2001 FZS 600 Fazer, A2 derestriction, carburettor spring
Thomasnl
PostPosted: 14:58 - 17 Feb 2023    Post subject: 2001 FZS 600 Fazer, A2 derestriction, carburettor spring Reply with quote
Good afternoon,
I am want to derestrict my 2001 FZS 600 Fazer. It has no restrictions in the intake manifolds but I have found that the carb slides only open a couple of mm instead of all the way. I think this is caused by the very tightly wound spring (5DM-14933-20) which can't compress any further which prevent the slide from moving further. It also has a 115 main jet which is understandable if the bike cannot take as much air in as it should.
I want to order new springs (5DM-14933-00) which I think is the correct stock spring. I also want to order 150 main jets which is also believe is stock.
Am I correct in this thought or is the restriction somewhere else?
Any other people that have experienced the same restriction method?
Thanks,
Easy-X
PostPosted: 15:22 - 17 Feb 2023    Post subject: Reply with quote
There might be an RPM limit with the electronic ignition but I don't that specific bike, hopefully someone will chip in...
PostPosted: 20:14 - 18 Feb 2023    Post subject: Reply with quote
Normally carbs would be inlet washers or throttle stops, not heard of a carb spring change..
Thomasnl
PostPosted: 20:57 - 19 Feb 2023    Post subject: Reply with quote
Throttle seems to open fully and there are no washers in the intake. Just the slide that can't open fully and the small main jet. Only thing I can think of is the spring wish can't compress any further.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:07 - 19 Feb 2023    Post subject: Reply with quote
So, let's get this straight. You have used your finger to push up the slide and it only goes up a few mil?
Triumph Sprint ST 1050
PostPosted: 21:47 - 19 Feb 2023    Post subject: Reply with quote
It can work out cheaper to get a stage 1 dynojet kit. Usually has springs, main jets and needles.
Thomasnl
PostPosted: 00:20 - 20 Feb 2023    Post subject: Reply with quote
Yes, maybe about 5 mm.
c_dug
PostPosted: 11:56 - 20 Feb 2023    Post subject: Reply with quote
I had a FZS600 with a stage 1 dynojet kit (and 1 piece sports exhaust) and it rode really really nicely, if I was to buy another FZS600 this is the route I'd go down.
The last post was made 3 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 55.05 Kb
