Suzuki RG125 Brake Disc and Caliper Problem
supra3turbo
PostPosted: 20:44 - 12 Mar 2023    Post subject: Suzuki RG125 Brake Disc and Caliper Problem Reply with quote
Hi All,
I am currently doing up my RG125 I rescued what was left of it for £200 years ago and ive decided to turn it into a cafe racer, its coming on well.
I have just come to look at the brakes, and noticed that not only was the front caliper not standard, it had been wearing through the inner part of the disc.
The disc is a 3 Bolt mounting type, but i understand there is some upgrade or something you can do as they were apparently quite bad brakes from the factory.
I am after a Brake Disc and Caliper that will fit.
EDIT Ive just been on CMSNL and the standard forks have top nuts with a Hex bolt head on, these are a Cap head screw in.... So these forks aren't standard either possibly.
I know the top Yoke isnt standard, but ive made a bolt on the CNC for that which will work nicely, the standard top Yoke is flimsy and requires the handlebars to be on top to act as a top clamp for the forks.
Any help would be greatly appreciated, Thanks Smile
Hoda CBR 600 FX stolen from stalybridge 2017/2018 black
Current Project Suzuki RG125 Cafe Racer
redeem ouzzer
PostPosted: 17:45 - 13 Mar 2023    Post subject: Reply with quote
RGV250 / GSXR400 front end is a straight swop.
Be a REAL MAN!
supra3turbo
PostPosted: 11:51 - 15 Mar 2023    Post subject: Reply with quote
Even the 1990 model Smile Cheers
PostPosted: 12:03 - 15 Mar 2023    Post subject: Reply with quote
If you have access to a CNC machine, pick a calliper and M/C you like and fabricate an alloy mounting plate for it.
supra3turbo
PostPosted: 15:01 - 15 Mar 2023    Post subject: Reply with quote
Thats a very good point, I could choose a twin pison caliper and make an adapter to bolt to the forks, awesome thanks for that ill get too it Very Happy
MCN
PostPosted: 12:27 - 16 Mar 2023    Post subject: Reply with quote
Fit a HELL braided brake hose.
The standard hose can provide a very spongey brake.
It's a very cheap mod that can produce excellent results.
No need to phaph with the rear as it's the most unused part of a motorbike. Unless you're on a tract and know how to use it.
supra3turbo
PostPosted: 09:19 - 17 Mar 2023    Post subject: Reply with quote
Is there any way of getting a universal Tachometer and MPH speedo, the bike came with a set of clocks, but I've no idea why they bothered, the bike has a cable operated tachometer and the clocks that are on it require an electronic signal, which im not sure if you can even get off the RG125 Gamma.
If i could find a cable operated Tach and Cable Speedo in MPH (With a neutral and indicator LED/Bulb for MOT) that would be great.
Easy-X
PostPosted: 15:23 - 17 Mar 2023    Post subject: Reply with quote
Not very exciting to look at but FleaBay has plenty of generic options, e.g.
https://www.ebay.co.uk/itm/175345402712
Not explained in the listing but these have mechanical tacho input and electronic speed input via a sensor & magnet stuck to rim or spoke. Then a right faff to program in the overall wheel circumference to calibrate the speedo display.
supra3turbo
PostPosted: 15:34 - 17 Mar 2023    Post subject: Reply with quote
Yeah i think i will have to get something like that, i put a full electronic custom dash on my friends NSR125 about 10 years ago I think it was.
Ill have a look for some options Smile
supra3turbo
PostPosted: 15:43 - 17 Mar 2023    Post subject: Reply with quote
I wonder if another suzuki clocks would fit, like these off a GS650
https://www.ebay.co.uk/itm/285183216702?hash=item42663e8c3e:g:LmwAAOSwqCFkDz7K&amdata=enc%3AAQAHAAAAwNhMlHp9k9ZTOLZPegE6q70RHX1%2Fbwux8GXjNjVxQoqFVwk1ekjr5792X6xi70KUYLLL6AHUO4VCbURqQtonwB%2B8pddeqmuklWilO08xl8vrhl9T9m8GvverJeRthxQFnfc6qW4TWtItj21fKe3PSJKg1hgfcA41s%2F0v38NROVZhpUdAOvYKsyJoi2MOoyYMupaUy%2FZn8ocxJbAHpwrw8ixxwkMnJTn9l%2BHqJWp6TWItUu1nS8MrnlaMvomlkXcCjQ%3D%3D%7Ctkp%3ABk9SR7yP3oPeYQ
You can also get aftermarket speedos that use GPS.
MCN
PostPosted: 17:30 - 17 Mar 2023    Post subject: Reply with quote
Digital speedometer is the same as a cycle computer.
Set it up then corroborating using a phone GPS app.
Adjust to suit.
The last post was made 2 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 74 Kb
