Lexamoto venom 125 2016 loss of power not liking idle
Adi123
PostPosted: 10:02 - 21 Nov 2023    Post subject: Lexamoto venom 125 2016 loss of power not liking idle Reply with quote
Bought the bike second hand from my dad knowing it's sat for about a year and I've rid it 3 weeks and it just cut any throttle you give it when it's warm and won't idle at all have to keep it 1/4 of throttle to keep it alive
Mysteriass
PostPosted: 10:51 - 21 Nov 2023    Post subject: Reply with quote
We need a bit more information but I'll take a preliminary guess...
Is it carb or fuel injection? I'm guessing carb?
If it's carb and it's been standing then the jets have probably got gummed up (Worse these days due to ethanol in the fuel). Need to take the carb off, take it apart, unscrew all the jets, clean and blow through everything until it's all immaculate.
Make sure the airbox and filter looks clear and clean while you're at it.
Before you do that though, is the choke getting stuck on? Is the cable for the choke bust? Is it half on and half off?
Speaking of "choke", fuel injection has a form of "choke" often called a fast idle. There's a thingymagig and a sensor that takes care of it that and might need looking at.
If it's fuel injection. It could be a sensor issue somewhere, most likely the engine temperature sensor that's got bust or corroded and might need replacing.
The last post was made 2 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 31.66 Kb
