A quick question for a vet...
Easy-X
PostPosted: 10:38 - 15 Apr 2023    Post subject: A quick question for a vet... Reply with quote
So some people were asked how much CO2 is in the atmosphere. 5% ? 7% ? 8% ? Wow... okay Shocked
I know from beer cellars you don't need much to fall asleep and wake up dead Sad Only ~1% CO2 in the atmosphere to start feeling the ill effects and of course if there's a canister leak that percentage will only go up. (Thankfully outside at sea level the concentration is a tiny 0.04%)
Anyhoo, 1% is the number for the average human but how are animals affected? Is that a universal number for mammals or would something like a rat tolerate more or less CO2 in the atmosphere?
Paging Mr. Stinkwheel Smile
Nobby the Bastard
Harley Gaydar
PostPosted: 11:02 - 15 Apr 2023    Post subject: Reply with quote
If 1% CO2 is lethal, how does mouth to mouth work where what you are exhaling is about 4-5% CO2?
Triumph Sprint ST 1050
Grizly
PostPosted: 11:24 - 15 Apr 2023    Post subject: Scuba diving Reply with quote
I used to be a scuba diver and we were always concerned with our air purity and how our bodies worked.
We can tolerate higher levels of other gasses for a short time.
We turn oxygen into CO2 and it's that (at about 5%) which triggers our desire to breathe and why hyperventilating before free diving is a bad idea.
The 5% exhaled into another non breathing person will help them with starting breathing again.
Wohoo!
Nobby the Bastard
Harley Gaydar
PostPosted: 11:59 - 15 Apr 2023    Post subject: Reply with quote
Surely if you aren't breathing your lungs would be saturated with a much higher percentage of CO2 than the 5% in exhaled air.
Easy-X
PostPosted: 12:37 - 15 Apr 2023    Post subject: Reply with quote
Where did you get the idea 1% is lethal?
PostPosted: 12:38 - 15 Apr 2023    Post subject: Reply with quote
As above, increased Carbon dioxide concentration triggers normal breathing so the 1% you're talking about in an enclosed space will make you feel breathless, maybe sleepy. (remember, the exhaled CO2 will add to the envoronmental levels in your lungs). Not toxic so it would take prolonged exposure to kill you but not something you'd want to be working in
As I recall, over 5% is distincltly unpleasant and will cause all sorts of symptoms, around 9% is toxic and can cause rapid unconciouslness then death. Over 30% is rapidly fatal but acts more like an anesthetic.
As Grizly correctly says, in my field during anaesthetics, there are probably more issues with not enough CO2 because over-ventilation drops the concentration which reduces the automatic breathing responses. You can land up with a patient being hypoxic (not enough oxygen) but also hypocapnic (not enough CO2) and not spontaneously breathing. This isn't a huge problem, it's why we have them intubated and bagged. While hypoxia will eventually trigger rescue breathing, it's not good enough.
There was a fashion for adding some CO2 to the gas mix to stimulate breathing but it's tricky to monitor and geting it wrong can have severe consequences, what we do more often now is monitor them for oxygen saturation and only give extra breaths when this drops below an acceptable level.
I think most mammals are of a similar tolerance to humans. Birds are much less tolerant of poor air quality (think canaries in mines). Not sure exactly why but avian lungs are ridgid and mechanically ventilated by air sacks drawing air back and forwards through them and they have different blood cell structure. The smaller the animal, the more rapid the metabolic rate so I'd expect smaller mammals to get in trouble more quickly but the trouble to happen at similar concentrations. Whales and diving mammals have some weird mechanism for dealing with CO2 I don't really know much about.
Easy-X
PostPosted: 12:50 - 15 Apr 2023    Post subject: Reply with quote
Just a random thought, whether there were more or less rats in beer cellars 'cos of the CO2 Smile Thanks, Mr. Stinkwheel!
PostPosted: 14:09 - 15 Apr 2023    Post subject: Reply with quote
They use high concentrations of CO2 to kill rats for feeding to pet reptiles. Same with pigs, that's why the recent CO2 shortages caused a shortage of bacon.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:33 - 15 Apr 2023    Post subject: Reply with quote
Point 9f order. My father who was a butcher said everything sold as bacon is actually salt pork and not bacon because it isn't cured correctly.
