ZZR1100 front sprocket has moved outwards?
Mrflashy
PostPosted: 17:49 - 10 Jun 2023    Post subject: ZZR1100 front sprocket has moved outwards? Reply with quote
I have a Zzr1100d engine in a race car and I suddenly lost drive when changing down at high speed, when inspecting, the rear chain is now loose and the front chain sprocket is 1-2cm further out and the nut is rubbing on the sprocket cover housing. If you try to select a gear and pull the clutch out, I get no drive just a revving engine like being in neutral.
What could the cause of this be? The shaft still turns with the chain/sprocket when rocking the car on the driveway, and no other signs of damage.
Many thanks
Nobby the Bastard
Harley Gaydar
PostPosted: 19:05 - 10 Jun 2023    Post subject: Reply with quote
Sounds like a fucked gearbox. No point trying to work out what in the gearbox is fucked, the whole engine Will need stripping anyway.
Triumph Sprint ST 1050
PostPosted: 19:25 - 10 Jun 2023    Post subject: Reply with quote
Obvious and easy one would be that the nut has come undone and the sprocket is no longer properly engaged on the splines.
Compex and annoying one would be that either the mainshaft has snapped, a gear has let go or the bearing has walked out of the crankcase
Nobby the Bastard
Harley Gaydar
PostPosted: 19:50 - 10 Jun 2023    Post subject: Reply with quote
I'd be amazed if there was 1-2 cm of thread for the nut to come undone over.
Mrflashy
PostPosted: 20:07 - 10 Jun 2023    Post subject: Reply with quote
Thanks all. There is a small possibility that this is a loose nut now it's been mentioned, as if I keep rocking back/forth occasionally the shaft stops turning when the sprocket is still turning, putting a bit of pressure with a pry to push it back on it starts turning the shaft again.
Will remove the cover and inspect the outside and feedback!
Nobby the Bastard
Harley Gaydar
PostPosted: 20:15 - 10 Jun 2023    Post subject: Reply with quote
Have you considered just taking the casing over the sproket off?
If it moves with a pry bar applied it's not a loose nut.
PostPosted: 20:33 - 10 Jun 2023    Post subject: Reply with quote
If the nut is unscrewing itself, the way they used to prevent this (other than the obvious properly tightening/thread-lock etc) was to use a grub screw into the sprocket.
You get an M6 cheese head screw, these usually have a 10mm head diameter. Measure 5mm away from one of the flats of the main sprocket nut on the sprocket and drill and tap an M6 hole in the sprocket (some sprockets actually already have these).
Once you've tightened the main nut down, take it a little either way until a flat is adjacent to the screw hole and screw the cheese-head in. Use a good spring washer and loctite, I'd suggest a nord-lok washer. Then you have a good mechanical lock preventing it happening again and because it's offset somewhat, is less prone to precessing out.
Old pre-unit brit bikes use this as it's very difficult to do up the mainshaft nut particularly tight for a variety of reasons. They don't come undone, even if they are barely past finger tight
PostPosted: 20:43 - 10 Jun 2023    Post subject: Reply with quote
Broken output shaft is common on bike-engined carsbecause the larger mass of the car means that the engine is at peak torque for longer (because the larger mass needs more time to accellerate through peak torque). Many people fit an outboard support bearing and in fact they make a stronger shaft for the Hayabusa engine for this very reason and strengthened case bolts too as they sometimes burst the cases.
Only way you're going to find out is have it apart.
Mrflashy
PostPosted: 21:02 - 10 Jun 2023    Post subject: Reply with quote
I've got a fuel tank to get out of the way before I can gain access but will definitely do this to get better eyes on it. Thank you!!
Mrflashy
PostPosted: 21:05 - 10 Jun 2023    Post subject: Reply with quote
Thanks all for the detailed advice, makes perfect sense to have a better fixing for the nut, and to be aware of the gotchas with bike engined cars. Luckily for me it didn't cause any safety issues for me as I was around 10,000rpm when I lost drive!
Nobby the Bastard
Harley Gaydar
PostPosted: 21:07 - 10 Jun 2023    Post subject: Reply with quote
It's not the nut thats the problem....
The shaft that the sproket is on has busted something further upstream because the bearing supporting the shaft is not up to the stress of hauling a car.
PostPosted: 21:57 - 10 Jun 2023    Post subject: Reply with quote
You'll very quickly know when the cover comes off anyway, either the nut or the broken shaft will fall out.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:00 - 10 Jun 2023    Post subject: Re: ZZR1100 front sprocket has moved outwards? Reply with quote
I wouldn't hope for the best at this point.
WD Forte
PostPosted: 22:13 - 10 Jun 2023    Post subject: Reply with quote
Cant he just weld the sprocket on?
I'm sure its been done before
bikers smell of wee
Mrflashy
PostPosted: 16:05 - 11 Jun 2023    Post subject: Reply with quote
Thanks all, prize goes to stinkwheel, the sprocket was sitting completely off the spline, and the nut had wound all the way off, the only thing stopping the nut from falling off was friction against the sprocket cover itself.
The previous owner appears to have used a smaller and wider sprocket which rendered his attempt of using the locking tab washer useless as it wasnt sitting on any splines.
I have refitted it by hand, put the car in gear and the output shaft is binding and halting the car from moving forward/back as expected.
Needs more checking as others have mentioned to ensure no further damage.
PostPosted: 18:09 - 11 Jun 2023    Post subject: Reply with quote
That's a result for you. Bike engined cars often get geared down with a smaller sprocket because usually 1st gear is too tall for the job. The downside is that you lose some speed at the top end.
PostPosted: 18:10 - 11 Jun 2023    Post subject: Reply with quote
Wow, that's a dinky sprocket. What is it 13 tooth? Grub screw trick wont work on that.
If you can't get the tabbed washer under it, it's likely to happen again.
If there's enough thread, you could try a nordlok washer, those things are remarkable. Better than anything else that isn't a physical mechanical lock like your tabbed washer or lockwire. Including nylok, loctite and double nuts.
My other thought would be milling/surface grinding the outside face of the sprocket so you can get the splined washer on and the nut on properly. Only reason I can think of to use a fatter sprocket would be to get the chain line and that's determined by the inside face.
PostPosted: 18:54 - 11 Jun 2023    Post subject: Reply with quote
High strength threadlock on the nut threads. When you want it off, cook it with a blow torch and it'll come loose easy as anything.
Mrflashy
PostPosted: 19:29 - 11 Jun 2023    Post subject: Reply with quote
14 tooth, the acceleration is immense as it's a Powertec tuned model with keihin FCRs too.
I might use both threadlock and a nordlok washer, don't fancy chances with this again!!
Thanks again all. I will report back if it turns into something more nasty when it starts up and moves again
MCN
PostPosted: 15:47 - 12 Jun 2023    Post subject: Reply with quote
If you are able to 'develop' the project, then look at fitting a Slipper Clutch.
I read your first post and considered, as Pits did, that the 'car' is a heavier lump to decelerate than the donor bike by a large margin.
Therefore, the drive train is being overloaded.
A slipper Clutch almost eliminate harmful 'back-torque' from the road reaching the engine.
It's because the engine cannot be pushed around much more than designed limits that something has to give. The weakest link in the chain being the drive sprocket.
Thread Lock and a Nord Lock washer may hold the sprocket on but the extra energy will ossiblybbe pushed elsewhere.
A rear wheel or burst chain is fine. A minced gearbox or a mashed bottom end, rammed push rod into an up coming piston.
The last post was made 3 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.27 - MySQL Queries: 13 - Page Size: 105.85 Kb
