| lingeringstin... |
 lingeringstin... Spanner Monkey
| stinkwheel |
 Posted: 22:44 - 06 Jul 2023 Post subject: |
I'd have said it's only as good as the narrowest point anyway. There would be a good argument for ensuring it was the same diameter right through from a laminar flow perspective. I've even seen people fit a little alloy spacer tube in plate manifolds to keep the inlet tract diameter smooth and even.
I actually run a smaller carb than the inlet size on my trials bullet. Standard size carb on a ported head. I find the smaller carb gives better idle and more low rev control along with less risk of bogging down if you snap the throttle open. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 A100man World Chat Champion
 Posted: 09:19 - 07 Jul 2023 Post subject: |
My A100 is fitted with a 20mm carb, most likely for commuter economy. I'm toying with the idea of trying to fit a Mikuni VM22, like the higher performing GP100 of the same kind of era. In my mind this will involve dismantling the engine, clutch cover/ carburetor spigot mount and drilling that out from 20mm to 22mm to hopefully benefit from the improve flow.
As Stinkers says port matching appears to be the key here
so I'm not sure what benefits a 27mm carb would offer bolted on to a 19mm or 22mm inlet port. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| MCN |
 MCN Super Spammer
| A100man |
 Posted: 11:00 - 07 Jul 2023 Post subject: |
| MCN wrote: | This question relates to Volumetric Efficiency.
How much gas you can push through an engine.
And some Thermodynamics thrown in the mix.
Trial and error is how the bodger manages this issue.
Calculus is how an engine designer manages it. With some trial and error thrown in.
Basically you can only get energy out of fuel if you can complete oxidisation in the machine.
Gas flow is limited to port size (and shape and routing.)
Blowers and Turbos interfere with the rules a bit bit there are calculated formula for those bastirts too.
Sukitansee is a proven method. |
Well quite, my tuning efforts to date have resulted in marginal or negligible gains, and yet like a 16 year old FS1E owner I persevere, undaunted by my lack of expertise and inability to absorb the knowledge of Bell, Blair, Jennings et al. ____________________ Now: A100, GT250A, XJ598, FZ750
| MCN |
 MCN Super Spammer
| Easy-X |
 Easy-X Super Spammer
| lingeringstin... |
| stinkwheel |
 Posted: 16:52 - 11 Jul 2023 Post subject: |
I presume we're talking CV carbs here, in which case is it actually opening the carb fully? Is the vacuum sufficient to fully lift the throttle valve? Maybe needs a weaker spring?
So many variables. Maybe you need an SU with the main jet metering valve attached to an advance retard lever with a bit of strimmer wire? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| lingeringstin... |
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 09:36 - 14 Aug 2023 Post subject: |
worth reading up about how they tried to slow down the (predecessor) of motogp by limiting carb sizes.
and when that rule kicked in, the bikes were quicker.
because...velocity stacks were "discovered" ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| Pete. |
 Pete. Super Spammer
 Posted: 10:03 - 14 Aug 2023 Post subject: |
I would imagine that the smaller inlets on the 125 engine are to bring up the inlet velocities to improve torque by increasing the intake charge momentum giving a little more cylinder fill in the low to mid-range. It would be at the expense of some top-end flow probably. The 250, being a twin, will have torque pulses at double the frequency of the 125 and so would benefit from the larger port without suffering too much in the mid-range. ____________________ a.k.a 'Geri'
The last post was made 2 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
