| legroscalis |
 legroscalis L Plate Warrior
 Posted: 02:04 - 10 May 2023 Post subject: Timing adjustment PGO BIG max 50 2007 |
Hi everyone, so I just did a bottom end rebuild on my 2008 PGO BIG max 50 and I realise that I messed up the timing when putting it back together so now it wont start. I know i need to adjust the timing to 17 degrees but I dont know whats the equivalent in mm so that i can adjust it with a Dial Indicator Gauge. Do you guys have any ideas on how to get the measurement I'm looking for?
Thanks  |
| WD Forte |
 WD Forte World Chat Champion
| legroscalis |
| WD Forte |
| legroscalis |
| Robby |
 Robby Dirty Old Man
| legroscalis |
| WD Forte |
| legroscalis |
| WD Forte |
| legroscalis |
| stinkwheel |
| Robby |
 Robby Dirty Old Man
 Posted: 10:17 - 11 May 2023 Post subject: |
Also worth mentioning that this looks like a classic case of fixating on the thing you don't understand. It was very common with teenagers trying to do diagnosis and always blaming the CDI, because it was the inscrutable black box of magic. The problem was never the CDI, it was them fucking something up.
So, fault finding from the top:
Spark, fuel, compression.
You mentioned the spark plug working, so I assume you have a spark. You're assuming this spark is happening at the wrong time. Follow Stinkwheel's advice there to find out if the rotor is in the correct position. If it is, we can assume that spark is not the problem.
Fuel. You mentioned a new carb. Is it the right carb, and does it have the right jets, needle height and other settings? Alternatively, do you still have the old carb and can you try that.
Fuel mix - it's a 2 stroke. I don't know if you're running pre mix or retaining the autolube system, but it needs to have the right amount of 2 stroke oil.
Compression. You've rebuilt the bottom end. I assume you rebuilt the top end too. Worth doing a compression test. If it's your first rebuild, you probably fucked it up somewhere.
For a simple diagnostic test, spray something flammable down the carb throat and try to start it. It should at least cough if things are anywhere near running. |
| WD Forte |
| legroscalis |
| stinkwheel |
The last post was made 3 years, 54 days ago. Instead of replying here, would creating a new thread be more useful? |
