Hanway Cafe 125 Issue
peeky1323
PostPosted: 11:25 - 01 Sep 2023    Post subject: Hanway Cafe 125 Issue Reply with quote
Hi All. My son has bought a 2020 Hanway BlackCafe 125 about 4 weeks ago. It's been fine for 2 weeks and then all of a sudden it's cutting out when you open the throttle more than 1/2 way. Also it idles rough. I unplugged what I thought was the MAF sensor and this made no different so I am thinking air leak although I can't see any issue on the throttle body, but I have not checked every vacuum hose etc. Sparkplug is fine. Does anyone have any ideas please?
Nobby the Bastard
Harley Gaydar
PostPosted: 12:40 - 01 Sep 2023    Post subject: Reply with quote
Ask him what he's been fucking around with on it.
Triumph Sprint ST 1050
peeky1323
PostPosted: 12:42 - 01 Sep 2023    Post subject: Reply with quote
He hasn't touched anything but thanks.
WD Forte
PostPosted: 14:10 - 01 Sep 2023    Post subject: Reply with quote
If its EFI then it has an ECU which in turn will have DTCs so read em
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 14:11 - 01 Sep 2023    Post subject: Reply with quote
I'm still hedging my bets on the youngling had a fiddle and hasn't yet admitted it.
WD Forte
PostPosted: 14:50 - 01 Sep 2023    Post subject: Reply with quote
Could well be, it looks like a cafe'd CG clone with EFI to comply with rules and yoofs is well into 'owner improvements'
Mind you, it is 2 years old now and chinese bikes haven't built a rep
for longevity
bikers smell of wee
peeky1323
PostPosted: 14:53 - 01 Sep 2023    Post subject: Reply with quote
He really hasn't. He is not technically minded and would have no need or desire to tinker with a working bike he uses for work commuting.
I have an ODB2 reader for cars but am trying to find out what adapter I need for this bike, and where the port is. The check engine light is on all the time now.
peeky1323
PostPosted: 14:56 - 01 Sep 2023    Post subject: Reply with quote
[quote="WD Forte"]If its EFI then it has an ECU which in turn will have DTCs so read em[/quote
Yes, it's EFI. I am trying to find out what adapter I need for my ODB2 reader and also where the port is.
WD Forte
PostPosted: 15:05 - 01 Sep 2023    Post subject: Reply with quote
A lot of chinese bikes used the Delphi or Delphi cloned ECUs.
on some Delphi systems,
if you turned the ignition on then off then on again and wait
they would flash out the fault codes
worth a try
bikers smell of wee
peeky1323
PostPosted: 15:50 - 01 Sep 2023    Post subject: Reply with quote
worth a try
I gave that a try but it didn't show anything.
Thanks, Matt
WD Forte
PostPosted: 16:44 - 01 Sep 2023    Post subject: Reply with quote
I'm now under the impression they use a Mikuni (best known for carbs) ECU
and it uses a common KWP2000protocol at obd 1 level which should be enough to get DTCs from.
CMPO would probably flog you a 16pin OBD to 3 pin adapter
bikers smell of wee
A100man
PostPosted: 17:05 - 01 Sep 2023    Post subject: Reply with quote
BTW - this is Nobby's equivalent to 'Welcome to the forum' Wink
peeky1323
PostPosted: 11:17 - 07 Sep 2023    Post subject: Reply with quote
Thanks. Do you know where the ODBC port is?
I also noticed what sounds like a loud fuel pump. A weird thing I've noticed is if you just barley move the throttle it dies. If you give it a rev it's fine.
peeky1323
PostPosted: 13:36 - 07 Sep 2023    Post subject: Reply with quote
Very Happy Very Happy
peeky1323
PostPosted: 13:02 - 11 Sep 2023    Post subject: mostly fixed Reply with quote
Hi All.
Just an update in case anyone is interested. I replaced the coil and this resolved the issue. However, the engine management light is still on so I guess I need to get an ODB2/1 adapter cable to reset it.
WD Forte
PostPosted: 13:14 - 11 Sep 2023    Post subject: Reply with quote
The ECU may or may not be actually sensing the coil status so
the eml may be indicating something else.
Best to read and note codes, delete, ride bike for a short while and test again to see if any come back.
bikers smell of wee
The last post was made 2 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 84.62 Kb
