| TerminalMan |
 TerminalMan L Plate Warrior
| Raffles |
 Raffles World Chat Champion
| TerminalMan |
 Posted: 10:47 - 17 Sep 2023 Post subject: |
Easiest way is to clamp it back in the yokes then use a two or three leg puller hooked under the top yoke to push the cap down and hold it there (I'm pretty sure that's why there is a dimple in the centre of them), then you can pry the circlip out and release the spring tension slowly and in a controlled fashion.
Nobody likes being hit in the face with a ballistic lump of metal which is what will happen if you try to do it by pushing down and getting someone to ping the circlip out. They are a near impossability to put back in if they aren't clamped in something. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 11:15 - 17 Sep 2023 Post subject: |
I can't remember if the 550 was the same but for sure on the 850 once you get the spring out you need to undo the bolt in the bottom of the fork leg to dismantle the rest of it, but the inside piece (damper?) will spin. To stop it from turning you put 2 M12 nuts on a long bit of studding and poke it down the leg do engage with the cutout in the damper then the bolt will un-do. ____________________ a.k.a 'Geri'
| TerminalMan |
| Bhud |
 Bhud World Chat Champion
 Posted: 19:19 - 17 Sep 2023 Post subject: |
Jubilee-clip a ring spanner to the leg with the ring end up above the top edge. Use an open-ended spanner and long socket to depress the plug by hooking the spanner into the ring spanner end and using it as a lever. Once you have the plug depressed, pick out the spring clip. ____________________ a.k.a 'Geri'
The last post was made 3 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
