Car braki pipe and hose replacement cost?
Ribenapigeon
PostPosted: 18:23 - 19 May 2023    Post subject: Car braki pipe and hose replacement cost? Reply with quote
Anyone had brake pipes and/or hoses fitted recently to a small car? What kind of cost is it these days?
Ive advisories on the hoses and pipes. Im thinking apart from the fact it's bloody awkward doing anything on a car and nuts are always stiff (along with my back Laughing ) the hoses I could do myself but putting in pipes is a bit more involved so I might split the cost by doing the hoses myself but leave the pipes. However given im going to be crawling around under a wheel arch maybe I should have a crack at the pipes ad well. Thoughts, advice, sympathy all welcome.
Cheers.
Easy-X
PostPosted: 18:31 - 19 May 2023    Post subject: Reply with quote
Brake hoses are trivial in price for most cars £10~£30* and easy to fit if you can manage to get 'em undone. Hard lines though? Be very unusual for them to degrade significantly Thinking
Just hoses you might get away with the old "latex glove under the fluid reservoir cap" trick to minimise the bleed operation but with hard lines and practically draining the whole system you might need to look into how the ABS unit will react.
*Once you find the correct part for your make/model of car check again on the hose part number. A Ford specific one might be twice the price of a generic one for essentially the same part.
Ribenapigeon
PostPosted: 18:43 - 19 May 2023    Post subject: Reply with quote
That's the thing. The parts are cheap and even if i get a pressure fluid flushing thing for around £50 the cost is a lot less than a mechanic doing the job. Ive been watching a few you(can think you can do it)tube videos and they range from nice and easy but on a nice clean practically new car all lifted up in a smart garage to bodger crawling around in the street who might as well be using glue and sticky tape.
I dont think the ABS system would be that challenged as its a simple standard system not some fancy BMW thing which needs reprogramming or some such.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:46 - 19 May 2023    Post subject: Reply with quote
Depends on the hard pipe. If it's just on the rear subframe you may be able to buy them. Typically, though, mechanics make up hard lines to suit beccause they need replacement so rarely.
Triumph Sprint ST 1050
Ribenapigeon
PostPosted: 19:39 - 19 May 2023    Post subject: Reply with quote
I was thinking of buying some pipe and fittings and a flaring tool to haya go at making up my own. Would be interesting just from a fettling skill point of view.
Tierbirdy
PostPosted: 19:43 - 19 May 2023    Post subject: Reply with quote
Oh boy...
Well I just paid £1100-ish for a total replacement of my brake lines & hoses. That was cripplingly painful. About £8-900 of that was labor. Admittedly that was a local independent BMW specialist rather than generic garage, could have possibly gotten it done cheaper. Their labor rate is about £80 an hour I think.
BMW 1 series, advisory for corroded pipes, previous owner fucking hammerited over said corroded pipes so when I went to undo one of the hoses to replace them with nicer braided HEL ones, it just sheared off.
That was for all 4 hard lines all the way from the ABS pump to each caliper, and fitting the HEL hoses I provided. Garage said they could form their own copper lines if I wanted, or I could wait an extra 2 days to get steel OEM ones shipped from BMW Germany and the price would be more or less the same, and apparently steel ones are better? No idea why, but as I wasnt in a rush I opted for the OEM ones.
I initially thought about having a go at it myself, however by the time Id bought all the required tools, that Id likely never use again, I thought it wouldnt be worth it. Then I got the quote from the garage and thought "fuck that Ill have a go myself." Then I looked up how to do it and how much aggro it would be (BMW in their infinite wisdom run the brake lines ontop of the fuel lines, so step 1 is "drain and remove the entire fuel system" which I didnt fancy trying to do on my back up on axle stands), and got the garage to do it.
MCN
PostPosted: 20:26 - 19 May 2023    Post subject: Reply with quote
Brake Pipes I used to fit loads of that stuff.
https://en.wikipedia.org/wiki/Bundy_tube?wprov=sfla1
Bundi Tubing. Kunt of a thing to work with.
Ribenapigeon
PostPosted: 20:48 - 19 May 2023    Post subject: Reply with quote
So if I do make up some pipes then use the copper nickel stuff?
Ribenapigeon
PostPosted: 20:52 - 19 May 2023    Post subject: Reply with quote
Tierbirdy wrote:
Oh boy...
The horror, the horror
You have my sympathies. Fortunately from a pic of yhe underbody of an Agila it looks like the pipes are just pinned up under the body with a protection plate over them from front to rear. Still a bugger if I had to do the whole pipe but not impossible.
Why are brake lines and hoses treated like they're some sort of dark art. Its some f****** pipe with unions ffs. Rolling Eyes
Easy-X
PostPosted: 21:13 - 19 May 2023    Post subject: Reply with quote
Oh, this is for the Agila? I doubt it'd be complicated then. Have you visually inspected the hard lines yourself? I'd be interested in a photo if you do think they'd dodgy.