PostPosted: 14:38 - 15 Apr 2023    Post subject: Reply with quote
Both are still made from dead pig though.
MCN
PostPosted: 19:33 - 15 Apr 2023    Post subject: Reply with quote
Humans breath 21% Oxygen at sea level 14.5 PSI.
CPR involves pushing exhaled breath into a non-breathing human.
Exhaled human breath contains 17% oxygen which is sufficient to 'sustain' a human life.
I did some training with ANSUL fire equipment.
During the training it was mentioned that a CO2 fire extinguisher can assist those trapped in a fire. The increases CO2 stimulates deep breathing which will pull in more oxygen.
The studies on this effect are a bit vague though.
Theoretically substantial but probably not worth the fuss in real life.
PostPosted: 20:01 - 15 Apr 2023    Post subject: Reply with quote
Best use for a fire extinguisher in a fire is to break down a door or smash a window so you can get out.
PostPosted: 20:30 - 15 Apr 2023    Post subject: Reply with quote
Rats are known for their ability to tolerate a wide range of environmental conditions, including high levels of CO2. Rats have a high tolerance for CO2 because they have a more efficient respiratory system than humans.
The respiratory system of rats is more efficient than that of humans because rats have a higher respiratory rate and a larger lung capacity relative to their body size. This means that rats can inhale and exhale more air per unit of time than humans, allowing them to eliminate CO2 from their bodies more efficiently.
In addition, rats have a higher concentration of carbonic anhydrase, an enzyme that helps to regulate the pH of the blood by converting CO2 into bicarbonate ions. This means that rats can more effectively regulate their blood pH in the presence of high levels of CO2
RhynoCZ
PostPosted: 20:44 - 15 Apr 2023    Post subject: Reply with quote
Does it work? I thought the consensus was not to do the mouth-to-mouth, as it's ineffective, and it makes much more sense to do the chest compressions to keep the blood circulating. Thinking
That being said, drop the ''2'' and you get much more lethal gas, the carbon monoxide. Oddly enough this lethal gas also has got its health benefits in very, very small doses.
PostPosted: 22:07 - 15 Apr 2023    Post subject: Reply with quote
Two reasons. One was people are understandably reluctant to do mouth to mouth on a stranger in a day and age where people can and have contracted hepatitis from giving first aid. Putting out a message to do compressions only encourages them to do something. Also to keeping it simple, people get confused about if they should do breaths, how many etc. the compressions are more important.
Breaths help with effective resuccitation so give them if you feel you can but chest compressions are most important, that's what circulates the oxygen. Even a defibrullator or adrenaline is a waste of time if your heart has stopped without the compressions. You need a good 2 minutes of effective chest compressions for stopped cardiac muscle cells to have recovered sufficiently to start beating again. Open an AED and the first thing it'll do is tell you is to start doing chest compressions.
Last time I did CPR on a human at an RTA, I didn't do breaths because frankly, there was a lot of blood about and it was a total stranger. I did do chest compression in shifts with an off duty police officer for a good 10-15 minutes before a competent paramedic crew arrived. He died in the end, but he was alive enough to be airlifted to hospital and have his family make a decision about organ donation.
MCN
PostPosted: 22:18 - 15 Apr 2023    Post subject: Reply with quote
CPR and Rescue Breaths.
30 compressions of at least 2 inches over the heart area between the nipples.
Then two rescue breaths, where a perceivable movement of the chest can be seen.
Blowing too hard can push air into the stomach and create resistance to rescue breaths.
Repeat until exhausted or until Medical help gets there.
The compressions do not create much heart activity but the speed and repeated cycles can help keep a brain alive.
PostPosted: 00:15 - 16 Apr 2023    Post subject: Reply with quote
The trouble is that by the time it's stopped beating, the cardiac muscle is exhausted and hypoxic. Given enough time to recover and oxygen, they can start beating again spontaneously, or an intervention like shocking a fibrullating rythm, giving drugs or even a precordial thump can kick-start them. The compressions are also supplying the heart itself with oxygen. Drugs and defibrulation will do nothing unless you've done this first. Drugs wont even get there unless you pump them round.
