| 10kovako |
 10kovako Borekit Bruiser
| Nobby the Bastard |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| 10kovako |
| 10kovako |
| Nobby the Bastard |
| 10kovako |
| MarJay |
 MarJay But it's British!
| 10kovako |
| stinkwheel |
 Posted: 08:00 - 30 May 2023 Post subject: |
If it burped a big air bubble out, it would have to go somewhere first and that's into the expansion tank. The system has to be under pressure for the radiator cap to be opened against its spring which would allow coolant to flow both ways between the expansion bottle and the radiator. That't wont happen properly while there's air in the system because air is compressable.
It MIGHT be your head gasket, it's possible a bit of crud was all that was preventing if gassing through and the flushing dislodged it but as above, I'd refill and take it for a bit of a run and see if it's still doing it. If the gasket's gone, the gasket's gone. If it hasn't, you're fine.
Another wee test is to feel one of the coolant hoses as you rev the engine. If it goes hard as you rev it, that would be a bad thing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| 10kovako |
| 10kovako |
| MarJay |
| 10kovako |
| Nobby the Bastard |
| 10kovako |
| 10kovako |
 Posted: 18:17 - 01 Jun 2023 Post subject: |
| 10kovako wrote: | | Nobby the Bastard wrote: | In that case you are overfilling it. When you turn it off,all that heat in the engine is seeping into the water that is no longer being cooled so the coolent expands.
The small gap at the top of the radiator is probably because a vacuum forms whilst you are riding and when you take the cap off when cold you are letting air in. |
But that’s the strange thing, if I was overfilling, surely the engine wouldn’t overheat? The cap is a strange one, it’s actually under the tank not in the radiator, by the thermostat. There’s definitely still an air gap. Is this normal? |
Ran another test again, and under the fuel tank, when I take off the coolant cap, the thermostat seems to allow water through to fill the radiators, and when a little warm the level appears full. As soon as I switch off the level drops again, so strange! ____________________ Let’s do this |
| Nobby the Bastard |
| 10kovako |
| Nobby the Bastard |
| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 19:53 - 01 Jun 2023 Post subject: |
A functioning radiator cap will maintain pressure in the cooling system, allowing excess volume (due to coolant expansion when hot) to flow into the surge tank/expansion tank. As the engine cools, the radiator cap will maintain an airtight seal, and the coolant in the surge tank will migrate back into the radiator. Your symptoms suggest the radiator cap is allowing air into the radiator upon cool down. I suggest replacing the cap. The STANT 11233 is an aftermarket cap that works on many japanese bikes, and costs a fraction of the OEM cap.  ____________________ History shows again and again how nature points out the folly of men - BOC |
| Nobby the Bastard |
| jeffyjeff |
| jeffyjeff |
The last post was made 3 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
