| Samon_x |
 Samon_x L Plate Warrior
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 13:53 - 16 Apr 2023 Post subject: |
Fowlers £325 for pukka Yammie one
or Ebay £48 for an oriental alternative with all the bits and bobs
https://www.ebay.co.uk/itm/324009260171? ____________________ bikers smell of wee |
| MCN |
 MCN Super Spammer
 Posted: 16:16 - 16 Apr 2023 Post subject: |
Would that include any of the odds and sods too?
(Asking for a friend.) ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
 Posted: 16:31 - 16 Apr 2023 Post subject: |
Interesting, that looks like an entirely different design to the admittedly grainy Fowlers’ fiche. Would it occupy the same space and brackets? Wemoto sell ‘em too. |
| stinkwheel |
 Posted: 17:50 - 16 Apr 2023 Post subject: |
If it was me, for that kind of money, I'd probably make up a fuel pump delete plate on the tank with a spigot and re-plumb it to run an external facet solid state pump. Maybe with a small car cartridge fuel filter if I could find somewhere to put it. Probably looking at around £100-150 to do all that and it would never need looking at again. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
| Samon_x |
| Nobby the Bastard |
| Samon_x |
| WD Forte |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 15:47 - 17 Apr 2023 Post subject: |
Afternoon chaps.
I'm Samon's brother, I've been trying to help remotely by phone as I live miles away.
The last message was a copypaste of mine, apologies for lack of clarity.
He confirmed that the brown wire terminal at the pump (ignition switched live) was getting power, 12.5v to ground with the ignition on. Other components on this circuit such as lights/horn etc also function.
He attempted to check continuity across the yellow wire (pump connector neg to ECU) but I think this was difficult as the ECU plug connector block has infinitesimally small connections that didn't fit a probe (but samon can confirm).
He grounded the yellow wire at the pump connector to neg on the battery using a separate cable. He showed there was now 12.5v between brown and yellow at the pump connector block with a multimeter. The pump did not prime during this.
Cheers,
Donny
P.S. long time no see!
EDIT: the wiring diagram I'm using:
https://imgur.com/rNS7SKE |
| Nobby the Bastard |
| DrDonnyBrago |
| Nobby the Bastard |
| Nobby the Bastard |
| WD Forte |
| Samon_x |
| WD Forte |
| DrDonnyBrago |
| WD Forte |
 Posted: 09:35 - 18 Apr 2023 Post subject: |
Yes and no.
Let's say we have an AOK YBR pump all connected up but we power it directly from a battery.
It should do the same as it does normally.
Start, run briefly then stop as it has an internal pressure switch/regulator
If it was free standing and not plumbed in it would run continuously
as it would never build enough pressure to trip the regulator switch.
My moneys on a bad pump because I don't think they hold pressure that long after power down.
If it doesn't run directly from a battery, I'd whip out and examine it closely before spending.
I'd check the pressure switch hasn't got stuck and the motor
still wont run with a direct feed to the terminals
(not via the pressure switch.)
I linked a motor filter kit before but you can get the whole
aftermarket assembly for £70 ish
https://www.ebay.co.uk/itm/304511331880? ____________________ bikers smell of wee |
| DrDonnyBrago |
| DrDonnyBrago |
| Nobby the Bastard |
| Kawasaki Jimbo |
The last post was made 2 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
