SR500 Ignition Question
ChrisA1983
PostPosted: 20:07 - 17 Oct 2023    Post subject: SR500 Ignition Question Reply with quote
Hi all,
New to the forum and new to bike building. Picked up a half done kick start SR500 chopper conversion recently and have an ignition question.
Just installing a fuse box and it comes with 3 wires; positive, negative and positive ignition. My question is, when putting a tester on my current ignition, it's showing as 2 negatives (1 in the on and 1 in off position). Obviously on connecting the ignition wire to this (before checking!), it blew the fuse. Is 2 negatives correct? And if so, where would I connect the ignition positive? Obviously if I touch it to the positive on the battery everything works fine.
So hard to find anywhere where you can ask a quick question so hopefully someone here can point me in the right direction
Thanks in advance.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:10 - 17 Oct 2023    Post subject: Reply with quote
I would imagine (if it doesn't earth through its body) oneof the positives is for the lighting etc. and one is for the sparks with a common earth.
Triumph Sprint ST 1050
jeffyjeff
PostPosted: 19:49 - 18 Oct 2023    Post subject: Re: SR500 Ignition Question Reply with quote
ChrisA1983 wrote:
...My question is, when putting a tester on my current ignition, it's showing as 2 negatives (1 in the on and 1 in off position).
Unaware of any need or purpose for a switched negative on a negative ground electrical system. Are you sure that you did not mistakenly invert the meter leads when you took your measurement?
WD Forte
PostPosted: 20:53 - 18 Oct 2023    Post subject: Reply with quote
None of this makes any sense to me.
why would a fuse box have a ground wire?
what function would that serve?
a fuse box isbasically, a pass through device
Power in and distributed power out, thassit.
No grounds needed.
The whole description is highly suspect (bollox) to me
bikers smell of wee
jeffyjeff
PostPosted: 23:37 - 18 Oct 2023    Post subject: Reply with quote
...half baked kick start SR500 chopper pretty much sums up all you need to know.
PostPosted: 07:56 - 20 Oct 2023    Post subject: Reply with quote
Surely the fuse should be between the battery and the rest of the wiring, as near to the battery as you can get it.
The last post was made 3 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 48.06 Kb
