Historically accurate replica war hammer, where to get one?
Ribenapigeon
PostPosted: 02:56 - 06 Mar 2023    Post subject: Historically accurate replica war hammer, where to get one? Reply with quote
Daft thing to want to buy but i do. So, where can I buy a decent acurate replica of a medieval war hammer? There are quite a lot of sites selling historical weapon replicas for re-enactment it seems but where are the right ones?
Cheers.[/u]
PostPosted: 09:29 - 06 Mar 2023    Post subject: Reply with quote
Cheers.[/u]
Check out skillagrims youtube channel, he reviews quite a lot of HEMA gear.
virus
PostPosted: 17:30 - 06 Mar 2023    Post subject: Reply with quote
Ravenforge.co.uk stock a few different ones depending on if you want a HEMA or a display piece.
own: 81 xs1100g...
Ribenapigeon
PostPosted: 18:18 - 06 Mar 2023    Post subject: Reply with quote
Im wanting a come the zombie apocalypse im prepared but looks good hanging on the wall meantime.
This looks the business and closely resembles the real thing found on museam sites. https://www.theknightshop.com/windlass-warhammer-with-spike
PostPosted: 18:27 - 06 Mar 2023    Post subject: Reply with quote
That's quite small and light 67cm long, 1kg. Either for single handed use or 'minaturised' for display? The other one... https://www.theknightshop.com/fiore-war-hammer is more the correct size historically I would have thought. 112cm long, 1.8 kg.
https://www.theknightshop.com/media/catalog/product/cache/1/image/650x/c9dcfd7b7989a8e877246fb8f9b6b76e/6/0/601004_battlecry-fiore-war-hammer_1.jpg
Triumph Trophy Launch Edition
Ribenapigeon
PostPosted: 00:33 - 07 Mar 2023    Post subject: Reply with quote
This is an authentic one from the period https://www.metmuseum.org/art/collection/search/25073
Interesting how rough the forging is compared with the reproductions available.
This one is interesting as you can see how the long strap like parts are forged into the head.
https://www.metmuseum.org/art/collection/search/33849
A Wikipedia entry says the longer pole hammers were for the foot soldier and the shorter for using on horseback.
Easy-X
PostPosted: 09:30 - 07 Mar 2023    Post subject: Reply with quote
15th Century... harder to keep the forge up to temp with an apprentice hung over from too much mead the night before working the bellows. The raw metal would also be inconsistent and have had to be worked by hand - power hammer? Unlikely. The cited example might also have been churned out for warfare en masse so little care spent on it.
Asking a bit much aren't we Wink
Much the same as rifles vs. carbines.
Ribenapigeon
PostPosted: 11:28 - 07 Mar 2023    Post subject: Reply with quote
I wish I had a forge. When I was at art school i loved the forge and was always working on stuff. Its hard looking at war hammers to work out how theyre actually made. They look simple but theres a lot more to them especially the ones with a top spike.
Ribenapigeon
PostPosted: 11:41 - 07 Mar 2023    Post subject: Reply with quote
https://www.celticwebmerchant.co.uk/axe-with-hammer-16th-century.html
This is getting out of hand!
PostPosted: 13:51 - 07 Mar 2023    Post subject: Reply with quote
Modern smiths do a lot of finishing work using a belt grinder, they forge big to rough dimensions then remove stock with a grinder and hacksaws to get to the final shape. Holes are drilled on a pillar drill.
Historical smiths would only have had access to files and a pedal grindstone, holes would have been punched, stock would have been hot-cut. They are a lot less precise in terms of squareness and accuracy (although arguably superior in strength) Everything would have been forged as close to final dimensions as possible then just finished off with files and such.
If you want to have a forge, just make one. All you need is a bucket, some refractory cement and some bellows (I'd suggest an electric blower rather than hand bellows).
https://lh3.googleusercontent.com/pw/AMWts8Dcif28CfiS38jGetUX3ul-psqiB2Ay6Ol39lcjtmOpRMGuKIu9Oc3sCWMRXV3WzEAp92wpJ2uQZFlYdt60HTsgOY8UpzFDWCeXd9rTzd3KS5yFMJjnGQOCtX-laBDsNqVQ39eaFWBCkc5q2DfupR1m=w1292-h969-no
https://lh3.googleusercontent.com/pw/AMWts8DN005oQj0M3yj53QhiYX0QJ4PlqOeMpQETxzXpeE6Y6-so5oczKjWmQJlQtuMmQde1FmdbEVSZuaYF0tfd7GeMWU1cSmf58qENoGSMn8BCnkGHNH-yiAHqmOEWw0fsaM4DM0CZwl2i0JMK8QlCb52b=w727-h969-no
https://lh3.googleusercontent.com/pw/AMWts8CigQ6wKXfvXG9FZrabkzPPuvSbbS06r6y2vwcT3hNsXWlHtKuNXp8K7mUnqzV1uaXmuuGFfgcHqoz4vyyHNqpz2KB80kpDGv64U7abs8auio_Zj7NobdECbyYevik1GBSjRAX0da0DQBnvXNWA78dp=w1292-h969-no
Ribenapigeon
PostPosted: 14:20 - 07 Mar 2023    Post subject: Reply with quote
It's the usual problem of getting a project off the ground even though i have the garden space. The big sticking point is getting a decent anvil. A good anvil and a hammer and I could fabricate other tools.
I used to be pretty good at forging back in the day. It all boils down to five processes, drawing out, cutting, bending, peircing and welding (forge welding). I never managed a good forge weld though but i didn't know back then you need a flux for that.
PostPosted: 15:47 - 07 Mar 2023    Post subject: Reply with quote
Have they made a war hammer on 'Forged In Fire'?
I must admit I do enjoy watching that programme. Thumbs Up
Ribenapigeon
PostPosted: 19:58 - 07 Mar 2023    Post subject: Reply with quote
Id like to see Nevil from Salvage hunters on it, he would wipe the yanks out.
PostPosted: 20:44 - 07 Mar 2023    Post subject: Reply with quote
You don't need an anvil. A striking block is absolutely fine. Round over one edge with a grinder, glue it down to a bit of railway sleeper or make a stand for it and you're good to go.
Alec Steele is a big proponant of using a mild steel striking block, especially for beginners because if you mis-hit, it wont spall. If you look at his early videos, he uses a simple 5 x 12 x 3" mild steel striking block with a hardy hole almost exclusively and used to run courses where you made your own set of smiths tools using one. I have a 6" cube of mild steel off ebay for a striking block.
The last post was made 3 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.88 - MySQL Queries: 13 - Page Size: 86.25 Kb
