| colinM |
 colinM Two Stroke Sniffer
| WD Forte |
 WD Forte World Chat Champion
 Posted: 15:41 - 05 Aug 2023 Post subject: |
I've got a 2001 Majesty 250
is yours the 125,250 or 400? for starters
I'll guess carbed 400.
A better or at least viewable picture would help
this is my 250 after renovation which may be similar
I'd removed stripped and serviced the starter motor.
The starter is only held in with two M6 bolts so
if the drive end is stuck in, you may have to drop the oil
and remove the RH crankcase cover to drive remnants out
but hot air gun may help to free it.
https://imgur.com/V2sWYJk.jpg ____________________ bikers smell of wee |
| colinM |
 Posted: 07:42 - 06 Aug 2023 Post subject: |
Here's some better pictures.
https://imgur.com/gallery/Q8q0udZ
I think I'll try some heat.. Maybe a mini blowtorch or something[/url] |
| Easy-X |
 Easy-X Super Spammer
 Posted: 09:46 - 06 Aug 2023 Post subject: |
Jeez... one of those "it was only the rust holding it together" projects, best of luck!
BTW to show the photos in your post you can get a link from imgur, look for "BBCode" in the menu. It should copy something like this to the clipboard:
| Code: | | [img]https://i.imgur.com/SV2f3rm.jpeg[/img] |
Which in turn would give you this:
https://i.imgur.com/SV2f3rm.jpeg ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
 Posted: 10:11 - 06 Aug 2023 Post subject: |
As above, you're probably going to need to drive that out from the inside. I'd be wanting something that fits on the end neatly too to use as a drift. Either an appropriate sized socket on an extension bar or possibly even buy a piece of aluminium or brass rod of the right diameter off ebay to use as a drift.
Applying a load of heat to the outside of the casing will only help. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| colinM |
 Posted: 13:42 - 06 Aug 2023 Post subject: |
| WD Forte |
 Posted: 13:59 - 06 Aug 2023 Post subject: |
| WD Forte |
| colinM |
| MCN |
 MCN Super Spammer
| WD Forte |
| colinM |
| WD Forte |
| colinM |
| WD Forte |
| colinM |
The last post was made 2 years, 126 days ago. Instead of replying here, would creating a new thread be more useful? |
