| Pothole |
 Pothole Two Stroke Sniffer
 Posted: 16:30 - 02 May 2023 Post subject: Does this cylinder look ok |
Guys, having sorted the Electric start on my Daughters 2011 jog 50cc when it tries to turn over it sounds like a bag of bolts. New battery new starter and starter relay. Fired up first time but doesn’t fire up any more. Pulled the cylinder head off this afternoon to inspect. It’s all smooth no scoring from what I can feel. Does it look ok to you lot
https://imagizer.imageshack.com/v2/150x100q70/924/fsEwl4.jpg |
| MCN |
 MCN Super Spammer
| Pothole |
| Nobby the Bastard |
| Pothole |
| Easy-X |
 Easy-X Super Spammer
 Posted: 19:42 - 02 May 2023 Post subject: |
That cylinder has had it. The piston will need changing too so buy a pair, and new gaskets. ____________________ a.k.a 'Geri'
| A100man |
 A100man World Chat Champion
 Posted: 20:10 - 02 May 2023 Post subject: |
The marks must mean something even if it's not scored enough to catch a nail. I'd take the cylinder off too so we can view the piston. BUT that isn't what is making ists oiund like a 'bag of bolts' so I suspect something else is at fault. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
 Posted: 22:25 - 02 May 2023 Post subject: |
I think that barrel needs to be pulled so you can inspect the piston and see if there is any play on the big end or small end. Piston has definately been rubbing on the bore.
Also worth checking for vertical play on the main bearings.
If we're placing bets, I'd guess repeated partial seizures and a fucked small end. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 Posted: 11:00 - 03 May 2023 Post subject: |
| stinkwheel wrote: |
If we're placing bets, I'd guess repeated partial seizures and a fucked small end. |
| Pothole |
| Pothole |
| Easy-X |
 Posted: 18:27 - 12 May 2023 Post subject: |
Sorry, how are you figuring out one has a feed and the other not, wet plug? Will the bike go with a little Ez-Start?
If the carb is just part of a cheap Chinese kit you'll want to pop the float bowl off and check the float can move up and down freely. The thing's probably spent most its life jiggled about in air freight  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Pothole |
| Easy-X |
| WD Forte |
 WD Forte World Chat Champion
| Pothole |
| Robby |
 Robby Dirty Old Man
| Pothole |
| A100man |
 Posted: 08:30 - 14 May 2023 Post subject: |
| Pothole wrote: | No this one looks different. The original had and inlet and outlet for the coolant which I believe is for the choke. The new one doesn’t
Checked the float and it’s moving freely |
Put the old one back on..
it should at least run so you can hear how the motor now sounds. It may even restrict the moped to legal moped speed and keep the Fuzz form discovering your misdemeanour. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| B1N |
 B1N Scooby Slapper
The last post was made 3 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
