New battery for a Kawasaki ER-6N
sapstar
PostPosted: 12:27 - 20 Apr 2023    Post subject: New battery for a Kawasaki ER-6N Reply with quote
I am looking for a new battery for ER-6N 2015. I see that I need a YTX12-BS or YTX14-BS.
On my searches, I get mostly AGM batteries. Is this the right battery technology for this bike?
Is Powerline battery from Tayna batteries any good? Or should I go for Varta which is my go to choice for my car.
Went through kawasaki parts finder and it says the battery I should get is the below one. Bit confused now as with my REG I get different recommendations.
26012-0999 BATTERY,YT12A-BS,12V
First/Current Bike - Kawasaki ER-6N
sapstar
PostPosted: 14:00 - 20 Apr 2023    Post subject: Reply with quote
Just pulled the battery out and it's a YT12A-BS and it isn't an AGM battery. Is this a safe upgrade?
Evil Hans
PostPosted: 14:10 - 20 Apr 2023    Post subject: Reply with quote
Shouldn't be any problem with installing an AGM battery. Only downside is that they are usually a bit pricier than the equivalent standard LA.
(Unless you have a clunky old unregulated charger)
Easy-X
PostPosted: 14:15 - 20 Apr 2023    Post subject: Reply with quote
I went for an AGM on my XSR and it seems to like it.
PostPosted: 14:39 - 20 Apr 2023    Post subject: Reply with quote
I have them on all my bikes. The powerline ones seem fine.
sapstar
PostPosted: 16:26 - 20 Apr 2023    Post subject: Reply with quote
Thanks for all the advise. I went with a Motobatt battery. The powerline one has lower Ah and CCA compared to the Original Yuasa and Motobatt. I have added more electrical stuff to my bike like heated grips, phone charger, heated gloves etc. So didn't want to go for lower Ah.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:29 - 20 Apr 2023    Post subject: Reply with quote
Amp hours are for starting. You really shouldn't exceed the capability of the charging system and rely only on your battery to power accessories....
sapstar
PostPosted: 21:04 - 20 Apr 2023    Post subject: Reply with quote
I thought CCA (Cold Cranking Amps) was for starting and Ah is the total power draw of the devices connected in general.
My current Yuasa battery is 10.5Ah so is the new one, so not exceeding. In terms of CCA, Yuasa was 175 and motobatt is 160. I guess this is OK too.
sapstar
PostPosted: 21:07 - 20 Apr 2023    Post subject: Reply with quote
Also have another question regarding trickle charging the battery with a maintainer. My battery charger has a "Small 12V Battery" mode which I used with the old battery. It also has an "AGM" mode. What should I be using to charge this new battery?
MCN
PostPosted: 22:39 - 20 Apr 2023    Post subject: Reply with quote
I was going to suggest Motobatt.
I have in the litre bike and in the 1300. No problemo.
Both Yuasa batteries fitted to the litre bike failed miserably after two years.
So I now only use Motobatt.
MCN
PostPosted: 22:41 - 20 Apr 2023    Post subject: Reply with quote
Get yourself a Ctek. And use the other for back-up.
https://www.ctek.com/uk/battery-chargers-12v-24v/vehicle-type/motorcycle/battery-maintainer
sapstar
PostPosted: 03:10 - 21 Apr 2023    Post subject: Reply with quote
Don't want to invest in another charger at the moment. I have this one.
https://amzn.eu/d/1gaXbMe
Nobby the Bastard
Harley Gaydar
PostPosted: 07:55 - 21 Apr 2023    Post subject: Reply with quote
Regardless of the AH of the battery you have, if your accessories use more power than you charging system can provide you will end up with a flat battery.
grr666
PostPosted: 07:56 - 21 Apr 2023    Post subject: Reply with quote
I like that some of their batteries have places to bolt in a second set of terminals. Handy for accessories.
Islander
PostPosted: 10:26 - 21 Apr 2023    Post subject: Reply with quote
The AH rating gives the energy capacity and discharge rate of the battery. CCA gives the maximum current output for short (starting) bursts.
