Alternative tyre profile height
Fullers1845
PostPosted: 21:54 - 19 Jul 2023    Post subject: Alternative tyre profile height Reply with quote
I need a new front tyre on my Zx6r J1, the trouble is that the specific tyre for that year is 120/65 R17, and the 65 profile means there’s very little choice about, in particular there are no sports touring tyres, and all I’m finding are a couple of ‘super sports’ tyres, I’m not at all a fast rider so moving to a 70 profile would bring a good choice of sports touring models.
Is it sensible to run a 70 instead?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:03 - 19 Jul 2023    Post subject: Reply with quote
The tyre is described as W/H R
W =width of the tyre in mm
H = the percentageof the height of the tyre (not the wheel!) Compared to the width W
R = The radius of the wheel.
It's up to you to decide if a 5% change in the profile will make a difference.
Triumph Sprint ST 1050
Fullers1845
PostPosted: 22:08 - 19 Jul 2023    Post subject: Reply with quote
I suspect in my case I probably wouldn’t notice at all!
Nobby the Bastard
Harley Gaydar
PostPosted: 22:12 - 19 Jul 2023    Post subject: Reply with quote
6mm either way. Forgot to say R is inches.
Tyre sizes are the best example of how to make things complicated.
Easy-X
PostPosted: 00:49 - 20 Jul 2023    Post subject: Reply with quote
A quarter inch drive on a 10mm socket Rolling Eyes
jeffyjeff
PostPosted: 01:27 - 20 Jul 2023    Post subject: Reply with quote
Clearance between the tyre and front fender will be reduced if you mount the 120/70 R17. Also, if your speedometer is driven off the front wheel, it will read slower with the higher profile tyre and your odometer reading will be affected as well (probably insignificant).
PostPosted: 07:07 - 20 Jul 2023    Post subject: Reply with quote
2.4% difference in speedo reading so only 1.45mph at 60mph.
It will probably improve the accuracy of he speedo somewhat.
blurredman
PostPosted: 08:11 - 20 Jul 2023    Post subject: Reply with quote
I wonder if the difference of a brand new tyre vs one worn to the bars has more of a effect on speed displayed and any physical difference felt than such a slight difference of a 65 vs 70 tyre?
PostPosted: 11:22 - 20 Jul 2023    Post subject: Reply with quote
I'd put a 70 section michelin road 5 or 6 on it.
Fullers1845
PostPosted: 11:55 - 20 Jul 2023    Post subject: Reply with quote
OK, looks like I'll go for a change, I've got about 15mm mudguard clearance and the speedo is off a sensor on the final drive.
PostPosted: 13:10 - 20 Jul 2023    Post subject: Reply with quote
The only bike of that era that had a 65 profile was the Yamaha R6 as I recall. I reckon the J1 ZX6 *should* be on a 70 section anyway.
MCN
PostPosted: 16:52 - 20 Jul 2023    Post subject: Reply with quote
Negligible as its only about 8-9mm on diameter.
Though.....
On big earthmovers, fitting a new tyre on a rear axle that has worn tyres fucks with the electronic traction control.
That can accelerate tyre and brake wear.
The sensors on each drive shift see the difference in shaft speed and the ETC brakes wheel on the faster shaft.
So when the burst one tyre on a rear axle, all four have to come off and four new fitted.
Or... the part worns from previous tyre work are fitted in place of the burst.
that_impulse_guy
PostPosted: 20:02 - 20 Jul 2023    Post subject: Reply with quote
same shit happen on pre-haldex mechanical quattros, e.g. b5 series s4/rs4 etc. mismatch in tyre sizes per axle/front+back makes the diffs work overtime, all the time. I had a front tyre blister in the sidewall after a speedbump and opted for 4 new ones.
to mr tyre profile above, dont worry, just fit a 70. its in the splitting hairs category, i.e. doesnt matter in real life.
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
Kentol750
PostPosted: 12:03 - 23 Jul 2023    Post subject: Tyres Reply with quote
Does it affect your insurance if you fit a tyre different in spec to what manufacturer uses? Do kawasaki say its safe to run a 70?
If its Ok and it won't invalidate your insurance then go for it.
If not, Michelin pilot power 2ct.
Some bikes.
The last post was made 3 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 82.37 Kb
