| A100man |
 A100man World Chat Champion
 Posted: 22:38 - 07 Aug 2023 Post subject: GP100 Damper rod not playing nicley |
Upgrading the A100 with GP100 forks and a disc brake. Figured I'd change the rotten seals on the donor GP forks., but damper rod not playing nicely and I cannot see any way to hold the rod still other than use 'friction'. Heres a link to the rod I think..
https://www.cmsnl.com/suzuki-gp100-1978-c-e01-e02-e06-e13-e14-e24-e30_model13378/cylinder_5114639140/
So far I have replaced teh spring added a socket for extra preload and
lent on the assembly with all of my 10.6 stome and used an air rattle gun without success.
There are square tapered holder tools on ebay I can buy if people have had success with these or any other suggestion?
Ta ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| Nobby the Bastard |
| Easy-X |
 Easy-X Super Spammer
| Islander |
 Islander World Chat Champion
| A100man |
 Posted: 09:22 - 08 Aug 2023 Post subject: |
Hi folks. Thanks for the tips, this morning I found some 8mm round bar (I dug out of the garden and saved in the that'll be useful one day pile) that I think I can fashion into a tool to loosely resemble this..
https://www.ebay.co.uk/itm/144685234629?
I'll let you know how it goes.. ____________________ Now: A100, GT250A, XJ598, FZ750
 Posted: 12:04 - 08 Aug 2023 Post subject: |
Are you trying to get the bolt in or out?
If out, just drill the head off the bolt.
If in, make sure the rod is jammed all the way into the bottom of the slider by screwing a long bit of threaded bar into it and using it as a slide-hammer. I'd also check the threads are in good order.
Leaning on the assembly is unhelpful, if anything you'd ideally want to be pulling the bolt slightly away from the slider so the rod engages in the bottom of it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 Posted: 13:10 - 08 Aug 2023 Post subject: |
| stinkwheel wrote: | Are you trying to get the bolt in or out?
Leaning on the assembly is unhelpful, if anything you'd ideally want to be pulling the bolt slightly away from the slider so the rod engages in the bottom of it. |
Out!
The Allen head bolt on the bottom of the slider is spinning freely while attached internally to the rod - I'm going to guess that drilling the head off will be tricky in these circs. I think the answer is still a holding tool. ____________________ Now: A100, GT250A, XJ598, FZ750
 Posted: 14:13 - 08 Aug 2023 Post subject: |
I've drilled them before and the puishing down seemed to stop the head rotating too much. The stub that's left has always unscrewed easily afterwards.
You don't need to provide very much resistance to the rod turning for a burp gun to work so a broom handle would probably work, or just keep rattling the fucker until it either undoes or breaks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Posted: 14:52 - 08 Aug 2023 Post subject: |
Doh! Sorry, I assumed you were putting it back together. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| A100man |
 Posted: 08:57 - 09 Aug 2023 Post subject: |
Success! a roughly tapered rod (in this case some bar with a nut weld on the other end) did the trick..
..now skinning my knuckles on getting the damned seals out, heat and small tyre lever tried thus far and it's starting to disintegrate. ____________________ Now: A100, GT250A, XJ598, FZ750
| A100man |
| A100man |
 Posted: 21:10 - 09 Aug 2023 Post subject: |
shucks - no clue how to delete duplicate photo  ____________________ Now: A100, GT250A, XJ598, FZ750
| Nobby the Bastard |
| A100man |
 Posted: 08:54 - 10 Aug 2023 Post subject: |
| Nobby the Bastard wrote: | | stinkwheel wrote: | Fixed it for you. Aye, that looks a lot better than some of the ones I've seen before. |
I note you don't remove the more embarrassing ones that Ste posts of me. |
Nobby, embarassed - oxymoron surely. ____________________ Now: A100, GT250A, XJ598, FZ750
The last post was made 2 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