You're fine if you've chosen an identical or higher AH figure than the original just don't go lower.
If your charger has an AGM mode then it's probably a good idea to use that although most don't distinguish between lead acid/gel/agm types and they seem to do well on standard charging and maintenance profiles.
PostPosted: 11:50 - 21 Apr 2023    Post subject: Reply with quote
I've always thought the "You must use special charger because AGM" thing was a bit of an odd one. I can't think of a more lacklusture way of charging a battery than by connecting it to a motorcycle alternator. Dirty overlapping halfwaves with constantly fluctuating voltages.
jeffyjeff
PostPosted: 18:07 - 21 Apr 2023    Post subject: Reply with quote
I can: old school single phase charging systems. Halfwaves that pulse 0-peak with a constantly fluctuating wavelength. At least the 3 phase voltages never drop to zero, and the fluctuations in voltage are constrained in a window that always hovers above full-charge battery voltage.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:28 - 21 Apr 2023    Post subject: Reply with quote
Isn't that what the regulator does?
MCN
PostPosted: 20:29 - 21 Apr 2023    Post subject: Reply with quote
Regulator controls the generator output.
https://www.google.com/search?q=12v+alternator+regulator&rlz=1C1ONGR_enGB1025GB1025&oq=12v+alt&aqs=chrome.2.69i57j0i512l9.11174j0j9&sourceid=chrome&ie=UTF-8#kpvalbx=_y-9CZPOcCMnaxc8PwaWvwAg_37
Rectifier controls current polarity/s
A semi-conductor (diode) allows half the wave to pass.
Coupling with a capacitor might smooth that.
And then connecting one to each phase could produce a smooth wave.
https://en.wikipedia.org/wiki/Rectifier
I think automotive application the regulator and rectifier are housed in the same block.
(Big alternators use AVRs, another thread.)
Islander
PostPosted: 21:35 - 21 Apr 2023    Post subject: Reply with quote
A simplified view is that the rectifier turns the AC output of the alternator into DC. The regulator controls and limits (regulates) the output voltage. Smoothing is provided by the battery itself.
Easy-X
PostPosted: 21:40 - 21 Apr 2023    Post subject: Reply with quote
AGM batteries optimally require a higher charging voltage (~14.6V) vs. old skool Lead-Acid (~13.8V) so if you don't have an AGM mode on your charger it just won't charge AGM batteries to their full capacity. AFAIK undercharging batteries a little won't do them any harm.
Robby
Dirty Old Man
PostPosted: 08:43 - 22 Apr 2023    Post subject: Reply with quote
Use the small battery setting.
That charger can output 4A. Motorcycle battery chargers generally output around 1A. 4A is too much for a ~10-14Ah battery. As a rule of thumb, you want to charge at 20% of the capacity or less.
It's also easy to overthink all of this, and chargers like that make it easy to get paranoid. A motobatt holds onto its charge very well and is typically supplied fully charged, so you could just fit it and forget it.
Traditionally, lead-acid batteries were supplied with the acid separate, or had sat on a shelf in a shop gently discharging for ages. They needed to be fully charged before use, for 6-10 hours. If you fitted a bike battery with a 50% charge, it would take several hours of riding for the bike to charge it up. That's bad for all kinds of reasons.
Don't overtighten the terminals. Use the crappy little allen key that comes with the battery, it will bend before overtightening.
sapstar
PostPosted: 10:12 - 22 Apr 2023    Post subject: Reply with quote
The charger does have a small battery setting which I think is 2A. So should work out under 20% of 10.5A.
Just fitted the motobatt and the bike came back to life. Also the battery came 100% charged.
sickpup
Old Timer
PostPosted: 09:04 - 24 Apr 2023    Post subject: Reply with quote
I'd disagree with this. Most lead acid batteries used to have a label on them saying a 10% charge rate was preferred.
The last post was made 2 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 123.43 Kb
