| BusterGonads |
 BusterGonads Trackday Trickster
 Posted: 13:30 - 05 Oct 2023 Post subject: CB250 Nighthawk 1997 Fork Seals |
Hello again bike mechanic gurus... Been a while.
Bit of a puzzle here - more below.
Recently, I sold my Street Twin and got the old bargain (£650) Nighthawk 250 out of the garage where it had been sitting for couple of years under a cloth, and got it mot'd in July. It has a leaking fork seal, but not bad, just a slight weep really, that would leave a thin line on the chrome of the stanshion so I just did a cheeky wipe of the fork outside the MOT place and the geezer passed it A1 no advisories. So, I've ridden it about a thousand miles this summer, around the winding lanes here in Northumberland, while I was deciding about whether to pull the trigger on another bike.
Meanwhile - over that thousand miles the leak got a wee bit worse, so I undid the top nut on the fork and pumped out most of the oil to see how it affected damping. Using one of those Lidle oil change oil pumps, I extracted all I could reach, but there is a minimal amount left in the bottom I think. The damping seems not affected at all. The fork is just about empty, but damping is fine as is handling. I got about 80ml out so I don't think much can be left.
So now - I can go for a ride and there is next to no weeping in twenty - twenty-five miles. I raise the dust seal after such a ride and the top of the seal is clear of pooled oil. HOWEVER - over the next few hours, oil is seeping upwards into the space above the seal. Maybe half a ml or more. How can this happen????
I am wondering of somehow the fork inside is becoming pressurised during the ride and pushing residual splashed oil out. How does it happen after the ride and not during it? It definitely isn't coming from anywhere else than below the seal, but the bike is sitting in the garage inactive, on its side stand, and up she comes.
PS - I know the solution is to replace, and I have ordered a seal kit on ebay.
EDIT: just noticed that you can see the oil line on the right front fork in the picture if you expand the image. That would be what I used to get out in about twenty odd miles before I took the oil out. ____________________ 2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250 |
 Posted: 14:51 - 05 Oct 2023 Post subject: |
Well, the oil will be hot and frothy after being compressed through the holes in the damper rod. Even more so if you've only got a small amount of oil in there.
I'd imagine riding along will air cool it a fair bit then when you stop, the heat would let the air and oil froth inside the shock expand. A bit like a coolant system that pukes a little coolant after you park up because it's topped circulating.
But yeah, new seals. Use OEM ones if you don't want to do them again in 6 months. Also may be worth replacing the bushes, worn bushes are a common cause of seal failure and it's also not unheard of to wreck them taking the fork apart. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| BusterGonads |
| BusterGonads |
| Robby |
 Robby Dirty Old Man
| blurredman |
 Posted: 10:41 - 06 Oct 2023 Post subject: |
Contrastly, I've never bought genuine seals, only generic ones and i've never had them leak.
I just get the size and order the cheapest generic seals I can. £3 to £5 for both, delivered normally. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| BusterGonads |
| Robby |
 Robby Dirty Old Man
| Bikebolt |
 Bikebolt L Plate Warrior
| BusterGonads |
The last post was made 3 years, 39 days ago. Instead of replying here, would creating a new thread be more useful? |
