| to v or not to v |
 to v or not to v World Chat Champion
| jeffyjeff |
 jeffyjeff World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
 Posted: 13:02 - 20 Jul 2023 Post subject: |
I've seen these 'bleed ports'get clogged on older bikes
braking systems so its a possibility I suppose.
Same cylinder on a clutch.
Found this simple diagram and added the Deflector part which is found in lot of them
It's just a spring plate to stop fluid squirting back all over the place if the brake is operated when the cover is off
when bleeding for instance.
It's easy enough to check pressure is being released by observing it to see if fluid rushes/flows back into the reservoir when the lever is released.
It's worth mentioning the slave cylinder could be getting stiff/sticky as well of course.
https://imgur.com/dA2Uq1Y.jpg ____________________ bikers smell of wee |
 Posted: 14:56 - 20 Jul 2023 Post subject: |
If it's hydraulic, I presume it'll have a long pushrod going through the engine between the slave cylinder and clutch centre? If it does, check it for rust binding on seals and make sure it's straight by rolling it on a sheet of glass. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| to v or not to v |
| WD Forte |
| Easy-X |
 Easy-X Super Spammer
| Nobby the Bastard |
| Easy-X |
 Posted: 20:38 - 20 Jul 2023 Post subject: |
| Nobby the Bastard wrote: | Not with a hydralic clutch, aside from pumping it a couple of times, which the failure to do would not cause it to slip. |
Well yes, now I come to think about it it's just the reverse of a disk brake. Now I feel a bit dumb  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| to v or not to v |
| blurredman |
 Posted: 07:31 - 21 Jul 2023 Post subject: |
Is it possible the fluid line (if a soft flexy at any point) could be swolen internally not letting fluid return at a fast enough rate? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| Nobby the Bastard |
| to v or not to v |
| WD Forte |
 Posted: 12:11 - 21 Jul 2023 Post subject: |
25+ years old and dirty fluid
This may not be the cause of the clutch slipping but
you my want to do a bit of shopping here
The clutch Master and Slave cylinder repair kits are pretty cheap
https://www.wemoto.com/bikes/yamaha/yzf_1000_r_thunderace/98 ____________________ bikers smell of wee |
| to v or not to v |
 Posted: 17:08 - 21 Jul 2023 Post subject: |
i was hoping it would be something simple  ____________________ current bike Yamaha Thunderace.
Moto Guzzi V7. |
| jeffyjeff |
| to v or not to v |
| to v or not to v |
| doggone |
 doggone World Chat Champion
| to v or not to v |
| WD Forte |
| to v or not to v |
| blurredman |
 Posted: 10:26 - 23 Jul 2023 Post subject: |
| Nobby the Bastard wrote: | Yes, we both thought that the person who suggested it was talking bollocks but it fitted the symptoms and replacing the pipes fixed the problem. |
I also doubted this too when it occured on the rear of my car. But taking off the flexible pipe it was completely without a hole. Thankfully I had changed the drums/shoes/cylinders not long before so no drum wear lip hindered me for inspection. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
The last post was made 2 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