Anyhoo, just buy all the stuff and lego-brick it. There's no point in getting fancy and making stuff yourself unless you think you can improve on the factory work or just fancy the entertainment. On a bike you're just making up short runs and don't even need a lift so have at it. On a car I'm assuming trolley jack and axel stands so fun is way down on the list.
At least the weather's nice Smile
Nobby the Bastard
Harley Gaydar
PostPosted: 21:49 - 19 May 2023    Post subject: Reply with quote
You do know they are examined for mots? Anything that looks like a nick, a kink or corrosion is a fail.
Fucking logo brick them....
Ribenapigeon
PostPosted: 23:20 - 19 May 2023    Post subject: Reply with quote
The advisory on the MOT is; Brake pipe corroded, covered in grease or other material (all pipes) [1.1.11(c)]
I can't get a good look as yet because I'll need to take it to someone else who has a driveway and trolly jack. I might stick a camera on a stick and have a look that way.
Easy-X
PostPosted: 02:41 - 20 May 2023    Post subject: Reply with quote
What I meant by that is just buy the OEM or pattern parts that fit the car and don't try and do anything clever like hand made lines.
MCN
PostPosted: 04:26 - 20 May 2023    Post subject: Reply with quote
You will need a good quality flaring tool set. With Clamp, and crimping/flaring doofer.
The flare needs to have a folded-over lip. The lip is rolled towards the inner diameter of the pipe. That provides a robust area to be compressed by the nut against the seat.
A little practice in forming the flare is required.
Snapon/Blueprint made the best tools for this.
I think Draper are reasonably useful.
A small pipe cutter is handy too as the cleaner the pipe is cut, the better the flare and seal will be.
Ribenapigeon
PostPosted: 07:11 - 20 May 2023    Post subject: Reply with quote
Problem is there are no pattern or OEM parts for the lines that run from the ABS pump to the rear. There's an ebay dealer makes up the shorter pipes front L and H and the rear short ones though. So maybe I'll accept the cost of the front to rear pipe being done by the garage and do the rest myself.
grr666
PostPosted: 09:06 - 20 May 2023    Post subject: Reply with quote
I've had that same advisory on my Transit the last 3 MOT's. It's only an advisory, it could just mean they are too dirty
to inspect them properly rather than actually corroded.
Robby
Dirty Old Man
PostPosted: 10:47 - 20 May 2023    Post subject: Reply with quote
I agree. Try cleaning them first. They really shouldn't be corroded yet.
If you are going to replace them yourself, get plenty of fittings and do some practice runs first to make decent connections. It's the kind of thing you really don't want to fuck up.
Ribenapigeon
PostPosted: 11:29 - 20 May 2023    Post subject: Reply with quote
They're some cheap all in kits on fleabay and amazon im thinking of ordering one just for practice purposes. Hoses are a lot simpler so apart from the flushing the system part im quite confident I can save a few bucks there doing it myself.
Ribenapigeon
PostPosted: 13:16 - 20 May 2023    Post subject: Reply with quote
I've just done a little research and found that brakes operate at up to around 2000psi ! Which is a rather sobering thought.
Ayrton
PostPosted: 19:41 - 20 May 2023    Post subject: Reply with quote
This was maybe 4 years ago but I paid just under £400 to have new brake pipes fitted to my Swift.
I wouldn't have wanted to do it myself, even the mechanic said he struggled with it since everything else on it is going to be corroded. Seems like the kind of job you want a car lift for.
Easy-X
PostPosted: 20:11 - 20 May 2023    Post subject: Reply with quote
The front half won't be too bad but certainly the back half.
Would it be acceptable to go with braided hose throughout and drop the hard lines? (If they're really beyond just a wire brush + paint.) Doing the hose ends is much easier that double-flaring copper pipe.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:16 - 20 May 2023    Post subject: Reply with quote
Braided lines for an entire car would be prohibitively expensive.
Thats why they use hard lines for OEM.
Easy-X
PostPosted: 20:26 - 20 May 2023    Post subject: Reply with quote
Hmm... £30 for 25ft of copper pipe, ends and bending/flaring tools. I take your point.
Ribenapigeon
PostPosted: 09:05 - 21 May 2023    Post subject: Reply with quote
Thats not a bad price but I wonder what the post covid gouge price is. Having sad that the recent work done on the car didn't break down unreasonably in individual jobs.
Im starting to think I'll just do the spring and shock replacement and service stuff myself and fund the brake work through overtime.
WD Forte
PostPosted: 14:32 - 26 May 2023    Post subject: Reply with quote
I've made them up in the past and it wasn't too bad but this was for a van where the access was much easier then crawling under a car.
Apart from buying the pipe/fittings/flaring tool etc
A trolley jack and axle stands or blocks to get it as high as possible
with the wheels off would make the job so much less of a hassle
and allow you to get a disc cutter in there to remove the old fittings
rather than fart about struggling for ages with rusty rounded off stuff.
A pipe bending tool would be very useful for creating any complex curves without kinking the pipe
A quick butchers on Ebay gives this
can't attest to the quality but I like the price
https://www.ebay.co.uk/itm/234632934771?
bikers smell of wee
The last post was made 3 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 129.09 Kb
