deresticted nsr not getting good performance
ayfy
PostPosted: 21:03 - 12 Apr 2005    Post subject: deresticted nsr not getting good performance Reply with quote
I've just finished derestricting my NSR and just took it out for a test spin. I think there's something not right. Above 7k revs it's fine and pulls really well, but below 7k it just gets bogged down, sometimes it gets bogged down so much it never goes above 7k and I have to change down a gear. I'm assuming this isn't how it should be, any ideas of what could be wrong?
something I did notice was when I took the intake restrictor out there was another part that came out too, looked like it had a filter on it of some kind, I'm assuming this should be left in there and is not part of the restrictor???
mr jamez
PostPosted: 21:26 - 12 Apr 2005    Post subject: Reply with quote
Sounds like you have taken the reed valves out! You really need to put them back in, the only thing to remember is to have the tab on them facing up and that should sort your problem.
gsxrpeak
PostPosted: 00:43 - 13 Apr 2005    Post subject: Reply with quote
did you make sre you put the air box back properly? i managed o scrample up some of the filter once and had the same prob.
visit my shop
www.tqmotorcycles.co.uk
https://stores.ebay.co.uk/TQ-Motorcycles_W0QQsspagenameZMEQ3aFQ3aSTQQtZkm
alains
PostPosted: 11:28 - 13 Apr 2005    Post subject: Reply with quote
part 3 is the resctrictor plate (which has to be taken off)
part 1 is the reed valve , which must be refit (the sharp part inside the barrel)
part 2 is the seal which is to be refit beetween the barrel and the reed block
ayfy
PostPosted: 14:18 - 13 Apr 2005    Post subject: Reply with quote
what do you mean by this? the airbox is just a box so i can't do anything there. if you mean the connector to the carb, that looks fine, it's quite short so it's unlikely it's gonna get tangled up in any way.
I did take the reed valve out but I did put it back in. Apart from the sharp side goes in first, is there an up and down side to it, it looked quite symmetrical to me?
alains
PostPosted: 14:25 - 13 Apr 2005    Post subject: Reply with quote
no , the fixing is equal on both side .
alains
PostPosted: 14:28 - 13 Apr 2005    Post subject: Reply with quote
probably you are restricted on the RC valves control box and CDI , pass me a pm with your serial number i will try to find out which kind of restrictions you have
ayfy
PostPosted: 16:34 - 13 Apr 2005    Post subject: Reply with quote
my bike is a 2002 uk spec so I guess is shouldn't be restricted in the CDI. Is the CDI the bit to the right side of the airbox bolted to the frame that looks like a CPU processor? It says SH693-12 on it, don't know if that helps or not.
another thing is when I took the airbox out I put it on it's side, I don't know exactly what's in the airbox but could something have got dislodged in there that's causing my power loss at low revs?
mr jamez
PostPosted: 16:51 - 13 Apr 2005    Post subject: Reply with quote
The CDI on the later models is under the seat, the black box under the fuel tank will be the power valve actuator.
The airbox is just plastic tub, nothing inside to come loose. Have you checked the airbox hose to the carb is on properley, no air leaking? also it is a good idea to replace the gasket when you remove the rubber intake manifold and reeds etc, check around that area for leaks as well. Other than that I can't really think of anything, unless you need to alter the jetting after derestricting the bike? not sure.
alains
PostPosted: 17:33 - 13 Apr 2005    Post subject: Reply with quote
allright but , which is important are the letter after the ZDCJC22B.......... which determine for which country it has been built with which restrictions . if i got that , i will be able to help
ayfy
PostPosted: 11:10 - 15 Apr 2005    Post subject: Reply with quote
this is really annoying, I took everything off again that I took off before and but it all back, checking absolutely everything. No difference. I did notice that the choke cable sticks on and I thought that might have been the problem but little difference.
from the problem I've described, ie. not pulling very well below 7k revs, does it sound like it's restricted somewhere else or is there something wrong with the bike? It's a 2002 UK bike so shouldn't be restricted other than in the exhaust and intake, anyone else derestricted a uk nsr of this age?
BTW I sent you a pm alains.
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 68.13 Kb
