2 Stroke 50cc (Aprilia) revs rising by itself
bcflogic
PostPosted: 14:53 - 02 Apr 2023    Post subject: 2 Stroke 50cc (Aprilia) revs rising by itself Reply with quote
2017 Aprilia SX50. Stock carb/jets *I believe*. Starts from cold 100%. Idles fine/revs fine. However, after approx 1 min, when a tweak of the throttle, the revs rise to almost max and stick. It's not a stuck throttle cable that I can see.
After a few seconds they come back down again and the bike will ride 100%. When the bike is then switched off/re-started 1 min later the EXACT same thing happens.
If it was an air leak, surely it would do it all the time? I can't understand why it does it once only after 1 min and then is fine again until the engine is stopped/restarted then happens again.
Any advice appreciated.
Robby
Dirty Old Man
PostPosted: 17:45 - 02 Apr 2023    Post subject: Reply with quote
If it only happens on a cold engine and at about the same time, I would be looking for a problem with the choke. I assume it may even have auto-choke, being a fairly new 50cc.
It's a 50 and it isn't brand new, so assume someone has fucked with it in a totally idiotic way.
Zen Dog
PostPosted: 15:51 - 03 Apr 2023    Post subject: Reply with quote
That is a weird one. If it was only when it was cold you might think it was a sticky carb slide that loosened up when warm or something, but every time even when warm? No idea.
Robby's suggestion seems like an avenue worth pursuing.
Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
bcflogic
PostPosted: 18:26 - 03 Apr 2023    Post subject: Reply with quote
It happens when warm too, every time. It has a manual choke. I think it's time to strip the carb.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:30 - 03 Apr 2023    Post subject: Reply with quote
Hmmm.
Is it incredibly rich or lean and is actually only just idling at what should be a high idle carb slide position and as soon as you touch the throttle it gets into a more efficient/effective fueling range and so accelerates upwards?
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 20:06 - 03 Apr 2023    Post subject: Reply with quote
Air leaks don't always behave like you want them to.
Check it all over. Something will be put in the wrong way round, a rubber will folded over or split, or a gasket split.
I once managed to cause an air leak by putting a carb spacer in the wrong way round. They're bastard things to track down.
bcflogic
PostPosted: 06:57 - 04 Apr 2023    Post subject: Reply with quote
Could be. I will whip the carb off and take a look.
dave001 This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 2 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 55.05 Kb
