Petrol
Adam_P
PostPosted: 21:01 - 11 Apr 2005    Post subject: Petrol Reply with quote
I've not yet looked at my Fazer's manual, which I'll do either tonight or in the morning. However, I was wondering if any of the engineers on here might be able to advise me on whether putting different octane fuel into it will cause any problems/damage?
I've been putting 95 RON in it recently, just because its been easier. But the local station does 98 RON SUper Unleaded too and I wasn't sure whether I'd need to do anything to the bike (timing etc) if I used a different rating.
I've got chance of using a little bit of 100 RON stuff from - ahem - a 'source' Whistle And was wondering whether that would be okay too?
I was hoping that Kickstart might be able to assist a numpty! Laughing
Thanks in advance folks.
Adam
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
Retro-Man
PostPosted: 21:11 - 11 Apr 2005    Post subject: Reply with quote
no problem in using the 98ron super unleaded at all
https://domharnessphotography.webs.com
R4nger
PostPosted: 21:17 - 11 Apr 2005    Post subject: Reply with quote
Normally UK bikes are not affected by this octane fuel above 95 because UK bikes are crappy or something I read from the forum so you are spending the extra money for nothing but it doesn't do any harm
PostPosted: 23:12 - 11 Apr 2005    Post subject: Reply with quote
Won't give you any advantage. Might loose you a tiny amount of fuel, but if it is a high lead aviation fuel then so not be surprised if it fouls the plugs.
JonB
Afraid of Mileage
PostPosted: 23:42 - 11 Apr 2005    Post subject: Reply with quote
Least you know it runs on petrol! Check sig. Laughing Sorry mate had to do it. Laughing
mattfuzzy
PostPosted: 23:47 - 11 Apr 2005    Post subject: Reply with quote
haha not funny jon Middle Finger Laughing Middle Finger
check my sig then! Twisted Evil haha
JonB
Afraid of Mileage
PostPosted: 23:48 - 11 Apr 2005    Post subject: Reply with quote
I NEVER said that!!! Embarassed
mattfuzzy
PostPosted: 23:50 - 11 Apr 2005    Post subject: Reply with quote
haha in that case
I NEVER SAID THAT! Embarassed
mchaggis
PostPosted: 02:55 - 12 Apr 2005    Post subject: Reply with quote
There shouldn't be any problems going up RONs, so long as it is still more or less the same fuel (unleaded). Whether you actually get any benefits from doing so without modifying the engine to take advantage of it is open to debate. The problems occur when you go down the RON scale, as the fuel burns more easily and using a lower octane fuel will cause more knocking and pre-ignition, which will destroy your little end bearings and increase wear on the bore, let alone the overheating issues.
The reason for the advanced wear and destruction of bearings is the shock waves from the pre-ignition explosions (explosion rather than a normal semi-controlled burn) drives the oil from the little end bearings and blows the oil off the bore of the cylinder. Loss of lubrication = overheating and rapid wear.
I must not be a troll...
Mmmm, Guinness
Pat172
PostPosted: 03:33 - 12 Apr 2005    Post subject: Reply with quote
exactly what mchaggis said above
the higher the RON the slower it burns
if you just stick with standard 95-98 ron you'll have no problem at all
on a highly tuned engine with modified compression you'll want to bump up the RON as McHaggis said which is why some people use additices to their fuels etc.
but anythigng from 95 to 98 (optimax, bp ultimate etc) is fine Wink Thumbs Up
- Suzuki Bandit N600
dotti
PostPosted: 04:35 - 12 Apr 2005    Post subject: Reply with quote
The only problem I ever had using higher octane fuels was that it made the bike backfire very regularly, when I used 97 octane fuel. I can only guess that this would be due to the exhaust ports opening while some fuel was still unburnt. When I went back to regular 91 octane the problem went away again.
Edit:
I don't know what Octane range you have over there, but here we have 91, 95 and 97/98 to choose from.
Dangerous traffic offences spotted on 50-minute trip: Lost count after 100. Number of traffic cops spotted: One, sitting by a speed-trap camera
Robby
Dirty Old Man
PostPosted: 08:56 - 12 Apr 2005    Post subject: Reply with quote
Stick to normal unleaded. Your engine won't take advantage of the higher octane stuff.
As for the 100 RON, I assume its a leaded race fuel. As keith said, a highly leaded fuel can foul the plugs. If your fazer has a catalytic converter the lead will take out your cat as well.
Adam_P
PostPosted: 10:45 - 12 Apr 2005    Post subject: Reply with quote
It is race fuel, but I'm fairly certain its unleaded. (But I might be wrong on that). I'd only be using a small amount of it if I was going to anyway as we'd use it for trackdays and I'd get a sample while there.
So, from what I can gather, 95 and 98 RON from the local pumps are fine, but anything over that, it ought to be set up to make sure damage doesn't occur?
Thanks folks.
God is imaginary
PostPosted: 14:27 - 12 Apr 2005    Post subject: Reply with quote
robby wrote:
Stick to normal unleaded. Your engine won't take advantagIt is race fuel, but I'm fairly certain its unleaded. (But I might be wrong on that). I'd only be using a small amount of it if I was going to anyway as we'd use it for trackdays and I'd get a sample while there.
If it has a cat even a tiny bit of lead will kill it. You will get no advantage at all from an increased octane rating and are likely to get a reduction in power if it is slower burning.
Suspect the Fazer is designed to run on 91 RON fuel.
The last post was made 21 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 84.46 Kb
