Suzuki A100 wiring diagram?
Bloater
PostPosted: 10:54 - 16 Oct 2023    Post subject: Suzuki A100 wiring diagram? Reply with quote
Morning all, I thought I'd try my luck with the collective and see if anyone can possibly help me out?
I'm lucky enough to own a 1980 Suzuki A100 N that has been in the family since new. I have recently had chance to restore it but unfortunately I'm having problems with the lights and blowing bulbs. I have the Haynes manual but, although there are several wiring diagrams for different models included mine does not appear to be one of them. Although there are several similar wires on mine that correspond to the last diagram there are also several that don't. The current wiring appears to be original however I don't think its covered in the manual I have.
My bike has a 4 position, 9 wire ignition and a lighting ceramic resistor as well as a rectifier. None of the manual diagrams show this configuration or all of the associated colours.
If anyone can help, or would possibly have a wiring diagram, I would be really grateful for any input.
Thanks in advance
Bloater
A100man
PostPosted: 11:08 - 16 Oct 2023    Post subject: Reply with quote
Un regulated AC lighting could be part of the problem..
Thers's a diagram in the back on my owners manual - if you have yours (since owned from new)
that migth help, otherwise I'll try and upload a picture of mine (diagram Rolling Eyes ).
Bloater
PostPosted: 11:52 - 16 Oct 2023    Post subject: Reply with quote
Hi, many thanks for your prompt reply.
I do have a owners manual and I thought that I had checked, I will definitely take another look when I get home though.
However, if you did get a chance to upload yours that would be really helpful and much appreciated.
Thanks again
Bloater
Bloater
PostPosted: 17:18 - 16 Oct 2023    Post subject: Reply with quote
Just to keep things updated.
I got home this afternoon and checked the hand book as suggested............We'll like you said there, right at the back, was indeed a wiring diagram, however, then I remembered, I had looked before but, it was for the French model, not mine Sad .
Then it happened the 'Homer' moment, 'DOHHHHHH'!!
I unfolded it (which I'd never done before), turned it over and 'low and behold' the UK version! It's exactly what I needed Embarassed Embarassed Embarassed
Thank you for your suggestion if it wasn't for you sharing your thoughts I would have still have been endlessly searching the net whilst all the time I had the genuine Suzuki article sitting in my spare bedroom.
All the best and thanks again
Bloater
A100man
PostPosted: 20:46 - 16 Oct 2023    Post subject: Reply with quote
Bloater
Thumbs Up All's well that ends well. Bizarrely mine has 'Pakistan' version on one side and 'All other markets' on the other..
There is a gap of 1 year, 203 days between these two posts...
Bigjimknicker...
PostPosted: 19:07 - 07 May 2025    Post subject: Re: Suzuki A100 wiring diagram? Reply with quote
Thanks in advance
Bloater
Any luck with this wiring?
I’m sure mine is an A100N & I can only find A100 k/l/m diagrams
Any help appreciated!!
slowasyoulike
PostPosted: 19:09 - 10 May 2025    Post subject: Re: Suzuki A100 wiring diagram? Reply with quote
If you'd bothered to actually read the two year old thread you've replied to, you would know that OP found a wiring diagram at the back of his manual...
Bigjimknicker...
PostPosted: 14:48 - 11 May 2025    Post subject: Reply with quote
I did read the whole thread, I’ve searched extensively for my wiring diagram with no luck, if you don’t have anything helpful to say keep quiet.
Mine is different to every diagram I’ve found so I’m simply asking for some help.
WD Forte
PostPosted: 16:03 - 11 May 2025    Post subject: Reply with quote
Just saying you have an A100N isn't much help to anyone not familiar the bike, but the 6v system with AC lighting system is common for that era.
its a 6V system with points I assume?
I'd just update the whole crappy system meself but
it would be easy enough to just stick led blubs in the fecker with maybe an additional diode and capacitor for each to smooth out the nipples.
bikers smell of wee
Bigjimknicker...
PostPosted: 18:02 - 11 May 2025    Post subject: Reply with quote
Yes it is 6V & point I believe, the trouble I have is that my loom looks OE, the stator wires match the loom too, I just can’t seem to find matching wires to the ignition plug, so even if I replace the loom I still have to figure out why my wires don’t match on the stator, it’s very strange I’ve even emailed Suzuki uk asking them to supply a wiring diagram & given them the VIN no too.
WD Forte
PostPosted: 22:32 - 11 May 2025    Post subject: Reply with quote
Bearing in mind the bike is pretty damn simple and uses almost the same electruical system as many other bike of that era,
if you cant understand a simple bike like this you'll probably be better off letting who does do it
bikers smell of wee
The last post was made 1 year, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 70.58 Kb
