Suzuki GSF 1200 2006 won’t start.
Nauris
PostPosted: 18:12 - 25 Feb 2023    Post subject: Suzuki GSF 1200 2006 won’t start. Reply with quote
Good evening!
I had running with my bandit last week!
Today tried to start but it won’t.
And suddenly my clutch wasn’t working properly.
I can shift gears, bet when it’s in gear clutch doesn’t do anything.
Spark plugs are working.
It just won’t start up.
I can’t figure it out.
Thanks for every replay.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 25 Feb 2023    Post subject: Reply with quote
Cable or hydraulic clutch?
Ah, Hydraulic, any pressure at the lever?
Triumph Sprint ST 1050
Nauris
PostPosted: 18:19 - 25 Feb 2023    Post subject: Reply with quote
Hydraulic. Yes there is pressure.
jaffa90
PostPosted: 02:16 - 26 Feb 2023    Post subject: Reply with quote
Good morning, when was the last service on the bike and is the engine oil level ok?
Nauris
PostPosted: 08:31 - 26 Feb 2023    Post subject: Reply with quote
Yes the oil level is ok.
I did service 1 month ago.
But few days ago I removed the gas tank, and putted it upside down for a few minutes.
Maybe there is some problem with vacume petcok.
I have spark, starter is running, but it just won’t start up.
I Checked spark plugs and they are kind of dry.
I’m not mechanic, so maybe I did something wrong with my gas tank, and vacume petcok.
Have can I make sure I have vacuume in my petcok, and the fuel is running¿
jaffa90
PostPosted: 19:09 - 26 Feb 2023    Post subject: Reply with quote
""" I did service 1 month ago.""""
""" I’m not mechanic,""""
Shocked
jeffyjeff
PostPosted: 05:46 - 27 Feb 2023    Post subject: Reply with quote
Maybe you got the lines to the vacuum petcock crossed up. Disconnect the fuel line between the petcock and the carburetors, and direct it into a container. Crank the engine over with the starter. Fuel should flow into your container. If it does not, make sure the vacuum port on the petcock is in fact connected to the vacuum source on the carburetor.
Nauris
PostPosted: 13:10 - 27 Feb 2023    Post subject: Reply with quote
Checked. Fuel is running!
But spark plugs arent realy wet!
When im, starting the engine, its smells like fuel.
was thinking maybe engine is flooded, took out the spark plugs, and cranked the engin to let fuel go out from carbs. that doset help eather.
No signs of life what so ever.
Maybe i will try to get help somwhere
The last post was made 3 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 53.16 Kb
