Adding Switched USB Port
RAYK47
PostPosted: 12:06 - 15 May 2023    Post subject: Adding Switched USB Port Reply with quote
Hi all
What is the best and simplest way to add the USB port to my bike (2015 Street Triple R) as I am going to IOM in a couple of weeks and will need a good source of power for SatNav on my phone.
I have an Ultimate addons USB socket but I don't want to wire it directly to my battery (mainly as it has a blue LED that is always on and i don't want it to drain the battery).
I am not the most handy person so I need a simple fix, I don't want to be having to splice into wires for example as I will mess it up.
any help will be greatly appreciated.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:17 - 15 May 2023    Post subject: Reply with quote
Is your headlight on all the time? Take a feed from there.
Triumph Sprint ST 1050
PostPosted: 12:28 - 15 May 2023    Post subject: Reply with quote
https://www.amazon.co.uk/Motorcycle-Electric-Charger-Switch-Adapter-Black/dp/B07G1682CT/ref=asc_df_B07G1682CT/?tag=googshopuk-21&linkCode=df0&hvadid=311081482938&hvpos=&hvnetw=g&hvrand=10675132327548295690&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006501&hvtargid=pla-566261876824&psc=1
PostPosted: 13:07 - 15 May 2023    Post subject: Reply with quote
Simplest? Get one with an actual on/off switch, wire it to the battery and turn it off when you're finished with it.
EDIT: As linked to above.
RAYK47
PostPosted: 13:16 - 15 May 2023    Post subject: Reply with quote
Thanks gents
seems the simplest option, as i had a UA one already i was hoping not to have to buy another one.
rpsmith79
PostPosted: 16:25 - 15 May 2023    Post subject: Reply with quote
I just recently fitted an Optimate USB charger to my Striple
Costs little more than the above, but is a fit and forget solution, as the "gubbins" inside it detect when the bike is running and turn the thing off when the engine is not running
https://www.optimate.co.uk/products/o108-usb-charger
EDIT: i have an optimate charger too, so works well with the above, as they both use the same plug, so i disconnect the USB and plug into my charger over the winter months
PostPosted: 20:01 - 15 May 2023    Post subject: Reply with quote
I fitted mine with an on/off switch through a relay under the seat.
Tapped into rear light + feed, works perfectly.
Super easy, just don't use a cheap nasty scotch lock or similar.
RAYK47
PostPosted: 08:33 - 17 May 2023    Post subject: Reply with quote
thanks all.
RAYK47
PostPosted: 08:34 - 17 May 2023    Post subject: Reply with quote
Didn't realise they did those. I already have an optimate port connected to my bike as well. Thanks
The last post was made 3 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 60.5 Kb
