 WalkeruK88 Nova Slayer
 mr.z World Chat Champion
 Posted: 22:45 - 11 Apr 2005 Post subject: |
Hmm a weird one that... if it were electrical then you'd be expecting wet plugs???
Is the carb actually getting the fuel in? perhaps the float is not working properly stuck probably, starveing it of fuel... (try taping it firmly before starting)
What i'd do is take everything from the tank to the carb off, check it and clean it untill something turned up... check the carb settings as well, also for air leaks as they dont help starting...
Does the bike run ok once its started? if so it might be electrical/knacklered leads perhaps...
Good luck getting it going though, kickstsrtds are all big and clever till something goes wrong  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
