headlight bulb upgrade
to v or not to v
PostPosted: 18:45 - 26 Jun 2023    Post subject: headlight bulb upgrade Reply with quote
the headlights on my Thunderace are crap. for a vehicle capable of such high speeds its a bit shocking really.
is there a plug and play upgrade available? the bulbs are 35/35w
Moto Guzzi V7.
MCN
PostPosted: 20:20 - 26 Jun 2023    Post subject: Re: headlight bulb upgrade Reply with quote
PIAA make very good bulbs. Much better light from them without having to modifuckate anything.
I used them in a Yamahahaha Thunderfart and Trumpet Splints 955is and two BMW Panzervaggons.
Very better much than standard halogen bulbs.
https://www.piaa.co.uk/
Kawasaki Jimbo
PostPosted: 20:34 - 26 Jun 2023    Post subject: Reply with quote
Big claims for headlight relay kits here -
An easy way to get a lot more light from your headlight. Adding relays will make any bulb put out it’s full intensity. Your headlight bulb’s Voltage drop after installing this kit will be a mere .1 Volt! (that’s point one Volt) You will be amazed at your stock bulb’s output! Even on a brand new bike you will notice an incredible difference in the headlight output.
https://www.easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html
The bloke seems to know his subject though, and although I’ve no experience of these the reg/rec wiring kit I bought was very high quality.
I’d have to ask whether the maxed-out bulb creates enough heat to damage surrounding plastics but it seems unlikely.
to v or not to v
PostPosted: 20:46 - 26 Jun 2023    Post subject: Reply with quote
thanks, but not simple plug n play.
i rarely ride in the dark so im not looking to throw a lot of money/labour at the problem.
Moto Guzzi V7.
Kawasaki Jimbo
PostPosted: 21:01 - 26 Jun 2023    Post subject: Reply with quote
It looks to me like plug ‘n’ play. I think one end attaches to the battery terminals, then you unplug the headlight connector, plug the kit’s own connector into the bulb and the other connector into the loom plug.
PostPosted: 21:06 - 26 Jun 2023    Post subject: Reply with quote
I've used LED bulbs from https://www.classiccarleds.co.uk on several bikes now. They are very good with crisp beam pattern that passes the MOT in the standard reflectors, and my tester does put them on the beam pattern tester.
One thing to watch is if there's room for the heatsink beching the bulb. I think yours are an H7 so they do several versions. Bigger heatsink = better if you can fit it in there. Remote electronics pack also = better if you can find somewhere to put it.
I put their LEDs on mrs stinkwheels Honda Wave which has 35/35 bulbs and it took them from effectively useless in the dark to actually quite a decent headlight.
to v or not to v
by pnp i mean i buy a brighter bulb and plug it in my headlight. ive no interest in adding more wires etc to the bike.
Moto Guzzi V7.
PostPosted: 21:10 - 26 Jun 2023    Post subject: Reply with quote
The LEDs are plug and play. You plug them into the bulb socket, fit the bulb in and they work. The ones with the remove electronics pack you do the same with (bulb socket plugs into the pack, bulb goes in the headlamp) the only additional thing is you cable tie the electronics pack somewhere. Or if you can't be arsed, buy an integrated one instead.
to v or not to v
PostPosted: 21:13 - 26 Jun 2023    Post subject: Reply with quote
thanks Stink' thats what im looking for. my bulb type is h4.
Moto Guzzi V7.
PostPosted: 21:40 - 26 Jun 2023    Post subject: Reply with quote
I have this if you want it. Just send me your address:
A100man
PostPosted: 22:02 - 26 Jun 2023    Post subject: Re: headlight bulb upgrade Reply with quote
I think someone downgraded you. Even my 1988 FZ has 60/55W H4 in its 'Ford Cortina' headlight.
to v or not to v
PostPosted: 22:07 - 26 Jun 2023    Post subject: Re: headlight bulb upgrade Reply with quote
nope thats what the UK model comes with as standard. euro model has 55w bulbs but has 1 light for dipped beam and 1 for main. whereas the UK model has both headlights lit at the same time.
Moto Guzzi V7.
to v or not to v
PostPosted: 22:12 - 26 Jun 2023    Post subject: Reply with quote
thanks Pete thats a very kind offer.
i need a matching pair though, so will pick some up online if i do upgrade Thumbs Up
Moto Guzzi V7.
A100man
PostPosted: 22:21 - 26 Jun 2023    Post subject: Re: headlight bulb upgrade Reply with quote
Ah, fair enough..
Easy-X
PostPosted: 23:53 - 26 Jun 2023    Post subject: Reply with quote
The relay idea has applied to cars in the past: run really chunky power all the way round, switch everywhere with relays and use signal wire from the switches. More energy efficient, reduction in copper, save the asthmatic kittens and all that. But of course it's gone too far now with individual CAN-bus modules for everything.
Anyhoo, on a bike? Where are the losses? A couple of switches and connectors... seems like a lot of hassle for a marginal gain Thinking
Kawasaki Jimbo
PostPosted: 00:15 - 27 Jun 2023    Post subject: Reply with quote
I suppose I’m just lucky there’s no ‘unhelpful’ rating.
Crying or Very sad Wink
PostPosted: 07:29 - 27 Jun 2023    Post subject: Reply with quote
Small switches with tiny shitty contacts that sit out in the weather carrying a relatively high load with the thinnest possible wire so it doesn't get in the way of handlebar movement.
Easy-X
PostPosted: 08:33 - 27 Jun 2023    Post subject: Reply with quote
And TBF something very easy to test with a multimeter with only my damnable procrastination preventing it from happening Laughing
The last post was made 2 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 102.61 Kb
