CG125E Engine??
XL125RC
PostPosted: 20:13 - 16 Aug 2023    Post subject: CG125E Engine?? Reply with quote
Does anyone know what the CG125E engine is from (obviously from a CG but which era specifically?) and if it is supposed to be 4 speed engine as i only seem to be getting 4 gears (1 down 3 up)
Thanks
***Edit: Engine is a CG125E not a CG125BRE
that_impulse_guy
PostPosted: 20:36 - 16 Aug 2023    Post subject: Reply with quote
what does it show on the front sprocket cover?
bcoz, i i remember right...old ones were a 4 down thing...N1234.
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
Nobby the Bastard
Harley Gaydar
PostPosted: 20:41 - 16 Aug 2023    Post subject: Reply with quote
I could have sworn that the one I passed my test on (1992) was 1 down 4 up....
Triumph Sprint ST 1050
WD Forte
PostPosted: 20:57 - 16 Aug 2023    Post subject: Reply with quote
Does it have points ignition or cdi?
bikers smell of wee
that_impulse_guy
PostPosted: 21:27 - 16 Aug 2023    Post subject: Reply with quote
yeah...
theres two real options...the one you describe, which was the 5 spd.
and then a much older 4 down only version.
if OP has a 1d3u thing between his legs, it cant be a 4spd and must be a broken 5spd...or some chinese weird 4spd gearbox has landed up in there. (they make copies of the things with 4 spd in some countries still)..
so if sprocket cover says 1n234....well...
or if it says 1n2345...etc...
(or...its from a bitsa bike and who knows really)
XL125RC
PostPosted: 13:55 - 17 Aug 2023    Post subject: Reply with quote
It has a CDI
Sorry guys the plot thickens... the engine in the log book is a CG125BRE but the actual engine inside it is a CG125E motor and it is a 5 speed i didn't have the wheel off the floor before so it wouldn't go into 5th. its 1 down 4 up.
https://i.postimg.cc/15RTV2HK/20230817-142216.jpg
All would be fine but i *think* this is a 6 volt motor... and the wiring loom has been hacked about so i think someone has put a 6 volt motor in for god knows what reason and then hacked together a wiring loom.
I have purchased a brand new loom but i had no idea this engine was in a 6 volt bike... Really messed up all of this is.
This is the engine if anyone knows for sure what era engine it is?
https://i.postimg.cc/TYR8qpRg/20230817-142308.jpg
WD Forte
PostPosted: 15:23 - 17 Aug 2023    Post subject: Reply with quote
As I roughly recall
CG125s went from 6v to 12v electrics 1985 ish and points to CDI around 1990.
Electric starters were added 2000 ish
I'll guess it's an early 90s model
But, Chines clones may be newer in age but have older more basic
kit fitted
I'd have the stator cover off and check what's fitted inside.
you don't want to find points setup but a stator with both charge and source coils.
If you do, modding the wiring to a 12V system with AC CDI is easy enough and cheap to get after market bits and bobs to make it go.
A GY6 AC-CDI box and 12v RR will probably cost around £25
Is that two mild steel bolts on the header and Philips/Pozi headed screws on the case?
nasty cheap shit way of doing it that is
bikers smell of wee
XL125RC
PostPosted: 18:38 - 17 Aug 2023    Post subject: Reply with quote
Yes, it is and i have no idea why they would do that. Honda did that from the factory back in the day. Shocked
blurredman
PostPosted: 09:41 - 21 Aug 2023    Post subject: Reply with quote
I had an XL125S for a while. It had a Japanese made 6v 5 speed CG125 motor in it too. Though should have had 6 speed overhead cam engine. I would have been happy with it if it wasn't for that missing gear.
Yours similar to this one?
https://www.motorcyclespecs.co.za/model/Honda/honda_xl125r_82.html
WD Forte
PostPosted: 09:54 - 21 Aug 2023    Post subject: Reply with quote
No they didnt, a look at the parts fiche shows bolts and studs
not poundshop screws
bikers smell of wee
The last post was made 2 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 65.74 Kb
