Knock Knocking / Oil Leak.
DaddyStu
PostPosted: 19:37 - 16 May 2023    Post subject: Knock Knocking / Oil Leak. Reply with quote
Had some what sounded like engine knocking on commute home today. Pulled over after a few miles - couldnt see anything obvious although the oil was bubbling back into rest position as viewed through sight-glass. No smoking.
Started her up again and got home after the next 10 miles with no issues. Couldn't replicate despite pushing out 9-10k revs.
She was running at 90degC but she is rated for that - its when the fan kicks in. Levels seem fine although oil lower than i'd thought having topped it to near the max about 200 miles ago.
Other than engine, theres a possibility a stone could've gotten in my scrambler tread and hit the mudguards as there is very little clearance. Didn't find one though.
Any thoughts on what to look for?
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
PostPosted: 20:08 - 16 May 2023    Post subject: Reply with quote
If it's in the engine, a knocking noise would be rev dependant. If it's in the transmission or drivetrain, it would be speed dependant.
As a total starter for 10, I would have a very close inspection of the chain, look at every link for signs of splitting in the sideplates, check the master link is intact and that there are no tight spots or tight links. Inspect the sprockets for signs of wear and hooking over and ensure the front sprocket is properly attached.
If there's a rear hugger, make sure it's not flapping about. Any of my recent wierd noises have been hugger related and a mate of mine had his bike recovered from Europe thinking there was a dead output shaft bearing when it was the hugger rubbing on the tyre..
DaddyStu
PostPosted: 20:12 - 16 May 2023    Post subject: Reply with quote
It didn't appear to be rev dependent or speed dependent. It was also irregular. I do need to check the chain - may need tensioning. I havent adjusted it in 800 miles. If it were drive-train related would it disappear after a quick stop?
Daddystu
PostPosted: 20:25 - 16 May 2023    Post subject: Reply with quote
If it's neither rev or speed dependant (by which I mean the knocking gets faster with speed or faster with revs) then it's not a mechanical part of the bikes engine or transmission, it's something else flapping about.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:43 - 16 May 2023    Post subject: Reply with quote
Left leg fell off the peg and was bouncing off the road?
Triumph Sprint ST 1050
DaddyStu
PostPosted: 20:58 - 16 May 2023    Post subject: Reply with quote
I havent got any flappy bits. Visor perhaps but it's solidly attached and the sound wasn't coming from there. Seemed to be engine/front wheel area.
Unless evidence to the contrary (after chain checks), i'm leaning towards the stone under the mudguard theory. Mainly because it cleared up and didn't reappear at 10k revs/70mph. Will check tomorrow when I top up levels. My sloping drive makes even that an event!
Daddystu
A100man
PostPosted: 22:25 - 16 May 2023    Post subject: Reply with quote
On a Chinese 125? Shocked
Easy-X
PostPosted: 00:21 - 17 May 2023    Post subject: Reply with quote
That's literally the top speed, according to the specs.
A100man
PostPosted: 09:22 - 17 May 2023    Post subject: Reply with quote
You sound like my kids. Rolling Eyes
Nobby the Bastard
Harley Gaydar
PostPosted: 09:30 - 17 May 2023    Post subject: Reply with quote
The only time it'll ever go that fast is in the back of a transit van.
DaddyStu
PostPosted: 12:49 - 17 May 2023    Post subject: Reply with quote
Aye - she'll do 70 'indicated' on the flat. Had 76 upto the rev limiter on a decline. Comfortable at 60-65 all day - even with my 90Kg!
We had a lovely day out up around Brecon-Landovery together - 5 hours in the saddle.
Daddystu
DaddyStu
PostPosted: 15:06 - 17 May 2023    Post subject: Reply with quote
Nice cleaned/lubed chain - no stuck links and all levels good. Looking gorgeous too. Chain in need of tensioning but no time now. Will be commuting in a bit so will see how it goes.
Daddystu
Robby
Dirty Old Man
PostPosted: 20:27 - 17 May 2023    Post subject: Reply with quote
Loose headstock bearings will knock. Hold the front brake on and bounce the forks up and down, with a bit of forward and backwards mixed in.
DaddyStu
PostPosted: 12:57 - 18 May 2023    Post subject: Reply with quote
All good - no drama. 60 mile there-n-back commute with no further issue.
Daddystu
DaddyStu
PostPosted: 17:08 - 21 May 2023    Post subject: Reply with quote
Have evidence of a possible oil leak - coming from front sprocket area and dripping onto top of the sidestand.
Dont think it's chain-lube. Possibly coolant running down from expansion tank outflow? The side-stand is taking a lot of strain from being on a sloped drive so hopefully no case-cracks.
Not enough to mark the floor yet but i wiped 2 clear yet oily drips off.
Didn't taste of much.
Its due a service so will get it checked over.
Daddystu
The last post was made 2 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.43 - MySQL Queries: 13 - Page Size: 90.04 Kb
