Steering lock stop missing
PotatoHead202...
PostPosted: 23:32 - 04 Mar 2023    Post subject: Steering lock stop missing Reply with quote
I've realised after seeing an older CZ125 that mine seems to have the flange (1/2" square piece of metal) missing from the bottom of the headstock on the frame.
Oddly, the two tabs either side on the lower fork clamps/triple tree are still there. The bars do turn very far but the tabs contact the frame before they can get any further.
Is this going to cause me arseache at MOT time? If it is is it a case of having someone weld a bit of metal on? Whats strange is that there is absolutely zero evidence of it ever being there in the first place. I'm only going off of other older models.
The frame is in the process of being painted with two part epoxy hence the incredibly rough finish at the moment!
Suzuki V Strom 1050XT, Honda CBF500 ABS,
doggone
PostPosted: 10:48 - 05 Mar 2023    Post subject: Reply with quote
I don't see how it's making it unsafe to ride unless it trapped your hand.
It isn't a specific thing to be checked but they do look at typical stress points like headstock for any signs of cracks developing.
The best option will be take it for test and definitely don't mention it at all even casually - rather than attempt any weld job which could damage bearings from heat and attract attention.
At worst an MOT fee lost but they won't fail it for that if they notice at all might be an advisory.
slowasyoulike
PostPosted: 12:16 - 05 Mar 2023    Post subject: Reply with quote
It's not necessarily a fail if you don't have a lock stop, but what will be is if the bars turn far enough to hit the tank or other bodywork, or trap cables etc. That's all my tester checks for anyway.
See Section 2.1.4: https://www.gov.uk/guidance/mot-inspection-manual-for-motorcycles/2-steering
PostPosted: 19:20 - 05 Mar 2023    Post subject: Reply with quote
Has someone welded/glued the bottom bearing race on?? Shocked
As above, if the bars/forks can hit the tank, it'll fail the MOT, if they can't, you're good.
PotatoHead202...
PostPosted: 19:38 - 05 Mar 2023    Post subject: Reply with quote
Welded the race on? Where did you get that from?
PostPosted: 21:59 - 05 Mar 2023    Post subject: Reply with quote
Maybe it's an insert type.
The last post was made 3 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 48.52 Kb
