Recommend me a router , I want to be able to remotely access
kawakid
PostPosted: 20:19 - 19 Nov 2023    Post subject: Recommend me a router , I want to be able to remotely access Reply with quote
Hello,
I spend quite a bit of time outside of the UK, its usually Mon-Thu in Europe for work or the occasional holiday.
I spend a lot of evening watching TV on my tablet, usually stuff on Netflix that I have downloaded or Prime.
Years ago, I used to have a Draytek Vigor router and could connect to my home network and by doing so, could then surf using my local Halifax IP address. (It was a bit shxt, but it worked).
Fast forward at least 13 years, I'm looking to do so again. I want to be able to VPN to my home. (Basically so I can watch Jungle whilst in Hamburg ffs Rolling Eyes Rolling Eyes and not to have the restricted list on Prime).
I'm on Virgin Media, I am wanting recommendations on a home router that will do this, I know I'll need to put the Virgin router in to modem mode.
Ideally I want a VPN solution that I can use on my android tablet. i.e. I connect to my home VPN, then I run ITV, Prime etc
Can anyone recommend a router. ( I'm not interersted in a UK VPN service, I want to access and surf out of my own line).
Any help appreciated.
I've a twin and a 4.
PostPosted: 22:15 - 19 Nov 2023    Post subject: Reply with quote
Seems backwards, but I'd just grab a cheap ASUS router, install Merlin and do it that way if you really want to route across the internet.
You won't need modem mode if you want to just VPN in, just pop it behind the router or DMZ it/port forward. Yolo.
Surfshark would be better and probably cheaper over 4 years Laughing
Exposing anything to the net just doesn't sit well with me these days.
Easy-X
PostPosted: 09:51 - 20 Nov 2023    Post subject: Reply with quote
Quite a few routers have a built-in VPN server. I've not really had much luck with them in the past but I did revisit this topic recently and had some success with Asus routers.
The better alternative is to deploy something like a Raspberry Pi as an OpenVPN or Wireguard server and then you have a lot more options to play with. You can probably still use the Virgin Media router if it has the ability to forward TCP/UDP ports onto the Pi.
Mysteriass
PostPosted: 22:22 - 20 Nov 2023    Post subject: Reply with quote
Hamburg?
Can't you just look out the window?
The last post was made 2 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 40.38 Kb
