is it ok to use slightly different oil grade (10w40, 10w50)
czakal
PostPosted: 19:35 - 20 May 2023    Post subject: is it ok to use slightly different oil grade (10w40, 10w50) Reply with quote
Hello people, it's my first oil change with my BMW G310R, the manual specifies 10W50 but 10W40 is much easier to find. Am I correct that the difference between those viscosities isn't huge, especially for a relatively low power budget bike like mine?
Thanks, C
Nobby the Bastard
Harley Gaydar
PostPosted: 19:40 - 20 May 2023    Post subject: Reply with quote
10w50 isn't that difficult to find. If thats what the manufacturer recommends, get it.
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 23:57 - 20 May 2023    Post subject: Reply with quote
It's unusual to require 10W50 in a liquid cooled engine, it's the sort of grade you may expect to need in something air cooled that operates over a wider temperature range.
I would assume there's a good reason why it asks for 10W50, and 10W40 would be too thin in very hot conditions, leading to low oil pressure in heavy traffic in summer.
Get the right stuff.
czakal
PostPosted: 01:58 - 21 May 2023    Post subject: Reply with quote
Sorry I meant 15W50, had a bit of trouble finding local stock but found something in next town over...
MCN
PostPosted: 06:19 - 21 May 2023    Post subject: Reply with quote
I was 'looking after' a Detriot Diesel for a few months a couple of years ago. The khunts were running it with the 'usual 15w40 Diesel engine oil we used in all our other Diesels.
The Detriot was wolfing through engine oil and the exhausts were dripping oil out of every joint.
I was told, 'Yeah, it's been doing this for years.'.
The issue with Detriot Diesel is they are only supposed to run on Mono Grade engine oils. For our engine that was 30w.
The oil consumption and raining oil was solved just by draining and filling with 30w oil.
The numbers on the oil indicate what temperature range the oil will maintain its lubricating properties. But also affects how easy/difficult it will be to start in cold temperatures.
The thicker oil puts more load on the starter system.
A100man
PostPosted: 08:17 - 21 May 2023    Post subject: Reply with quote
I wouldn't worry about it..
Perhaps if I was touring a hot country I might try harder to get 15/50. On the other hand it's probably the standard choice in a hot country and more available..
MCN
PostPosted: 11:07 - 21 May 2023    Post subject: Reply with quote
15/50 isn't difficult to get.
Unless you are located in a region where stuff is difficult to get.
Ebay amazon are all the usual khunts have it available.
PostPosted: 11:27 - 21 May 2023    Post subject: Reply with quote
I have an oil cooled BMW which is supposed to use 10w/50. I just put any good oil in it. I've used 0w/30 fully synth long life oil for vw diesels (coz I get it free from work) and I've used 15/30, 15/40 semi-synth and get very high mileages on my bike.
Just change it often.
PostPosted: 18:07 - 21 May 2023    Post subject: Reply with quote
BMW usually have a chart in the owners manual showing different oil viscosities for use in different air temperature ranges.
If you are in the UK, it boils down to both 15w-50 and 10w-40 will cover any range of temperatures you could reasonably expect to encounter. Not like in continental Europe where they will be seeing minus double figures for weeks at a time over the winter.
PostPosted: 15:03 - 22 May 2023    Post subject: Reply with quote
Working on the principle 'some oil is better than no oil. I've put some real shite in my cars and bikes over the years. It certainly wouldn't worry me in the slightest using 10/40 in place of 10/50.
Triumph Trophy Launch Edition
blurredman
PostPosted: 09:06 - 23 May 2023    Post subject: Reply with quote
I often use 10w40 semi (MA) oil for actual oil change on my bike, but top up with much cheaper 20w50 standard mineral. I do the oil change just before the winter, so I make the most of the smoother gear changes whilst I can- and by the time summer comes around, about half a gallon of oil has burnt up in total and it's all pretty much 20w50 by that point anyway through topping up so it doesn't effect the smoothness of the bike by the time the sun has come out. Not that any of this matters realistically.
The last post was made 2 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 69.29 Kb
