No thermostat..?
A100man
PostPosted: 12:45 - 08 Jun 2023    Post subject: No thermostat..? Reply with quote
Suspect the FZ has no or broken thermostat fitted as the temp needle hardly ever moves off the bottom. In hot weather recently it nudged up a bit but not much..
My suspicion is that there's no thermostat in the housing.. (I'll have a look soon as I also want to dismantle parts to balance the carbs) But..how bad is this generally? i.e. what are the downside of not having one. Obvs it's not running at optimum temp for much of the time.
PostPosted: 13:01 - 08 Jun 2023    Post subject: Reply with quote
If it was broken it was more likely to be broken shut than broken in an open position. Could it be an issue with the temperature sender rather than the stat? I'd definitely recommend inspecting, and then testing the stat using the Haynes classic water in a pan on the hob method.
The other option is just to see if the rad is getting hot. If not it could be the stat is shut or it could be an air lock in the cooling system.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:05 - 08 Jun 2023    Post subject: Reply with quote
No stat is a quick and easy fix for a broken stat. There wasn''t in my FZR and I used it in all kinds of weather without an issue.
Triumph Sprint ST 1050
that_impulse_guy
PostPosted: 16:46 - 08 Jun 2023    Post subject: Reply with quote
my jap ('86 carb, 4T) import doesnt have a stat.
its not there.
there is a holder for it, but its empty.
it came empty from the factory...so did every other one of these ones.
Mine is not unique.
The microfiche shows the stat holder, but there is no stat drawn/shown, and no part number for it either.
I dont know what I'm proving, come to your own conclusions
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
MCN
PostPosted: 21:03 - 08 Jun 2023    Post subject: Re: No thermostat..? Reply with quote
Could just as easy be the temperature sensor not reading correctly.
WD Forte
PostPosted: 23:50 - 08 Jun 2023    Post subject: Reply with quote
Quick gauge test
short the sender wire to the engine when the ignition is on
and the needle should climb to max.
If it does, the gauge is OK
To test the sender
measure it's resistance to ground at cold/ambient (20C)
as the engine warms up the resistance should drop
bikers smell of wee
PostPosted: 00:33 - 09 Jun 2023    Post subject: Reply with quote
You could bodge the bodge and cover part of the radiator with a bit of for sale sign board. I've actually seen it done for running over winter with bikes that had the 'stat removed because they overheated in town in the summer.
slowasyoulike
PostPosted: 08:48 - 09 Jun 2023    Post subject: Reply with quote
I did this years ago with an old 400 Burgman that someone had removed the thermostat from. It was a complete shed, with many other issues which meant spending money on it was out... on the advice of an experienced bodger mate I used to cover half the radiator grille with gaffa tape in winter - worked like a charm Thumbs Up
A100man
PostPosted: 09:35 - 09 Jun 2023    Post subject: Reply with quote
I like it.. should also test the gauge further.. Although I might contest the terminology.. 'enhancing the bodge' surely. Wink
Cheers all
A100man
PostPosted: 09:36 - 09 Jun 2023    Post subject: Reply with quote
WD Forte wrote:
Quick gauge test
To test the sender
Thumbs Up Thumbs Up
lingeringstin...
PostPosted: 23:52 - 13 Jun 2023    Post subject: Reply with quote
Every car and bike I've ever owned that was water cooled got the thermostat immediately chucked out and in several decades I have never had the least bit of issue with it. Yes I know there might be some sort of "optimum" temperature for highly tuned race engines to run at but in real daily use of average vehicles nothing requires a thermostat other than so your car's heater heats up quicker in the winter.
Most engines even today are still not rocket science. Fuel leaks into the engine through a hole and then goes bang under pressure and the piston runs away in terror, then it comes back again for more. This repeats itself many times and as a consequence the shaking of the engine causes gravity to recede in front of you and the vehicle gets pulled along by magnetic force as if it's perpetually going downhill. When you switch off the ignition the piston stops being frightened and the gravitational field around the vehicle returns to normal.
Well that's one of my theories anyway. I've got others.
weasley
PostPosted: 13:32 - 16 Jun 2023    Post subject: Reply with quote
[quote="lingeringstink"...but in real daily use of average vehicles nothing requires a thermostat other than so your car's heater heats up quicker in the winter.[/quote]
And your engine heats up quicker, meaning it is running more optimally more quickly. Most wear happens during warm-up, when the parts aren't the right size and the oil is not fully woken up. More recently this is also to help with vehicle emissions and efficiency.
MCN
PostPosted: 13:47 - 16 Jun 2023    Post subject: Reply with quote
We used to dip women suspected of witchcraft. Because we believed this to be a proper method of detection and control.
It's fucking amazing that in this day and age we still have folk who have faith in medieval remedies. Shocked
WD Forte
PostPosted: 14:04 - 16 Jun 2023    Post subject: Reply with quote
I always piss in my coolant when topping it up to
purge noxious vapours and evil fluxes lest a menstruating woman
has cursed it by passing by with out a veil
You cant be too careful
bikers smell of wee
MCN
PostPosted: 14:08 - 16 Jun 2023    Post subject: Reply with quote
With you ethanol intake your piss might probably be efficacious in controlling evil.
virus
PostPosted: 16:12 - 16 Jun 2023    Post subject: Reply with quote
I have a friend who did that as an emergency bodge to get home after a bike boiled over on him. He forgot / couldnt be arsed to repair it and all was going well until It boiled over again/blew a hose and sprayed him in his own stale hot piss. Oh how we laughed. Laughing
own: 81 xs1100g...
MCN
PostPosted: 17:42 - 16 Jun 2023    Post subject: Reply with quote
Possibly as a Get-Home solution but antifreeze at a high enough concentration prevents bacterial sludge forming in cooling systems kind cool water systems used for HVAC.
Leaving Pee-Pee in the cooling system could create its own problems over time.
And how much piss? It's not easy to hold more than a pint.
Or 8 pints before the seal is broken.
The last post was made 3 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 99.09 Kb
