))))
PostPosted: 20:16 - 13 Feb 2023    Post subject: Reply with quote
Two stroke engines are finnicky beasts. Airbox shape and size is critical as is exhaust shape and size. If you fit the wrong airbox it won't run properly.
A car is a transportation device designed to get Mr and Mrs average to work and back. They are often modular in nature and will run on any old crappy petrol after any old abuse in any old weather. A two stroke motorcycle is much more of a fine tuned instrument. The magic that Honda and other manufacturers achieved is making them reliable and useable. By bolting on crap from other bikes, you're ruining that.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:20 - 13 Feb 2023    Post subject: Reply with quote
Jesus wept. Yet another person who reckons thay can cobble something together that will do the engine justice without melting it who hasn't the beginning of a clue how to start when Honda spent probably in the millions developing it....
Robby
Dirty Old Man
PostPosted: 21:47 - 13 Feb 2023    Post subject: Reply with quote
It's an engine that makes something in the range of 200bhp/litre without using forced induction. The exhaust and airbox are critical for that, and it still won't last that long.
Just don't go chopping engine mounts to make it fit. This project is never seeing the road, so at least leave the engine in a state where it can go on ebay when you give up.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:15 - 13 Feb 2023    Post subject: Reply with quote
Back in the day RGV owners were swapping piston rings to try and protect the engines with nitrate plated barrels every 12k miles.
NSRs have nitrate barrels so before even looking at putting a bike together I'd be checking the engine even works.
Like I said before, it's all much above the OPs pay grade. Even getting an NSR125 commisoned would require me to seek advice and potentially cost me fuck loads and that assuming standard intake and exhuast.
Anything else than that it'll not run or likely melt itself within the first 2 minutes.
WD Forte
PostPosted: 22:57 - 13 Feb 2023    Post subject: Reply with quote
I'd use my beautiful hot air gun to reshape/flatten the back of the box until doesn't foul on the shock
simples
bikers smell of wee
slowasyoulike
PostPosted: 00:10 - 14 Feb 2023    Post subject: Reply with quote
OP - there used to be a lad on here called arcane, I think you and him would get on well.
Zen Dog
PostPosted: 00:14 - 14 Feb 2023    Post subject: Reply with quote
Given that all the sensible advice above is clearly going to be ignored in favour of creating this monstrosity, the only two bits which matter are Robby's "don't cut anything off the engine" and WD's, which is the actual fix for the problem at hand.
Other than that, I just want to know more about this bike OP is making. He's already not using the NSR frame, which was the basis of one of the best handling bikes I've ever ridden, in favour of apparently a Husqvarna steel cradle motorcross frame(?). This has disaster written all over it, and we've only seen the shock mount area. I'm feeling there may be a real contender for the "eBay's Most Miserable Bike" thread at the end of this. I want details, more pics of the bike please! What's the concept? What are you attempting exactly with this bike OP? Pass the popcorn
Bhud
PostPosted: 00:15 - 14 Feb 2023    Post subject: Reply with quote
Wasn't there an NSR125 specialist on here once upon a time, called Alain?
Not to speak for him, but I think he might be horrified and tell you not to fuck with it.
mentalboy
PostPosted: 04:44 - 14 Feb 2023    Post subject: Reply with quote
I'm surprised there are any NSR125 engines still running, putting a highly strung two stroke into a machine aimed at greenhorn boy racers was never going to end well.
I spent 30 years twerping and derping with 4 strokes, great fun to mess with, anyone with half a clue can do all sorts of things to them.
I also spent a lot of that time tinkering with two strokes, as Marjay said, they are finnicky things. Just in case anything was lost in translation, they can be a complete bastard to get running, especially after some herp-de-derp has tried to 'improve' it.
Make mine a Corona.
Easy-X
PostPosted: 08:32 - 14 Feb 2023    Post subject: Reply with quote
Sounds like taking a saxophone and replacing the reed mouthpiece with one from a recorder Sad
Nobby the Bastard
Harley Gaydar
PostPosted: 08:41 - 14 Feb 2023    Post subject: Reply with quote
Alain ran away when OP started talking about trying the NSR 50 CDI on it...
Rob Fzs
PostPosted: 14:26 - 14 Feb 2023    Post subject: Reply with quote
OP will deal with this by cutting the airbox up and use bathroom sealant to stick it all back together
Actually did work for a while on a Cg i had, but not an nsr
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
The last post was made 3 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 121.29 Kb
