| stinkwheel |
 Posted: 16:54 - 09 Aug 2023 Post subject: Bending steel-sih part |
I want to re-profile the bends in a kick-start so it's not as prone to getting in the way of my foot. I've bought a spare one to piss about with so it's not the end of the world if it gets screwed up.
It's for an enfield bullet and is made in India. Looks like chromed cast steel. I doubt the chrome will survive the process and from previous experience, the metal will be of the poorest quality.
I have a MAPP burner and I do have a small coal forge I can get cranked up if necessary (but it's a scutter).
I think cold setting is right out of the question., it'll just snap. The thing is it's a componant that takes a real hiding too, it's got to get a 612cc long stroke engine with 10:1 compression over compression which takes a bit of welly.
I was thinking clamp it in a vice and heat the area to be bent until it's orange red then have at it with a bit of pipe slipped over the end. Then normalise it by taking it up to orange red and allowing to air cool a couple of times.
Would that be it or should I be doing anything else in the realms of heat treating/tempering/ageing so it lands up strong and flexible? Not sure what best to do with cast steel-ish.
It's one of these. I want to straighten the bend just above the splined hole and the next bend up again so it's closer to a straight line (but not totally straight, maybe half the kick-out it currently has).
https://www.bikechatforums.com/files/kickstart.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeremyr62 |
 jeremyr62 Nova Slayer
| Easy-X |
 Easy-X Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 17:49 - 09 Aug 2023 Post subject: |
I doubt you could cold bend it at the spring from the spline end anyway you'll just bend the shank.
Stick it in a vice, cook it at up close to the spline end and bend it. If yu get it glowing bright orange it'll bend easily. If your mapp torch won't get it hot enough because the heat is radiating away let me know and I'll send you a wad of ceramic blanket then you'll be able to get it yellow.
Let it cool right down and then repeat at the crank. Your chrome will surely turn blue. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 17:52 - 09 Aug 2023 Post subject: |
Maybe it is forged then. Whatever it is will have been done in a backstreet workshop in Chennai in any case.
Main question is do I need to heat treat/temper/ageing of some sort afterwards? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 20:18 - 09 Aug 2023 Post subject: |
I had to modify a wrench in order to properly bleed the ABS brakes on my R1150R. I used a propane torch to heat the area prior to bending. Then I let it cool in ambient air.
Cooling quickly (quenching) will improve hardness, but make it brittle as a result.
Cooling slowly will improve ductility, which will make it more shock resistant.
You could put it in an oven to slow down the cooling process even more.
https://live.staticflickr.com/65535/53105709078_8e7921835f_w.jpg ____________________ History shows again and again how nature points out the folly of men - BOC |
| jeremyr62 |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 21:45 - 09 Aug 2023 Post subject: |
I've haven't modded kick starts but have modified some gear levers without them breaking.
Not as much stress on them as a kick start I know, but wonder if the cut/bend/weld method might be worth a try or thinking about in order to get the bar more inline with the black line?
https://imgur.com/G6pQcgS.jpg ____________________ bikers smell of wee |
| stinkwheel |
| WD Forte |
| stinkwheel |
| davebike |
 davebike World Chat Champion
 Posted: 06:11 - 10 Aug 2023 Post subject: |
I bent Pattern Jap kickstarts for customers
You need lots of heat I used a really BIG propane torch 40mm Dia and 57KBTU get the area to bend red hot and it works or did the few times I did it ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| stinkwheel |
The last post was made 2 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
