| zippot69 |
 zippot69 L Plate Warrior
| dave001 |
 dave001 Banned
| stinkwheel |
 Posted: 18:54 - 05 May 2023 Post subject: |
Surprising how well it'll come up with wire wool and WD40.
If it's very far gone, painting it black is an option although paint doesn't key well to chrome. If it's just for a bit of a tart up, I'd suggest cleaning the rust off (wire wool and elbow grease or a 12-24h soak in white vinegar and a wash off), scratching the surface of the chrome with some aluminium oxide paper to help the paint key followed by a thorough clean, degrease and dry. I've had pretty good success using plastikote BBQ paint which gives a very forgiving satin black finish. You need to let it dry once applied then bake it on in an oven. Be warned, it'll stink the place out.
That said, you're talking about a 1980's CM125 so the chrome in question will be the mudguards and exhaust yeah? They've usually rotted through from the inside in my experience, usually at the highest point of the mudguards (bulging the chrome up between the forks) and lowest point of the exhaust. Nothing short of replacing them will sort that. You may well find a pair of pattern universal mudguards aren't all that expensive ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 A100man World Chat Champion
 Posted: 19:07 - 05 May 2023 Post subject: |
If not yet rotten as described by Stinkwheel, I'd wire brush them (mudguards) on the inside to within and inch of their life then underseal.. om top side silver hammerite sprayed on top of a well prepped surface usually looks OK. Did this with my A100 several years ago and it still look fine. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| MCN |
 MCN Super Spammer
| WD Forte |
 WD Forte World Chat Champion
 Posted: 00:36 - 06 May 2023 Post subject: |
So,
Basically, first bike and you've bought a 41 year old non running 125
Hope you got it cheap and didn't fall for the 'classic innit mate' crap.
Its not classic its old.
With no licence it's at a new hobby stage whicb may or may not develop further.
Never mind the mudguard that's easy and relatively cheap to sort out.
"Chrome don't get you home" and all that.
Take a close look at the swinging arm, fork stanchions, spokes and inside the tank, plus the seat pan which I suspect may be pressed steel.
Corrosion here will be a longer more expensive job than tarting up a mudguard.
You also need to know if it will wake up or not.
its a CM125C not a 125cm
Don't spend any more money on it right now other than a few quid on some wd40 acf50 etc and cleaning products
Do some initial cleaning and de-greasing and de-rusting, this will help you see what you've got.
Take lots of good quality pics for reference and if you want to share online.
Heres Fowlers parts page for that bike, note many parts are NLA
but its a good place to get a refence to part numbers and what goes where and stuff.
https://www.fowlersparts.co.uk/browser/manufacturer/honda/bike/cm125c/year/1982/country/england/colour/all-colours ____________________ bikers smell of wee |
| Bhud |
 Bhud World Chat Champion
| Bhud |
| Robby |
 Robby Dirty Old Man
| zippot69 |
| jeffyjeff |
 jeffyjeff World Chat Champion
| stinkwheel |
 Posted: 19:40 - 06 May 2023 Post subject: |
Car oil is fine but I'd use 10w-40. As above, if it's 12v, a car battery will be fine to crank it over and for short engine runs. Don't leave it on for long runs because it'll put a lot of load on the charging system trying to fully charge it and will burn out the alternator.
If you're changing the oil, on an unknown little twin of that era, I'd clean the oil filter screen first. You have to remove the side cover to get at it, it's often neglected.
From your description, I'd say cosmetics are the last thing you need to be dealing with so spray over the rusty chrome with WD40 and leave it until you have a working motorcycle. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bhud |
| Robby |
 Robby Dirty Old Man
| zippot69 |
 Posted: 11:20 - 07 May 2023 Post subject: What options for chrome |
file:///C:/Users/david/Downloads/IMG_20230430_155853_resized_20230507_110829310.jpg
trying to post a photo but cant find how too
I wont overspend on anything may try and adapt a centre stand rather than make new.
Trying to find my reg number to fill in the v62 for for a v5 anyone got any advice. I think its get a dealer to do a credit check or mot it when its finished but not sure. ____________________ were ,here for a good time not a long time.
Old age is an honour not granted to everyone |
| stinkwheel |
| zippot69 |
| WD Forte |
| stinkwheel |
| Easy-X |
 Easy-X Super Spammer
 Posted: 17:09 - 07 May 2023 Post subject: |
I use imgur but the various photo sites are much the same.
Post a photo and go to the "..." menu in the top right of your photo (it's a hidden button that appears as you hover over the picture) pick "get share links" and copy out the BBCode one, for example:
| Code: | | [img]https://i.imgur.com/uJra5vl.jpg?1[/img] |
Paste the text straight into your post:
https://i.imgur.com/uJra5vl.jpg?1 ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
 Posted: 17:40 - 07 May 2023 Post subject: |
If it comes out like this you're doiing it wrong.
https://www.bikechatforums.com/download.php?id=103219 ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
The last post was made 3 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
