| TravisBickle |
 TravisBickle World Chat Champion
| mentalboy |
 mentalboy World Chat Champion
| TravisBickle |
 Posted: 04:07 - 22 Dec 2022 Post subject: |
I had been warned about the powershift gearboxes being problematic however it was running ok when I got it and I got the car for a steal so figured even if I have to put a new gearbox in it at a later date, I'll still have got my money's worth out of it.
So far the gearbox has been fine, touch wood, and my mechanic said it's a "gen 2" powershift gearbox which is much better and more reliable than the "gen 1" ones, although still far from perfect.
Need to replace a few more vehicles on the fleet in the first half of next year and wondering whether it's worth getting any more Galaxys. The only realy viable alternatives are the SEAT Alhambra / VW Sharan which are far superior in terms of reliability (although I have heard horror stories about the DSG gearboxes on them as well, probably more reliable than the Powershifts on the Fords but more expensive to fix/replace) but I think the Galaxys are more plush and comfortable inside.
My remap guy said these Peugeot engines are crap on fuel, he has the same engine in his van, and also that the Powershift boxes sap power which will be contributing towards the poor mpg. If that's true, whichever way you look at it, I should be getting more than 27mpg!!!
Going down the VAG route for future vehicles seems to be the sensible choice, but I do just like these Galaxys. ____________________ 2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport |
| ThunderGuts |
 ThunderGuts World Chat Champion
| to v or not to v |
 to v or not to v World Chat Champion
| Easy-X |
 Easy-X Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| P.addy |
 P.addy Red Rocket
| Polarbear |
 Polarbear Super Spammer
| doggone |
 doggone World Chat Champion
| P.addy |
 P.addy Red Rocket
| Rob Fzs |
 Rob Fzs World Chat Champion
| dave001 |
 dave001 Banned
| mentalboy |
| UncleFester |
 UncleFester World Chat Champion
| TravisBickle |
 Posted: 07:15 - 02 Jan 2023 Post subject: |
| to v or not to v wrote: | wouldnt you be better off asking this on a Ford specific forum? |
Was going to try there next if no joy from this forum. This is usually my go-to when seeking advice, albeit usually bike-related.
| Easy-X wrote: | 27mpg is bad given it should be >50mpg. I would say bad injectors but my Skoda Fabia had a bad injector pretty much from new (eventually swapped under warranty) and a) it didn't make much odds to the mpg and b) if fuel is being pissed away you'd probably see downstream problems e.g. lambda sensor burn-outs or cat damage. |
That's what my mechanics were eluding to clutching at straws but it's a lot to fork out if it doesn't cure the problem. Also, if the injectors are leaking, wouldn't they return any unburnt fuel back tot he tank through the leak-off pipes? Admittedly my knowledge on this subject is limited!
| WD Forte wrote: | What sort of mpg are you expecting?
Taxi work in a city has to be the least economical way to use a car
in terms of mpg |
We don't work in a city, or even a town centre. 95% is rural country lanes, high speed A and B roads and motorways. Never had an issue getting 40mpg minimum out of any of the other taxis.
| Paddy. wrote: | Would be sorting the codes first, then getting the fuel system checked. |
Codes all went away after the service, even the one relating to the solenoid.
| Rob Fzs wrote: | Is the ford running one of them stupid wet belts? |
Not sure! Had the timing belt done shortly after buying it as it was on about 116k and the interval is 144k (had one snap on me once at 124k when the interval was 125k but because I had always changed the oil and filters myself had no history for the car and Ford would not honour it under warranty).
Managed to pull this off AutoData if that indicates whether it's wet or not?
https://i.ibb.co/162zTtx/Untitled.png
| UncleBFester wrote: | Get some cleaner spray and give the MAF a cleanup.
Maybe 02 sensors ......
OOI how's the seals on the intercooler/turbo pipework? Taken it for an italian tune up?
As for oil contamination, borewash? |
New genuine MAF and/or MAP sensors got to be worth a go, surely, thanks will try.
Wouldn't O2 sensors pull up a fault code?
Not checked the intercooler/turbo pipework personally but again, any pressure out of spec would flag a fault code surely? Gets an Italian tuneup daily! And no, that's not the cause of the poor MPG. Struggle to get 30mpg even driving as economically as possible.
Regarding borewash, you could be onto something here? We have a 1.6CDTi Zafira B that started leaking diesel into the sump and filling the sump up with diesel. Had to change the injectors. I guess this would account for the oil degradation fault codes which actually came back shortly after the previous service. So we're thinking quite possibly injectors??? ____________________ 2024 BMW M1000XR
| TravisBickle |
| UncleFester |
| Robby |
 Robby Dirty Old Man
 Posted: 11:33 - 02 Jan 2023 Post subject: |
It's either something simple or difficult. You're only going to get answers to simple stuff here, but theoretically the fault codes should tell you about more complex stuff.
If you suspect diesel dribbling down and getting into the oil, you can get home oil analysis kits, or the kind where you send it off to a lab. Not expensive, you get a few tests in a kit, so it could be worth doing the lab one for you whole fleet, I expect it would pay for itself fairly quickly if it picks up one major failure before it happens.
As for my fairly basic understanding of what goes wrong with diesel engines, is it blowing smoke, and can you feel any wear in the turbo by trying to wiggle it's shaft?
It's at the mileage where I would expect a turbo to be worn out, injector seals to be hardened, and injectors to be a bit fucked. |
| dave001 |
 dave001 Banned
| TravisBickle |
| Nobby the Bastard |
| TravisBickle |
| Nobby the Bastard |
The last post was made 3 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
