How to lubricate? a 1999 R1 Exup valve?
skatefreak
PostPosted: 23:01 - 28 Jun 2023    Post subject: How to lubricate? a 1999 R1 Exup valve? Reply with quote
As per title,
Exup valve moves freely by hand but as soon as any lateral tension is applied (such as hooking up the cables) it seems to seize up?
Does it need cleaning?
I've not had it apart yet as the first bolt sheered off easily and the second rounded out. Need to get it on a pilar drill, just curious as to whether there is a known solution for the issue.
Best regards
PostPosted: 06:58 - 29 Jun 2023    Post subject: Reply with quote
Last exup valve I had apart for similar issues (FZR400I think it was) the bushes were severely worn. I had to turn new ones.
xX-Alex-Xx
PostPosted: 08:33 - 29 Jun 2023    Post subject: Reply with quote
Probably easier just to fix it open... Eliminator boxes for the motor aren't expensive.
DILLIGAF
to v or not to v
PostPosted: 17:34 - 29 Jun 2023    Post subject: Reply with quote
have a look at this fella-
https://www.thunderacers.com/thunderace_bestanden/howto/exup/
Moto Guzzi V7.
Copycat73
PostPosted: 17:46 - 29 Jun 2023    Post subject: Reply with quote
and loose all the lowdown back pressure .. to what advantage ?
caveat emptor
Copycat73
PostPosted: 17:48 - 29 Jun 2023    Post subject: Re: How to lubricate? a 1999 R1 Exup valve? Reply with quote
skatefreak wrote:
As per title,
Best regards
molybdenum disulfide grease
caveat emptor
Nobby the Bastard
Harley Gaydar
PostPosted: 18:05 - 29 Jun 2023    Post subject: Reply with quote
You lose the bottom end tractability. But it still goes like a missile.
The alternative is having it closed all the time but then you end up.with a litre bike that can only do 80.
Triumph Sprint ST 1050
xX-Alex-Xx
PostPosted: 18:07 - 29 Jun 2023    Post subject: Reply with quote
There’s no advantage to having the valves in my experience. I’ve removed the SET valves on my zooks and the difference it’s made low down has been… fvck all. Better to remove the problem altogether when it doesn’t give any benefits.
DILLIGAF
Nobby the Bastard
Harley Gaydar
PostPosted: 18:23 - 29 Jun 2023    Post subject: Reply with quote
My experience of exup valves shows they do have a noticeable difference.
Kawasaki Jimbo
PostPosted: 19:56 - 29 Jun 2023    Post subject: Reply with quote
Early ones (Yamaha) allow optimal breathing at both low and high revs, and I recall reading something about Yamaha’s 5-valve cylinder head influencing the invention too but I’m still looking for that source. Consequently I wouldn’t remove my ‘03 R1’s EXUP because I’d expect a worse performance.
Later bikes with ‘EXUP’ including from other manufacturers use it more as a means to control emissions at the measured 5k revs.
skatefreak
PostPosted: 22:00 - 29 Jun 2023    Post subject: Reply with quote
Pinned at the moment which help's with the high end on the track but the low end is dead.
I manage to stall it more often than I'd like thus looking to restore it's functionality :\
Nobby the Bastard
Harley Gaydar
PostPosted: 22:22 - 29 Jun 2023    Post subject: Reply with quote
This.
The last post was made 2 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 73.37 Kb
