Car tow electrics WTF.
A100man
PostPosted: 11:57 - 14 Jun 2023    Post subject: Car tow electrics WTF. Reply with quote
All
Was considering buying a bike trailer, noted that I could get a towbar quite cheaply (less that 150) but then looked into the tow-bar electrics.
Jeez! for my 2019 SEAT Leon you'd need to employ a customs man to rip out all the internals required,,
You need to route cable all the way up the sill and into the back of the glove box (removing the never used CD player in teh process) then fiddle about in the fuse box area.. Stupidly I assumed that there'd be a ready prepped connector in the boot area.. Summat to do with CAN bus controls I believe (on lights FFS)..
Suffice to say unless there's a short cut i won't be bothering.
WD Forte
PostPosted: 12:54 - 14 Jun 2023    Post subject: Reply with quote
Look up 'interface relays' for after market towbar wiring
they should enable you to patch in a tow bar without giving the cars
CANbus and stuff conniptions
This place may sell you a kit including one
https://www.towbarexpress.co.uk/
bikers smell of wee
whyber
PostPosted: 13:20 - 14 Jun 2023    Post subject: Reply with quote
I got lucky, my old 2006 Focus didn't need any CANBUS nonsense. Just crimped them in.
Doesn't help you, sry. Very Happy
Hot and tired
A100man
PostPosted: 13:51 - 14 Jun 2023    Post subject: Reply with quote
Thumbs Up the TEB7AS unit seems popular.. you still need to runa 2mm 'live'
for the battery but that's all. Could be back on..
Fullers1845
PostPosted: 14:33 - 14 Jun 2023    Post subject: Reply with quote
You only really need the vehicle specific stuff when towing heavy stuff, our Mondeo was done cheaply with bypass relays which was absolutely fine for our old camping trailer or bike on a trailer but when we got our caravan I had a local car electrics place put in the ford oem module and reprogrammed for the esp link in
A100man
PostPosted: 15:48 - 14 Jun 2023    Post subject: Reply with quote
Next problem..
brake lights, fog, reversing and rear lights embedded in the tailgate with wiring threaded through rubber conduit next to top hatch hinge..
Indicators though are in body in rear flanks..
Load of toss and wank.
PostPosted: 16:34 - 14 Jun 2023    Post subject: Reply with quote
Sounds like it would be easier to make a stand-alone battery and loom on the trailer board with always on LED tail light and suction-cup/velcro optical triggers for the other lights.
I jest... but that would actually be comparatively easy to do. Thinking
WD Forte
PostPosted: 16:35 - 14 Jun 2023    Post subject: Reply with quote
for a bike trailer all you really need is
indicators L&R
tail and number plate light
Brake lights
ground
I suspect Seat ( VW) use DIN standard wiring
so Grounds will be Brown
and I'll guess but check of course
Tail GY/WH
numberplate GY/GN
Brake lights BK/RD
Indicators
RH - BK/GN
LH - BK/W
bikers smell of wee
MCN
PostPosted: 19:24 - 14 Jun 2023    Post subject: Reply with quote
I got a BMW VW Audi specific tow bar on my BMW520. I bought the kit from some shower in England. (When I lived south of the divide)
I don't like tow bars hanging out the back so I got a bar with a removable ball thingy.
It has full load rating boats, bike, caravans, Iford Williams (if you're a one that carts coos or horses around).
The other deal with a removable is that if the electric socket goes on the blink, the blink the vehicle can still pass an mot.
If a tow bar is fitted then the tester must plug a test plug into the socket and test all trailer light functions.
My car uses cantus and the towbar kit comes with an interface.
I don't know how the gizmo works but it let's the cantus know when a trailer is hooked up and disables the reversing lights.
The trailer lights on my trailer failed quite soon after I got the hoowur.
I bought two LED clusters for it from ebay.
100% better suited to the trailer and I haven't had any bother with failures in 10 years.
Towing regulations are something to look at too.
And you must have secondary retention between the trailer and the tow. Incase the hitch jumps off the ball. It must be a thing.
Get a spare wheel for the trailer too or fill the tyres with sealant.
A puncture on a trailer will spoil your day.
Skudd
PostPosted: 12:34 - 26 Jun 2023    Post subject: Reply with quote
Just had a tow bar fitted to my 16 plate Mondeo, £400 all in. Wunderluch I think it is. Got the garage to do all the mucking around. Obviously had tpo ring round a few places, but your local facefook will help you there.
slowasyoulike
PostPosted: 19:16 - 26 Jun 2023    Post subject: Reply with quote
A100man wrote:
TEB7AS
Yep, that's what you want. I fitted a towbar to my CANBUS-afflicted Vito, and used one of those. It was actually surprisingly painless as I was able to take the required 12V from a tab lighter socket in the back of the van.
RoamingStar
PostPosted: 09:59 - 18 Jul 2023    Post subject: Reply with quote
A100man wrote:
Next problem..
I'm a bit late to the party here so you've probably already sorted it, but my Touran is the same and although the wiring is up there it is all routed to a common loom under a panel in the boot floor (right where the tailgate latch receiver is). A bunch of torx screws removed reveals the wiring. At the time I couldn't find specific information for my model with regards wiring colours so used a multimeter in tiny holes made in the wiring insulation to work out which did what. I would think your car would be similar, trace the wiring from the bootlid and see where it goes. Conveniently everything was in one place for me, I think I even found a switched 12v in there so didn't have to run a long power line to the relay from further forward in the car.
Lots of wiring diagrams online and a Haynes is always handy.
The last post was made 2 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 74.96 Kb
