VFR750F Overheating
GaryWright670...
PostPosted: 12:26 - 16 Oct 2023    Post subject: VFR750F Overheating Reply with quote
My beloved Honda VFR 750F 1992 is overheating. Please can anyone tell me what might be the cause or at least tell me what I should check first. Accessing the thermostat seems a very major dismantling job. But before I do that what else might be the cause? Question
Thanks
(PS This is my first posting to this forum Smile
jaffa90
PostPosted: 16:46 - 16 Oct 2023    Post subject: Reply with quote
Hi, what tells you it`s overheating?
Robby
Dirty Old Man
PostPosted: 17:42 - 16 Oct 2023    Post subject: Reply with quote
Does it have any coolant in the radiator and expansion bottle?
Is the radiator fan kicking in when it gets hot?
jeffyjeff
PostPosted: 21:37 - 16 Oct 2023    Post subject: Re: VFR750F Overheating Reply with quote
I would check the following in this order:
1. Low coolant level
2. Obstructed radiator
3. Poor coolant flow (collapsed or obstructed coolant hose)
4. Failed fan switch (fan won't operate, overheats when stopped)
4. Failed water pump or water pump drive
5. Failed thermostat
Any of these things could cause overheating. A failed temp sensor could cause your temp gauge to read higher than normal, leading you to believe the engine is overheating when in fact it is not. Like Jaffa90 said, why do you think it is overheating? More than likely, the symptoms will lead you to one of the investigative checks listed above.
Edit: Low coolant level could be caused by a leak, failed radiator cap, or failed head gasket. Failed cap or head gasket will likely force coolant out of the recovery tank. Coolant in the engine oil is one indicator of a failed head gasket. When a hot engine is stopped, pressurized coolant in the water jacket is forced through the failed head gasket and drains into the crankcase.
PostPosted: 08:15 - 20 Oct 2023    Post subject: Reply with quote
In what circumatances is it overheating?
On most older VFRs of that era, the radiator itself can be in a bit of a grungy state. Is it clean and are the cooling fins mostly clear and straight? Likewise the oil cooler. The oil cooler lines are also fairly out in the open, they are known for corrosion (which would cause a significant oil leak) but they are succeptable to damage or pinching too.
When was the coolant last changed? Was it drained properly via both the drain screw on the bottom of the water pump and the two drain screws on the front of the barrels? If it's not been done for a while, might be worth draining it to see if it's full of grunge and giving it a flush through. You'd going to need to remove some parts to get in about the filler cap and such anyway so it's worth doing while you're in there, then you know the system is clean and full of coolant. I generally drain it then stick a hose in the filler cap and trickle water through it slowly for a while. Then I fill it with water, run it up to temperastre and drain it a couple of times. The process of doing this might throw something up anyway.
The thermostat is a major suspect though. It's a bit of a pain in the arse to get at. You should be able to fiddle it out if you remove the right hand side panel and the coolant hose on the right side, then you can reach through the frame and undo the bolts to get the lid off. You may need to be inventive with small ratchet spanners and 1/4" sockets. Here's roughly what you're looking at with the airbox and carbs removed (at which point it's easy), this is a later model than yours but still an RC36 so it should all be very similar. It is possible to do with the carbs in place though but there is a lot of stuff in the way.
https://lh3.googleusercontent.com/pw/ADCreHeC7XEGAiGtmHBCacAY_IN2c-Xja0DvTMLac7i64uf-HSy2PnbHR_4H5r00zN3vfiDqCNKGKbf_yQa9b5gBZ2RLJwU8LypuDIpR3lGmCMIcdJhWOTblldPB-jkPF_oBkljQTIfmIrXjtLGn3rbCwZok=w1547-h870-s-no
jaffa90
PostPosted: 01:01 - 21 Oct 2023    Post subject: Reply with quote
Sounds like the O.P. has heat stroke? Crying or Very sad
The last post was made 3 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 49.72 Kb