TV doesn't help. When you treat an arrest, you don't stand around watching to see if your intervention has worked. You do compressions for 2 minutes, pause briefly to see if there is any sort of rythm you can shock or give drugs to. If there is you administer this and immediately start another 2 minute cycle then stop again briefly to see if it worked or if you should try another intervention.
It helps to think of the heart as a pump and the compressions are manually working the pump until the power comes back on.
Or until your patient shows signs of recovery, such as breathing.
There is also a good argument for not fucking about trying to find a pulse. If your patient is unconcious and not breathing start CPR. You are highly unlikely to stop a heart by giving CPR whereas the swithering about trying to decide if anyone thinks they can feel a pulse can mean the difference between life and death.
Freddyfruitba...
PostPosted: 16:24 - 16 Apr 2023    Post subject: Reply with quote
stinkwheel wrote:
Two reasons.
Isn't a third reason the fact that administering CPR is apparently absolutely exhausting (correct?) and that in order for it to be kept going long enough until the emergency services arrive to take over, it makes more sense to be realistic about what can be achieved. I don't think there's much doubt that if you have adequate motivated and trained volunteers, the optimum is to use mouth-to-mouth as well.
PostPosted: 18:54 - 16 Apr 2023    Post subject: Reply with quote
This is true. When I was in the TA they made us take turns at keeping a recusci-Annie going for half an hour solo (and they have a monitor in it to check your breaths and compressions are effective). Pretty much fit to drop by that point.
Equally, when doing it on a real person, there is a sizeable adrenaline dump that comes into play.
Tierbirdy
PostPosted: 14:43 - 18 Apr 2023    Post subject: Reply with quote
Mouth to mouth is fucking gross and no way Id do it Razz Even on a loved one I'd probably think twice.
Generally when someone "dies" the first thing to go is all their muscles relax and the sphincter stopping all your stomach contents going back up your throat opens up and as a result you get a lovely liquid cocktail coming out the mouth that smells like a 3 day old Big Mac. Plus maybe add in a bit of foamy bubbly blood too if people have actually been doing effective CPR rather than gently massaging the chest. I dont think I've ever seen a member of the public giving anything even vaguely resembling effective CPR, so confusing them even further by getting them to try and give mouth to mouth as well is just too much.
Which just means basic first aid and general self care should be mandatory learning at school.
MCN
PostPosted: 10:03 - 20 Apr 2023    Post subject: Reply with quote
CPR does help.
And the idea that its better to do something in this case means a lot.
It might not be the stats you accept as worthy of your efforts but if it helps 1 out of 10 people then is 100% effective for that 10%
"1. CPR Saves Lives.
Currently, about 9 in 10 people who have cardiac arrest outside the hospital die.2 But CPR can help improve those odds. If it is performed in the first few minutes of cardiac arrest, CPR can double or triple a person’s chance of survival.2"
A lot of 'bad press' is probably due to not enough people being trained in CPR.
There are a lot of things most folk do not know.
to v or not to v
PostPosted: 20:20 - 20 Apr 2023    Post subject: Reply with quote
apparently doing cpr properly can result in broken bones for the patient.
most people arent aware just how much pressure is needed to perform it properly.
Moto Guzzi V7.
PostPosted: 20:47 - 20 Apr 2023    Post subject: Reply with quote
Yes, if you're doing it properly, you've got a good chance of popping some ribs. Which they won't be needing if they're dead.
A good way of looking at it is that if their heart has stopped beating, the person is dead. The situation can only possibly improve from that point so you should have a go.
MCN
PostPosted: 00:46 - 21 Apr 2023    Post subject: Reply with quote
Medical term for that:
You can't make an omelette without breaking eggs.
(Or was that Can't Cook Won't Cook?)
Ribenapigeon
PostPosted: 17:18 - 30 Apr 2023    Post subject: Reply with quote
Best CPR training I received was from a retired A&E nurse. I was amazed at just how much force she was getting us to administer to the Annie. None of that kneel by the subject and press hard stuff but almost jumping using the weight of your body. Im pretty sure if given properly the subject is going to be very sore and no suprise if ribs are cracked. Ive never given CPR but been present once and its nightmarishly stressful. The guy didn't live (heroin overdose) and my colleague giving the CPR was knackered and for weeks afterwards was having flashbacks and a lot of difficult thoughts.
The last post was made 3 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 140 Kb
