YBR 125 2015 reg won’t start
bazzaboy2010
PostPosted: 10:34 - 21 May 2023    Post subject: YBR 125 2015 reg won’t start Reply with quote
Haven’t ridden the bike for a week and then put my key and nothing.
So pulled the battery out, that’s fully charged, then looked at the single fuse and that is fine.
But still getting nothing
Any ideas please would be grateful
Easy-X
PostPosted: 11:53 - 21 May 2023    Post subject: Reply with quote
Define "nothing." Complete silence, any clicking from a relay, slight clunk from the starter motor?
Nobby the Bastard
Harley Gaydar
PostPosted: 11:55 - 21 May 2023    Post subject: Reply with quote
Have you put the big red switch on the handlebars to off?
Triumph Sprint ST 1050
slowasyoulike
PostPosted: 14:14 - 21 May 2023    Post subject: Reply with quote
[assuming 'nothing' means literally no life at all...]
After you've checked the kill switch, as suggested, if that's not off or in need of a clean then check the ignition switch itself.
I used to have an Aprilia scooter which would do exactly what yours has; the barrel was a bit worn and every now and again the ignition wouldn't come on unless the key was held in a certain position when turned on. Could be that yours just needs a bit of a clean. In my case it was that scrotes had damaged the switch in a botched theft attempt.
The last post was made 2 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.86 - MySQL Queries: 13 - Page Size: 38.97 Kb
